POV-Ray : Newsgroups : povray.unofficial.patches : Some ideas about SDL enhancements Server Time
17 May 2026 01:03:01 EDT (-0400)
  Some ideas about SDL enhancements (Message 1 to 10 of 37)
Subject: Some ideas about SDL enhancements
Date: 31 Mar 2003 15:02:17
Message: <3e889ec9@news.povray.org>
This is a really old subject, discussed a thousand times already, but
anyways, I thought about writing some of the ideas that have occurred to
me about what new features in the POV-Ray SDL would be great.
  Some of the ideas are old, but I thought that I would make a complete
list of what I think.
  I'm posting this to this group in case some patch maker could get some
inspiration for a new feature (I could try to implement these myself, but
I really don't have the time now...).
  These are features which should not be too difficult to implement.
  * Assigment shortcut operators.
  That is, +=, -=, *= and /=.
  The advantage is clear with statements like:
#declare Array[Index1*a*b+1][Index2] += 2;
  * #do - #until
  The advantage of this is that the loop condition is checked after the
loop body has been parsed and not before. This is useful for example in
sitations like this:
#do
  #declare Point = <rand(S),rand(S),rand(S)>*2-1;
#until(vlength(Point) <= 1)
  * Array operators for the string type.
  A string could be accessed as an array. For example:
#declare I = MyString[a];
  would be completely equivalent to:
#declare I = asc(substr(MyString, a, 1));
  However, it would not only be a shortcut since this would work as well:
#declare MyString[a] = 65;
  * Float literals written as ascii chars (as in C).
  This way the above could be written as:
#declare MyString[a] = 'A';
  * Binary file reading and writing.
  A read-command which reads (the specified amount of) raw binary data into
a string identifier. In the same way it should be possible to directly
write a string as raw data to a file (IIRC currently this is not possible
because of a bug which causes the value 0 to not be written).
  Also a seeking command would be good.
  * Handling bitmaps with a 2-dimensional color array.
  A function should be added which reads the given image file into a given
identifier, which is created as a 2-dimensional array of colors (exactly
as if created by #declare Image = array[Width][Height];).
  Also every item in POV-Ray which accepts an image should also accept
such array of colors.
  (Note: Functions for reading the image dimensions are not necessary
because such function already exists: dimension_size().)
  * Reading members of the global_settings and camera data with the
dot operator.
  For example, you could do this:
#if(global_settings.max_trace_level < 15)
  global_settings { max_trace_level 15 }
  Sub-blocks inside the global_settings block could be accessed in the
same way, eg:
global_settings.radiosity.error_bound
  * Some way of making dynamic data containers.
  This is a whole lot more complicated issue.
  One way of allowing this is to add support for user-defined abstract
types, for example some type of 'struct' construct in such way that you
can make instantiations of this type. This also requires having a reference
type identifier, which can point to such instantiation.
  This way it would be possible to make, for example, a linked list.
  Members of such struct would be accessed with the dot operator.
Subject: Re: Some ideas about SDL enhancements
Date: 31 Mar 2003 19:43:49
Message: <cjameshuff-B58952.19442331032003@netplex.aussie.org>
In article <3e889ec9@news.povray.org>, Warp <war### [at] tagpovrayorg>
Similarly, I'd like a #set directive, which modifies existing variables
but can not make new ones. I made a patch for this, which is included in
MegaPOV IIRC...it reduces typing, makes code clearer, and catches some
errors sooner.
This loops infinitely:
#declare Loops = 10;
#while(Loops > 0)
    #declare loops = Loops - 1;
And this produces an error:
#while(Loops > 0)
    #set loops = Loops - 1;
What I'd really like is for modification to be done without any keyword,
as it is in most other languages...for example, the Sapphire equivalent:
def j: 10;
while(j > 0)
    j -= 1;
>   * #do - #until
Why do...until() instead of do...while()? Similar constructs, but
do...while() seems more common.
Anyway, might as well add for loops of some sort while you are at it.
And splines. Unify splines with the ones used by shapes like lathe and
prism too.
Less useful, but no real argument against it.
Agreed. I'm not really happy with POV's file handling. A more complete
implementation would allow for importation of various model formats to
be done from a POV script...DXF import could be done as a standard
include file. It would go a long way toward reducing the need for
plugins.
Hmm...not very memory efficient, and doesn't hook into POV's existing
internal image handling. A separate data type might be better.
> dot operator.
These could both be handled with the same mechanism...things like
global_settings would be an object with things like max_trace_level as
members.
I've posted messages about this before, but a prototype based object
system would fit the POV language with few changes. "object" would
become a basic, empty object (in the object oriented programming sense),
and all the shapes would descend from it. Prototype OOP fits how complex
shapes are already constructed, and is simpler than class based systems.
As for references...perhaps a link directive of some sort.
