POV-Ray : Newsgroups : povray.unofficial.patches : Crash after 63 frames? Server Time
16 May 2026 23:42:13 EDT (-0400)
  Crash after 63 frames? (Message 1 to 10 of 46)
Subject: Crash after 63 frames?
Date: 30 Oct 2003 11:53:09
Message: <3fa141f5$1@news.povray.org>
I'm not sure if this is a POV-Ray/Macintosh or MacMegaPOV problem, so I'll
try here first.
I am trying to run a rather long animation job (750 frames) on my G5
workstation (OS X 10.2.7, *not* Panther) using MacMegaPOV Carbon 1.0, and
without fail the job poops out after rendering 63 frames. I have the start
and end frames set to 638 and 1388 respectively, but after 63 frames
MacMegaPOV crashes and dies.
I learned a long time ago on the Windows version of regular (unpatched)
POV-Ray to not run a long animation batch inside POV-Ray because it doesn't
release the memory it allocates before starting another frame. Instead, I
run POV-Ray from the command line and feed it one frame at a time, thereby
ensuring that POV-Ray releases any allocated memory as it exits after
rendering each frame (my model uses a *lot* of texture, image and bump maps
and consumes 500+ MB of memory to render 1 frame). But since there is no
command line in Macintosh, I don't see any other alternative than to run
animation jobs inside MacMegaPOV.
Any suggestions??
Subject: Re: Crash after 63 frames?
Date: 30 Oct 2003 12:07:59
Message: <8ug2qv0gi9kp09ruc9kmqoab5nsu1f1q34@4ax.com>
On Thu, 30 Oct 2003 11:53:09 -0500, "Scott Gammans"
<dee### [at] yahoocom> wrote:
> Any suggestions??
Waiting for MacMegaPOV maintainer, I would suggest as follow:
Try it again with no other software run. Does it stop each time on pure OS?
If yes try to make as minimal as possible your scene when this behaviour
occur. If you have any access to other platform (you mentioned Windows) try to
run your scene there with WinMegaPOV. Describe your results then.
ABX
Date: 30 Oct 2003 12:29:31
Message: <3fa14a7b@news.povray.org>
In article <3fa141f5$1@news.povray.org> , "Scott Gammans"
This simply is incorrect, but I know you don't care that I tell you.  Still,
incorrect information posted tends to stick in new users' minds longer than
correct information, so if nobody says it isn't so they will take it as
true...
    Thorsten
e-mail: tho### [at] trfde
Date: 30 Oct 2003 12:32:02
Message: <s0u771-5vp.ln1@triton.imagico.de>
> try here first.
Does it crash always after 63 frames even if you render a different
subset or even identical frames?  Try removing all uses of MegaPOV
features and render with official POV.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 30 Oct 2003 12:46:43
Message: <1g3nnmc.1xb0c5u1p8fg34N%yvos.s@gmx.net>
I can not give you an answer right now but I will start such an
animation an see what it does.
Is it something you can repeat or is it with one specific scene?
 If so, send that scene to me if that is possible for you.
Even if that were to be true (but it is not) you would not notice this
so soon on OS X.
You would need a scene which uses a *huge* amount of memory.
If you want to verify this you can run top in the terminal and watch
memory consumption for MegaPOV.
Command line on a Mac..... Are you serious ? ;-) :-)
If you wait for MegaPOV 1.1 you will be able to compile such a version
without any problems.
There are indeed quite a few people interested for such a version.
> Any suggestions??
More info? First thing to know is if this happens with a simple scene as
well.
That is always the first step.
Yvo
MacMegaPOV at:
http://users.skynet.be/smellenbergh
E-mail: yvo### [at] gmxnet
Date: 30 Oct 2003 13:20:51
Message: <1g3npev.ecvzfx1qaqy2aN%yvos.s@gmx.net>
Your animation counts 750 frames but you start with frame 638 and end
with 1388?
Please what have you entered in 'Initial Frame', 'Final Frame', 'Subset
Start' and 'Subset end' on the clock panel of the prefrences dialog?
