POV-Ray : Newsgroups : povray.unofficial.patches : Some ideas about SDL enhancements Server Time
27 Jul 2026 00:51:34 EDT (-0400)
  Some ideas about SDL enhancements (Message 18 to 27 of 37)
Subject: Re: Some ideas about SDL enhancements
Date: 3 Apr 2003 02:57:27
Message: <3e8be967@news.povray.org>
> I hope you like this new post_processing.
It seems promising ! Beside those f_output_ red green blue and alpha , what
other informations will be available (such as f_output_depth,
f_output_normal ..etc) ?
M
Date: 3 Apr 2003 03:08:27
Message: <gbqn8v4293sd4i439efa48a5pi3cmu0n92@4ax.com>
I duplicated chanels available in previous implementation of post_processing but
I have no idea whether they were all really used.
#declare f_output_red=function{internal(...)};
#declare f_output_green=function{internal(...)};
#declare f_output_blue=function{internal(...)};
#declare f_output_alpha=function{internal(...)};
#declare f_output_ipoint_x=function{internal(...)};
#declare f_output_ipoint_y=function{internal(...)};
#declare f_output_ipoint_z=function{internal(...)};
#declare f_output_inormal_x=function{internal(...)};
#declare f_output_inormal_y=function{internal(...)};
#declare f_output_inormal_z=function{internal(...)};
#declare f_output_pnormal_x=function{internal(...)};
#declare f_output_pnormal_y=function{internal(...)};
#declare f_output_pnormal_z=function{internal(...)};
#declare f_output_depth=function{internal(...)};
#declare f_output_u=function{internal(...)};
#declare f_output_v=function{internal(...)};
#declare f_pp_red=function{internal(...)};
#declare f_pp_green=function{internal(...)};
#declare f_pp_blue=function{internal(...)};
#declare f_pp_alpha=function{internal(...)};
But its definition is controlled by macros becouse it has to control caching
settings at the same time. In other words it is required to use pprocess.inc
include file just like functions.inc is dedicated for functions and mechsim.inc
is dedicated for mechanic simulations.
And of course usage of those functions before end of rendering cause error.
ABX
Date: 3 Apr 2003 03:34:42
Message: <3e8bf222$1@news.povray.org>
post_processing
ok.
I don't know if it'd be easy to implement but it could be a plus to know
which object is intersected to allow postprocessing on limited part of the
output. Something like
sphere { ... object_id 1 }
box { ... object_id 2 }
f_output_iobject_id : return 1 if intersection is on the sphere, 2 for the
box..
M
Date: 3 Apr 2003 04:03:18
Message: <kjsn8vsheg94v4teqvann96a859f9dg3tc@4ax.com>
On Thu, 3 Apr 2003 10:34:46 +0200, "Mael" <mae### [at] hotmailcom> wrote:
> ok.
> box..
This shouldn't be a problem but I wonder whether this could be already
workarounded with combination of depth output + _your_ projection (point) patch.
But of course when more objects is used 'id' is much more useful.
ABX
Date: 3 Apr 2003 04:19:42
Message: <gjun8v4lvqmrbtuihckcdvt9clrhn4je6d@4ax.com>
On Thu, 03 Apr 2003 09:08:14 +0200, ABX <abx### [at] abxartpl> wrote:
> But it will be also possible to do it in one pass. Instead of
> using internal function with output of rendering you could use new camera_view
> pigment type.
It should be noted that neither camera_view pigment nor post_process effects has
resolution like image_map. They are contignous from <0,0> to <1,1> but of course
values taken from rendering output are pixelized. In order to get camera_view
and effects "pixelized" (integer coordinates on image) we have to use (delivered
but simple) functions to convert. Having contignous coordinates seems much
better since now we can experiment with other antialiasing without patching
sources. In other words AA become part of post_processing instead of rendering
(and when you wish only part of image can be antialiased with only necessary
amount of rays traced).
ABX
Date: 3 Apr 2003 04:41:02
Message: <3e8c01ae$1@news.povray.org>
> Having contignous coordinates seems much better since now
> we can experiment with other antialiasing without patching sources.
In case you're looking for an example, what about trying a Mitchell and
Netravali filter which seems to be used in some renderers. It takes two
parameters blur/ringing
M
Date: 3 Apr 2003 04:51:41
Message: <nn0o8v8rb6e0iq6e99im97cbklofpka1lc@4ax.com>
I will leave it for future users because I already hardly find free time for
other opened tasks.