Wedging all this into the POV syntax is kind of ugly though. It would be
cleaner to just start over from scratch. This would allow a lot of crud
to be stripped out of the language, and let interpretation be moved over
to a virtual machine, for a great increase in speed for complex
computations like tree generators or particle simulations. I propose a
simple to use language for the main scene, and a more limited, very
tightly optimized version for things like isosurfaces and shaders.
http://tag.povray.org/
Date: 1 Apr 2003 00:36:06
Message: <u39i8vo8lhi0v6u1uv340li8r0u51b4r4q@4ax.com>
On Mon, 31 Mar 2003 19:44:23 -0500, Christopher James Huff
> And splines.
http://megapov.inetart.net/manual/expressions.html#spline_like_array
ABX
Date: 1 Apr 2003 00:44:58
Message: <o89i8v4q06esddmrkv408irom77684tj0c@4ax.com>
>  * #do - #until
>  * Reading members of the global_settings and camera data with the dot operator.
Interesting and some alredy in "to do". But POV is not only for sigs ;)
ABX
Date: 1 Apr 2003 05:43:30
Message: <3e896d52@news.povray.org>
Christopher James Huff <cja### [at] earthlinknet> wrote:
>>   * #do - #until
  Because #until is unambiguous to the parser.
  When the POV-Ray parser sees the #do and a bit forward it sees a #while,
it has no way of knowing whether the #while is ending the #do or whether
it's starting a #while-loop.
  Using #until completely disambiguates this.
  You are right. There could be a new "bitmap" type which is stored in
memory more efficiently than an 2-dimensional array of colors, but which
looks from the point of view of the SDL like such array. (The only difference
would be that if you want to create an identifier of type "bitmap" by other
means than using the image reasing function, there must be a special syntax
for that.)
Date: 1 Apr 2003 08:50:21
Message: <3E89991C.FF17D0A4@gmx.de>
I'd use the pascal version:
#repeat
#until ()
this probably would avoid confusion when people simply assume it would
work like in C when they see a #do.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 1 Apr 2003 09:17:42
Message: <cjameshuff-76E0D7.09181601042003@netplex.aussie.org>
In article <3e896d52@news.povray.org>, Warp <war### [at] tagpovrayorg>
Of course...without block delimiters, this is necessary.
> for that.)
Something like this?
new_image(X_SIZE, Y_SIZE, INIT_FUNCTION)
open_image(X_SIZE, Y_SIZE, TYPE, FILE_NAME)
or this:
image {X_SIZE, Y_SIZE, INIT_FUNCTION | TYPE FILE_NAME}
Some other ideas:
Declarable warps, and make "warp {}" behave more like "transform {}",
able to hold multiple warps. There are some incompletely implemented
features in warps as well.
Declarable patterns. We really have this already, it is just necessary
to tweak the function pattern syntax.
Universal "blend", replacing all the *_map keywords. Maybe combine with
splines.
Integrate textures, patterns, splines, warps, color_maps, etc with
functions. In the process of happening now.
Separate transparency:
    pigment {...}
    transparency FILTER_AMT
    transparency FILTER_AMT, TRANSM_AMT
    transparency {
        filter FILTER_AMT
        transmit TRANSM_AMT
        blur {...}
The *_AMT could be constants or functions.
Extend waveforms. spline_wave, function, move phase and frequency into
"waveform" block. Default waveforms would be the same, but when a
waveform block is specified, use unclipped pattern values as input.
finish_map, or let finish values be specified with functions.
Roll "sky_sphere" into "background". With the present name, too many
people mistake it for an object.
RGBE file format support. Other high dynamic range formats.
axis_rotate, stretch transforms. axis_rotate is obvious, stretch is like
scale, but along a specific axis. (axial_scale?)
I've mentioned my ideas for noise generators before...basically, they
would be ordinary functions.
Dump the # character for anything not a "preprocessor" command.
I have a lot of other ideas, but I'll stop there.
Date: 1 Apr 2003 13:25:43
Message: <3e89d9a7@news.povray.org>
  Another handy feature for "background" would be support for a pigment
(instead of the current support for a single color).
  The pigment could be evaluated, for example, at <0,0,0> in the lower
left pixel of the image and <1,1,0> at the upper right pixel. The
functionality would be pretty similar to using the alpha channel (+ua),
but instead of blending to transparent, the image would blend to the
given pigment.
  One of the most useful applications for this would be to specify a bitmap
for the background (which is often requested by people).
Date: 1 Apr 2003 20:48:06
Message: <3E8A4261.99A6515C@pacbell.net>
> given pigment.
How would you contrain it to the view point of the camera?
Ken Tyler
Date: 1 Apr 2003 21:58:19
Message: <cjameshuff-E611E2.21585501042003@netplex.aussie.org>
In article <3e89d9a7@news.povray.org>, Warp <war### [at] tagpovrayorg>
This would be handled by something else. Your definition only works for
camera rays, it is meaningless for reflected or refracted rays. I can
think of two (non-exclusive) possibilities: a post-process feature, and
a programmable camera feature which lets you specify every detail of the
camera...basically coding the pixel level tracing in POV code. Some
built-in functions would be made available to make new cameras based on
existing ones. In this case, you would use one of these functions and a
pigment function to determine the final pixel color.