Yvo
MacMegaPOV at:
Date: 30 Oct 2003 14:18:13
Message: <3fa163f5$1@news.povray.org>
638
1388
638
1388
"Yvo Smellenbergh" <yvo### [at] gmxnet> wrote in message
news:1g3npev.ecvzfx1qaqy2aN%yvos.s@gmx.net...
and
start
> with 1388?
> Yvo
> MacMegaPOV at:
Date: 30 Oct 2003 14:38:12
Message: <3fa168a4$1@news.povray.org>
*sigh* No, Thorsten, I do care what you have to say--but let's not get into
another argument about your manner of online writing.
I may be wrong about what is causing the problem, but POV-Ray for Windows
*does* have some sort of memory allocation problem that, after a few dozen
frames, causes it to stop rendering with a memory allocation error because
it can't allocate any more memory to open one of the TGA bump map files in
my scene. I know it's not the most accurate measurement tool, but the
Windows XP Task Manager clearly shows POV-Ray consuming more and more memory
as each frame is rendered, until all physical memory is consumed and it
starts thrashing the virtual memory. When that also runs out, POV-Ray stops.
So it's either POV-Ray not releasing allocated memory after a frame is
completed, or it's a memory leak, or a problem with the way Windows XP
allocates memory to programs, or a little of all the above. And with a scene
file that takes nearly 600 MB of memory to render for one frame, it doesn't
take long for my workstation to grind to a halt when running a long
animation sequence totally from within POV-Ray.
To get around this problem--WHATEVER the reason for it--I figured out a long
time ago that if I execute POV-Ray from a batch file and render one frame at
a time from the command line, e.g....
pvengine +Iscene.pov +H384 +W512 +Q9 +KFI638 +KFF638 +Oscene_.png -D /NR
/EXIT
pvengine +Iscene.pov +H384 +W512 +Q9 +KFI639 +KFF639 +Oscene_.png -D /NR
/EXIT
pvengine +Iscene.pov +H384 +W512 +Q9 +KFI640 +KFF640 +Oscene_.png -D /NR
/EXIT
...POV-Ray always behaves perfectly and never is unable to parse a scene
file because it can't allocate the memory. The key is telling POV-Ray to
/EXIT after rendering one frame--that seems to force it to release any
memory it allocated back to Windows.
You will never be able to convince me that there is no problem with
long-running, memory-intensive animation jobs in POV-Ray, Thorsten, because
I've seen it happen.
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3fa14a7b@news.povray.org...
doesn't
Still,
than
> true...
>     Thorsten
Date: 30 Oct 2003 14:41:48
Message: <3fa1697c$1@news.povray.org>
By the way, my newsreader inserted carriage return/line feeds in my example
command line script below where I didn't want them... the script looks sorta
like this:
pvengine +Iscene.pov +H384 ... +KFI638 +KFF638 +Oscene_.png -D /NR /EXIT
pvengine +Iscene.pov +H384 ... +KFI639 +KFF639 +Oscene_.png -D /NR /EXIT
pvengine +Iscene.pov +H384 ... +KFI640 +KFF640 +Oscene_.png -D /NR /EXIT
"Scott Gammans" <dee### [at] yahoocom> wrote in message
news:3fa168a4$1@news.povray.org...
into
memory
stops.
scene
doesn't
long
at
> /EXIT
> /EXIT
> /EXIT
because
(unpatched)
> doesn't
> Still,
> than
> > true...
> >     Thorsten
Date: 30 Oct 2003 14:50:57
Message: <3fa16ba1$1@news.povray.org>
Yes, it's any 63 frames of the same basic scene file, and with the exception
of Finder and whatever services are started when OS X boots up, I'm not
running any other processes.
I'm not using any MegaPOV features at all; the only reason I'm using
MacMegaPOV is the unavailability of POV-Ray for Macintosh on OS X 10.2.x.
This is a straight, standard POV-Ray *.POV file that includes seven *.INC
files and loads about 45 MB of *.PNG and *.TGA image, bump and texture map
files. Total memory used for each frame is about 550 MB.
thanks...
news:s0u### [at] tritonimagicode...
I'll
> > try here first.
and
start
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
