POV-Ray : Newsgroups : povray.unofficial.patches : pvmpovray35 release Server Time
22 Mar 2026 11:19:40 EDT (-0400)
  pvmpovray35 release (Message 1 to 10 of 14)
Subject: pvmpovray35 release
Date: 11 Dec 2002 00:55:17
Message: <3df6d345@news.povray.org>
Hi all, for those that are interested I have made available my own PVM
patch for POV-Ray3.5 and may (or may not) provide support for it until
the sourceforge version is released. It is only designed to work with the
3.50c Unix source code, but I would be interested to here if anyone
successfully applies the patch to other distributions...
This is basically the previous pvmpov3.1g patch modified and updated for
3.50c, with similar commandline support. I have documented many of the
source code changes in the archive, and the release notes should ensure
hassle free installation. If you are familiar with pvmpov, you should
have no problems (excepting my own bugs...) getting this up and running
(if not, get the pvmpov archive if only for the documentation). If you
don't know what PVM is, then this is of no use to you...
http://www.karekare.co.nz/matthewg/povrayindex.html
(! 240kb+ of images on page !)
Enjoy,
Matthew Grove.
Subject: Re: pvmpovray35 release
Date: 11 Dec 2002 05:14:04
Message: <3df70fec@news.povray.org>
Since I don't have anything to do with the maintenance of these Sparc
computers at work, I have no idea whether PVM is installed here or not.
Is there some way of looking whether this is so or not?
  When trying to compile the pvm-patched version, the compiler chokes on:
#include "pvm3.h"
and says that file doesn't exist. Does this mean PVM is not installed here?
(But shouldn't it be '#include <pvm3.h>' if it's supposed to be a system-wide
library and not a file in the current directory?)
  By the way, I wouldn't like to start a sermon about programming guidelines,
but I noticed that you have lots of stuff in pvm.h which are used only
in pvm.cpp and are clearly just "configuring" it.
  In C and C++ a header file is supposed to be a definition of the
*public interface* of that module. It's not a configuration file for the
module or anything like that.
  A public interface should be minimal and contain only those things which
are purposed to be used by other modules. Everything that is only an
internal implementation detail of pcm.cpp and not even supposed to be used
anywhere else, should go inside pvm.cpp, nowhere else. (If they are things
that can be configured, you can put them at the very beginning of pvm.cpp
for easy access.)
  For some reason many programmers have the odd idea that a header file is
a file where you declare all types and constants, regardless of where they
are used. This is certainly not the purpose of a header file.
  Sorry, couldn't help myself... :)
Date: 11 Dec 2002 07:29:58
Message: <3df72fc5@news.povray.org>
I successfully installed PVM for myself and compiled pvmpovray35.
  Using 12 sparcs benchmark.pov (with the suggested options) rendered in 34
minutes. Not bad.
Date: 11 Dec 2002 20:36:51
Message: <3df7e833@news.povray.org>
Peopla at university taught me this very thing: put types and constants in
header file.
Date: 12 Dec 2002 00:43:16
Message: <3df821f4@news.povray.org>
>   34
> minutes. Not bad.
Nice to hear that it actually works for someone else :-)
It would be nice to see more parallel benchmark results on
povbench/tabsnet, so I encourage all to post their results.
Matthew.
Date: 12 Dec 2002 00:53:53
Message: <3df82471@news.povray.org>
>   guidelines,
>   is
> they are used. This is certainly not the purpose of a header file.
I didn't write the original, I just did enough to get the thing to work
with 3.5. Quite frankly, POV-Ray and the PVM patch have enough holes to
drive a fairly large truck through.
However, I do agree that in theory, only 'public' stuff should go in the
header files, but sometimes it is not always that simple...
Matthew.
Date: 12 Dec 2002 04:35:22
Message: <3df8585a$1@news.povray.org>
In article <3df7e833@news.povray.org> , "Apache"
> header file.
Which is completely wrong:  Only put types and constants used in more than
one source file into a header file.  Otherwise you just clutter the
namespace, regardless of the language being used.
    Thorsten
e-mail: tho### [at] trfde
Date: 12 Dec 2002 04:47:06
Message: <3df85b1a$1@news.povray.org>
Agreed! I had some trouble with those people more than once about this kind
of things.
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3df8585a$1@news.povray.org...
in
> > header file.
>     Thorsten
Date: 12 Dec 2002 05:50:34
Message: <3df869f9@news.povray.org>
> header file.
  Then change university. :)
Date: 12 Dec 2002 08:30:44
Message: <3df88f84@news.povray.org>
> minutes. Not bad.
  With 29 sparcs benchmark.pov rendered in 21 minutes.
  One problem is that it takes almost 6 minutes to parse benchmark.pov
regardless of the amount of computers, so the time will never go under
that no matter how many sparcs I use (except if I use faster sparcs,
of course).
