POV-Ray : Newsgroups : povray.unofficial.patches : Linux framebuffer patch version 0.3 released Server Time
16 Mar 2026 17:29:05 EDT (-0400)
  Linux framebuffer patch version 0.3 released (Message 2 to 11 of 11)
<<< Previous 1 Messages Goto Initial 10 Messages
Subject: Re: Linux framebuffer patch version 0.3 released
Date: 18 Aug 2005 10:21:36
Message: <43049970@news.povray.org>
Note: installation instruction (as for version 0.2)
	To apply the patch, untar the archive and copy all the files from the
newly created povray-3.6.1-fb-0.3.0/ directory to the corresponding locations
in the source distribution of povray-3.6.1.  Then run the ./configure script
as usual, and 'make check' to build and run a test render.  The tarball contains
only the new and modified files, as compared to the official povray-3.6.1 for
Unix source archive.
(From version 0.2 to 0.3 only the unix/fbb.cpp file was actually changed.
Thus it should be safe to copy that file alone if you already applied the
previous version of this patch to povray-3.6.1.)
	- NC
Date: 18 Aug 2005 10:45:02
Message: <de26q0$trs$1@chho.imagico.de>
Nicolas Calimet wrote:
> - add support for (user-supplied) background image a la X Window
You know i have been somewhat reluctant about the user supplied
background (using the core code image reading functions for something
there were't intended for...)
But of course using libxpm isn't an option here. :-)
Maybe we should just write a simple PPM reader that can be used by all
display modes for reading the background image.
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 18 Aug 2005 11:09:16
Message: <4304a49c$1@news.povray.org>
	... and you know that looking at the code will tell you that
those core functions aren't badly hijacked: it's actually quite clean
	PPM can't handle transparency (gimp says).  Can it?
	- NC
Date: 18 Aug 2005 12:05:02
Message: <de2bi2$uvg$1@chho.imagico.de>
Well - this is not the point.  The problem is that when making changes
to the core code possible requirements of the frontend using the code
for a different nonstandard purpose are no concern.  In other words: The
interfaces between core code and platform specific frontend should be
well defined for both directions and currently this is not the case for
using the image reading functions in the frontend.
No but what use has transparency except having a totally transparent
image (which does not need to be an image anyway).  Note you can of
course also implement a PNG reader but this would require libpng.
Date: 18 Aug 2005 13:45:02
Message: <de2hb1$6i$1@chho.imagico.de>
>     This patch is against pov 3.6, for which I doubt there will be any
> such core change.
For integrating this patch into MegaPOV we have to consider
maintainability.  It is quite possibe that there will be patches
changing the way images are read in the future.  To add some feature not
actually extending program usability, just adding some gimmick, at this
cost is not very good.  So when adding this patch to MegaPOV (which i
seriously consider - the patch itself is a very interesting and useful
one) i will most likely remove this part.
>> image
>     That's precisely the point.
>     I'd be interested to see how you would use the current background.*
> feature to get transparent background (apart from disabling the default
> checker code or adding support for some extra command / env var).
Quite simple: reserve a certain file name used for the background image
to be interpreted as plain transparent.  Same can be used for different
internally generated checkers.  See the ImageMagick built-in
Images/Patterns for what i mean.
Date: 18 Aug 2005 14:29:57
Message: <4304d3a5$1@news.povray.org>
> maintainability.
	I knew you would answer something around these lines, which is one reason
that motivated the cancelling of my post.  But too late apparently  :-p
	- NC
Date: 18 Aug 2005 14:38:00
Message: <4304d588@news.povray.org>
	Not something I find particularly elegant either.
	- NC
Date: 18 Aug 2005 15:00:02
Message: <de2lpr$15s$1@chho.imagico.de>
>> maintainability.
> reason
Just FYI: You have at most 5 minutes to cancel a post to prevent it from
becoming visible for me (because i suck news every 5 minutes). ;-)
I find it a fairly good concept.  You can have any number of internal
background patterns and the user has easy access to them without need to
handle a separate file for each of them.  The background image
reading/generation would be in the general code (in unix.cpp) and the
different display modes would simply access them with some function.
Date: 18 Aug 2005 15:45:09
Message: <4304e545@news.povray.org>
	I still don't quite understand how this would work from the user
standpoint (I'll look later at how imagemagick does) i.e. how the user
tell povray to use whatever image or pattern.
	Well probably too much coding of color bitmasks these last days...
	This is something I already wanted to do, so at least I agree
to this point  ;-)
	- NC
Date: 18 Aug 2005 16:25:02
Message: <de2qna$28f$1@chho.imagico.de>
Well - with Imagemagick you can specify 'magick:LOGO' (or 'LOGO:' in old
style syntax) as file name to obtain the internally generated logo
image.  Same for other images or patterns like 'pattern:checkboard'.
So when POV-Ray has a command line option -background <file> just use
something like -background internal:TRANSPARENT
I know there currently is no such option but it could be introduced
(alternatively/additionally an environment variable).
