POV-Ray : Newsgroups : povray.unofficial.patches : What is this HDRI thing? Server Time
27 Jul 2026 00:50:56 EDT (-0400)
  What is this HDRI thing? (Message 10 to 19 of 19)
<<< Previous 9 Messages Goto Initial 10 Messages
Subject: Re: What is this HDRI thing?
Date: 30 Dec 2002 13:07:18
Message: <chrishuff-CECC74.13025430122002@netplex.aussie.org>
In article <3e0e4bc9$2@news.povray.org>,
 "Gilles Tran" <git### [at] wanadoofr> wrote:
> Hmm, it looks that you haven't seen what's going on in p.b.i these days.
I'm on a modem connection, so I haven't kept caught up.
> Come on, give it a try, you'll see the advantage by yourself :-) (and I
> didn't believe it before I was given the patch). With HDR, we now have
> POV-Ray images virtually impossible to tell from actual photographs. See
> JRG's watch pic for instance.
But it is still less accurate than radiosity could be, as far as I can
tell. Why use a high dynamic range environment map instead of sampling
the actual environment? Speed? The ability to use real-world samples
instead of coding a background?
http://tag.povray.org/
Date: 30 Dec 2002 14:02:19
Message: <3e10983b@news.povray.org>
news: chr### [at] netplexaussieorg...
> tell.
Accuracy here is really a non-issue given the benefits...
Creating complex environments just to make them look nice in reflections and
project the right lights is rarely done :
for practical purposes, you just don't code the whole St Peters Basilic to
make a background (or you've really been raytracing too long...). There's a
example by Jaime who did a fake HDRI that way, but he used a complete scene
he had done before.
Speed is of course a big issue there too, since maps render very fast.
Also, natural light environments taken from photographs have a complexity
and a richness that is unmatched by usual 3D lighting, which is why people
go ooh and aah in front of these pics.
Now HDR isn't the solution to all lighting problems, and is only valuable in
certain circumstances, like "packshot" images (close ups of objects), but
then it is very good and extremly simple to set up using regular radiosity
parameters.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 30 Dec 2002 15:59:37
Message: <3e10b3b9@news.povray.org>
I'm starting to get interested...
Date: 30 Dec 2002 17:38:28
Message: <20021230233829.790f9b4d.jaimevives@ignorancia.org>
On Mon, 30 Dec 2002 13:02:54 -0500
  Yes, I think it's main purpouse is to create "augmented reality", but
it's good also for some other interesting things, as Gilles said.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 3 Jan 2003 13:15:54
Message: <3e15d35a$1@news.povray.org>
Can you tell me a bit more about the implementation here? For example, I
have rendered a few scenes using an HDR file and I would like to "mask out"
the actual original scene that the HDR file contains. Is there a way to do
that? If I put a plane or perhaps a wall in front of the "background" image
that appears in my scene, will that block out the light coming from the HDR
file? In other words, does the placement of the HDR file in the scene act
exactly like a light-emitting source? That's the part I don't quite get.
In effect, the probes I have used are of a campus, a beach, a kitchen, etc.
and you can always see some part of that original scene in the POV scene.
I'd like to "sample" the illumination of the HDR file but leave the kitchen
(or the beach) out of my own picture.
Thanks much,
Dennis
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3e10983b@news.povray.org...
> > tell.
and
a
scene
> he had done before.
in
> parameters.
> G.
> - POV-Ray and Poser computer images
> - Posters
Date: 3 Jan 2003 13:40:10
Message: <cjameshuff-E9F06E.13360603012003@netplex.aussie.org>
In article <3e10983b@news.povray.org>,
> > tell.
Well, since my interests are mainly in simulation, "better" == "more
accurate", "less accurate" == "worse". Speed is only part of my equation
for judging a simulation if the quality is a constant. Like glows or
fog, this is a compromise of quality vs. speed...it isn't "better than
radiosity", just faster without being a lot worse, like what ambient was
originally for.
Since you are an artist, you have different criteria about which is
"better".
Date: 3 Jan 2003 19:34:02
Message: <3e162bfa@news.povray.org>
3e15d35a$1@news.povray.org...
etc.
kitchen
Well, HDR maps really behave like any other map apart the high range stuff
(mildy reflective objects will show proper highlights, radiosity effects
will be more natural-looking etc.). I don't see a way to use only the
illumination but not the image itself, apart carefully setting up the scene
so that the HDR map doesn't show up in the frame and the non-HDR parts shown
are consistent with the rest of the lighting (the sort of trick we use with
regular maps). And no_image only works for the reflective parts, not the
illumination itself (just checked...). Possibly the best would be to use
Jaime's trick, setting up a complete scene and then using it as a map with
the "fake HDR" method(s) he describes.
G.
- Posters
Date: 3 Jan 2003 20:01:57
Message: <3e163285@news.povray.org>
Thank for your reply. Where is the message in which Jamie describes this
technique> I must have missed it.
But to be clear, if I put a plane on the Y axis beyond my object, I should
still be able to use the illumination from the map even if the map image is
not showing in my scene?
thanks again,
D.
news:3e162bfa@news.povray.org...
act
> etc.
scene.
> kitchen
scene
shown
with
> G.
> - Posters
Date: 3 Jan 2003 23:05:04
Message: <3E165D66.4010200@videotron.ca>
Program ended abnormally on 1/3/03 8:02 PM, Due to a catastrophic Dennis
Miller error:
I think it was in povray.binaries.images.
The parts of the HDR map behind the camera, yes.
The parts hidden by the plane, no.
> thanks again,
> D.
Date: 4 Jan 2003 06:19:12
Message: <20030104121910.2ef8c47b.jaimevives@ignorancia.org>
On Fri, 3 Jan 2003 20:02:03 -0500
> this technique> I must have missed it.
 The basic trick consists on using a surrounding sphere with a
multilayer texture like this one (more or less, I'm still
experimenting with it):
// "back-lighting" layer
texture{
 pigment{
  image_map{
   jpeg "test.jpg"
   map_type 1
   interpolate 2
 finish{
  diffuse 0
  ambient light_ambient
// 254 layers to fake the HDR behavoir
texture{
 pigment{
  image_map{
   gif "test.gif"  // grayscale version of the original map
   map_type 1
   #while (il<254)
//    transmit 255-il max_intensity/(pow(il+1,2))
    filter 255-il max_intensity/(pow(il+1,2))
    #local il=il+1;
 finish{
  diffuse 0
  ambient 0
// final layer to hide the grayscale maps
texture{
 pigment{
  image_map{
   jpeg "test.jpg"
   map_type 1
   interpolate 2
//   filter all .5
   filter all .9
 finish{
  diffuse 1
  ambient 1
  The problem is that each map needs diferent settings that must be
found by trial and error. The advantage is that it can work with any
image where the brightness levels are somewhat proportional to real
luminance. Aditionally, you need a program to convert the image to a
grayscale one with ordered palette (255=white, 0=black). I've done it
with The Gimp, simply saving the grayscale version as gif.
