POV-Ray : Newsgroups : povray.unofficial.patches : Your wanted features Server Time
16 Apr 2026 06:17:34 EDT (-0400)
  Your wanted features (Message 1 to 10 of 30)
Subject: Your wanted features
Date: 5 Jun 2003 11:20:01
Message: <web.3edf5ebd7e2b69fbaa7c54710@news.povray.org>
Let's make a nice big list of all the features people would like to see in
an official/unofficial version of POVRay!
I'll start it off with a couple of items.
Bicubic texture filtering. There is actually a #DECLARE statement for cubic
filtering in the POV source, but there is no implementation that uses it.
Fractal texture filtering. I've seen a sample image that has been resized
using fractal interpolation, and did it ever look good.
Displacement mapping. I've read a bit about it in a magazine (although this
article was about it in DirectX 9), and it sounds like it would be quite
useful in POVRay. Add a displacement{} block with the appropriate contents,
just like the normal{} one.
I'll leave it to the rest of you to come up with some more items for the
list.
Rohan _e_ii
Subject: Re: Your wanted features
Date: 5 Jun 2003 12:23:27
Message: <cjameshuff-8C2F99.11144505062003@netplex.aussie.org>
In article <web.3edf5ebd7e2b69fbaa7c54710@news.povray.org>,
That shouldn't be too hard.
Aside from being highly complex to implement, this would probably slow
things down a lot. You'd be better off resizing outside of POV, and
using a computationally cheaper method in the rendering.
This one has been discussed a *lot*. To summarize: it is possible, but
is far from simple. General displacement would require tessellation of
all objects, which is possible but a real pain to implement.
http://tag.povray.org/
Date: 5 Jun 2003 12:46:22
Message: <cjameshuff-7927C6.11374005062003@netplex.aussie.org>
BTW, here's the POV-related stuff on my own "to-do" list.
voxelize pigment/pattern: what I originally called "smooth blur", takes
samples at the vertices of a 3D lattice (like the corners of the
checkers pattern) and interpolates between them. With a fine enough
lattice, it might allow infinite gradients in things like the object
pattern to be softened enough for efficient isosurface solving without
too many artifacts.
blur pigment/pattern: What it says, it blurs a pigment or pattern.
portal pigment: I've made some posts about this before, I just need to
get it into release-ready form. It's a pigment that serves as a "portal"
into another area of the scene.
Tessellation: I'm working on my own tessellation patch. Others have done
general tessellation methods, I'm doing shape-specific methods. So far
I've got nice tessellations for spheres, cylinders, cones, and a few
other shapes.
Glow: I want to eventually have a glow feature that allows point, line,
hoop, and spline glows (think of neon lights for that last one) as well
as object glows. The last feature will require the tessellation patch.
Proximity and curvature patterns: I have some ideas for making the
rendering faster while getting rid of grainyness with the general
method, and object-specific methods that are very fast.
point_field object, displaced_mesh.
Date: 5 Jun 2003 13:19:15
Message: <3edf7b93@news.povray.org>
  I see two possible ways of implementing this:
  1: The pigment works as a projection plane of a secondary camera. That is,
     When the color of the point <x,y> is asked from the pigment, these
     coordinates are converted to the secondary projection plane coordinates,
     and a ray is raytraced from the secondary camera passing through that
     point.
       The effect of this method is exactly the same as if you had rendered
     an image with the secondary camera and then used this resulting image
     as an image map in the final scene (which is rendered using the main
     camera). The advantage being, of course, that only those pixels which
     are really needed are traced and you don't need a temporary image file.
  2: The pigment warps rays to another location. That is, when a ray hits
     the object and the color of the surface is requested, a given offset
     is added to the intersection point and a new ray is traced in the
     same direction as the original incoming ray. A given transformation
     may be applied to the ray as well.
       This would allow making, eg. windows which show scenery from a
     completely different part of the scene (ie. which are not really
     behind that window). The difference with the implementation 1 is
     that when you move the camera, you see different parts of the
     scene through the portal.
  I think that both of these variants are useful. It might be a good idea
to implement them both.
Date: 5 Jun 2003 13:37:59
Message: <smvudv0n5qb26c6el9sf6pi792glckpdi5@4ax.com>
Case 1 is already in MegaPOV 1.1 code. It is called camera_view{}. It can be
used as follow:
   pigment{ camera_view{ CAMERA_IDENTIFIER || CAMERA_SYNTAX } }
Has to wait for 3.51 unfortunatelly.
ABX
Date: 5 Jun 2003 14:14:38
Message: <cjameshuff-357808.13055705062003@netplex.aussie.org>
In article <3edf7b93@news.povray.org>, Warp <war### [at] tagpovrayorg>
>      point.
Someone else wrote a camera pigment patch which does this.
This is what my portal pigment does. It is not just an offset, it is a
full transformation. I've used it to make something look like a
"gateway" to another world and to make one of those infinitely
self-containing scenes, where the entire scene was visible in a crystal
ball in the center of the scene. Other effects are based on making the
ray directions interact with the normal.
Here's my original post:
http://news.povray.org/povray.binaries.images/13490/
Date: 5 Jun 2003 15:03:57
Message: <3edf941d@news.povray.org>
I would like to see some of POVMan's nice surfaces and finishes implemented
in POV-Ray. I really like this anisotropic reflections or FSSS.
Unfortunately I'm not familiar with renderman specs so I cannot really use
POVMan.
Andreas
http://www.render-zone.com
Date: 5 Jun 2003 16:09:04
Message: <3EDFA387.7E2F7C05@gmx.de>
I don't think this is a good idea, a lot of 'i want' without much
knowledge about how something works and if it is necessary at all is not
very helpful.  An 'i would like to see feature XXX in POV-Ray' when XXX is
anything someone has read about in an advertisement for whatever program
won't lead to anything.
There is nothing against putting together a list but this would only be
valuable when at least someone has already seriously made up his mind
about any item in that list.
If you want to discuss an idea for a new feature it is usually better to
post about what effect you are trying to achieve and possibly why you are
not content with the way this is currently possible in POV.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 6 Jun 2003 05:21:37
Message: <3ee05d21$1@news.povray.org>
I am wondering if there are so many programmers out there who are
wondering what project to do next. I am under the impression that most
are rather overwhelmed by their own project (pov patches, other
programming and RL).
Povingly,
Philippe
Date: 6 Jun 2003 15:08:38
Message: <3ee0e6b6@news.povray.org>
"Rohan Bernett" <rox### [at] yahoocom> wrote in message
news:web.3edf5ebd7e2b69fbaa7c54710@news.povray.org...
I'm waiting patiently for the camera_view pigment and perhaps at a later
date a scene pigment where a pigment is taken from an entirely separate
scene.
I would also like to see uv_mapping for functions, so that uv_mapped and
traditional pigments can be combined and manipulated the way that other
function pigments can.
The point of my response however is to ask how polygon displacement can
do anything which isosurfaces cannot do. I would like some clarification
because now I really cannot see the point.
What would be interesting is a set of mesh structures which could be
"built" when rendering and require less memory usage. For example, a
mesh box which would only need 8 vertices stored in memory. PoV-Ray
would know where the 12 triangles should be. This would be most useful
for grass, tiny spaceship details, flower petals, etc. Even better would
be some way to define a set list of triangles (as vertex list
references) for any list of the correct number of vertices. Just
throwing this out there. I've of course got no idea how to implement it.
 -Shay