ABX
Date: 3 Apr 2003 10:08:23
Message: <cjameshuff-56E41F.10084803042003@netplex.aussie.org>
In article <a5jn8vs8n8u2929ajl86cmjtbhsamdm4fh@4ax.com>,
> (Are you sure you used correct math for this effect? I used weighting.)
I didn't, but I wasn't really concerned with that, since the syntax
itself is so rough.
define BasicCamera = camera {...usual camera stuff...}
function lerp(mn, mx, t) {return mn*t + mx*(1-t);}
special_camera {
    function trace_pixel(x, y) {
        //get the raw color of the pixel
        def pixelColor = BasicCamera.trace_pixel(x, y);
        //The result is a linear interpolation between the raw color
        //and the background, controlled by the alpha channel.
        def result = lerp(pixelColor, bkgndPigment(x/image_width,
y/image_height, 0), pixelColor.alpha);
        //That calculation modified alpha, so set it back to normal
        result.alpha = pixelColor.alpha;
        //do I need to explain?
        return result;
> That's possible and already tested with my post_process
> implementation (if you wish I can send sample image to p.b.i but its
> content seems obvious). It is possible with following script.
You seem to miss the point completely. I'm not talking about a post
process feature, isn't that obvious? This is a way to specify the camera
behavior at a very low level. That trace_pixel() function is called by
POV to trace every pixel.
>   #declare f_avg=function(v1,v2,w){(1-w)*v1+w*v2}; // average/weight
Eh...this is linear interpolation, not any kind of average. A common
name seems to be "lerp", though I don't know why, I usually use
something like linInterp. Anyway, there should be a function already
defined which does this...and it is unrelated to the subject of this
thread.
>   global_settings{
>     post_process{
>       // functions for four channels of output
>       function{f_avg(f_output_red(x,y)
>       ,back_Pig(x,y,0).x,f_output_alpha(x,y))}
>       function{f_avg(f_output_green(x,y),back_Pig(x,y,0).y,f_output_alpha(x,y)
>       function{f_avg(f_output_blue(x,y)
>       ,back_Pig(x,y,0).z,f_output_alpha(x,y))}
>       function{0}
>       save_file "with_background.png"
Sorry, but yuck. This is something that really needs vector functions,
and IMO should wait until they are available because it will need to be
redesigned and rewritten when they are here.
> Please note that you have more control in this implementation than in your
> script becouse you can define differend behaviour for each channel.
Wrong. My script only handled all channels at once because that was all
that was needed. It could easily handle channels separately.
Sorry, I don't. Great improvement in functionality, but extreme loss in
useability and efficiency. As I said, this really, really needs vector
functions. Using n-tuples of functions makes things far more complex
than necessary, and requires recomputing things that could be done once.
your "one-pass" version calls camb_Pig() 6 times and back_Pig() 3 times
per pixel, when once each would do. It also takes three functions whcih
have only 2 characters that change, when one function of about the same
length would do.
http://tag.povray.org/
Date: 3 Apr 2003 10:41:09
Message: <2dko8v0n8gi53kla520aca3au0ltl163a8@4ax.com>
On Thu, 03 Apr 2003 10:08:48 -0500, Christopher James Huff
No. You have described some functionality you dream about and I showed you how
it could be possible with my patch.
> >   global_settings{
> >     post_process{
> >       function{f_avg(f_output_red(x,y),back_Pig(x,y,0).x,f_output_alpha(x,y))}
> >       function{f_avg(f_output_green(x,y),back_Pig(x,y,0).y,f_output_alpha(x,y))}
> >       function{f_avg(f_output_blue(x,y),back_Pig(x,y,0).z,f_output_alpha(x,y))}
> >       function{0}
So do you want me to remove it from from MegaPOV 1.1 ? Do you prefer the
previous much more limited post_processing ? Or do you want to deliver vector
functions within a month ? I do not understand your intentions. I do not think
community want to wait years for post processing.
Can you deliver sources for inclusion in compilation ?
> length would do.
I completly understand your point here but the problem is that I do not have
vector functions available. And I can hardly see when they will be available.
But once the sources will be available you can improve it, I will be happy about
that.
ABX
Date: 3 Apr 2003 21:27:18
Message: <cjameshuff-2EE709.21275603042003@netplex.aussie.org>
In article <3e8bf222$1@news.povray.org>, "Mael" <mae### [at] hotmailcom>
> box..
A better idea might be some group label.
sphere { ... object_groups "mask A", "mask B" }
box { ... object_groups "high AA" }
And then have exclude_groups and include_groups options for the filters,
and/or filters that use the groups for other things like masks.
Hmm, a shorter possible alternate syntax:
sphere { ... }: "mask A", "mask B"
box { ... }: "high AA"
