POV-Ray : Newsgroups : povray.unofficial.patches : FEATURE REQUEST: visibility level flag. Server Time
27 Jul 2026 02:29:18 EDT (-0400)
  FEATURE REQUEST: visibility level flag. (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: FEATURE REQUEST: visibility level flag.
Date: 23 Dec 2001 13:53:22
Message: <3c262822$1@news.povray.org>
L'Harmonieux Forgeron wrote:
> 1. Learn to quote, put your answer after the text you are responding to.
> Thanks; it make it easier to build the dialogue.
That's what I usually do.
> 2. Nobody, but from your description, no_image and no_reflection would
have been
> possible weaker forms, hence removing them might have helped to simplify
the SDL.
They could be useful shortcuts.
> 2. This aspect was not in your initial query. You did not even mention
radiosity.
Which means you didn't pay attention to my first post (radiosity is
mentioned there).
>    It's look like you're asking something while wanting something else.
>    (asking for new feature, while wanting radiosity evolution/debugging)
That was just an example. I thought of the most general feature which might
include what I was looking for.
> 3. As I had done the debugging of no_reflection and no_image, it would not
cost you
> too much. You would probably increase each object with another unsigned
integer
> (short ?) and might have to surcharge the NO_IMAGE and NO_REFLECTION
flags.
Let me have my C exam and I will give it a try.
> BUT:
>  - I do not see the interest of it (as exposed in your initial request)
YHO
>  - I'm personaly against it
Morally?
>  - it is too late for 3.5, but too soon for doing your own patch
There's no hurry. And nobody talked about 3.5. This is
povray.unofficial.patches, isn't it?
>  - Last, you came to that solution because you had a problem with
radiosity...
>    Fixing the wheels won't put gazoline in the tank!
As I said, I looked for the most general solution.
Jonathan.
Date: 23 Dec 2001 13:57:43
Message: <3c262927$1@news.povray.org>
I personally use two copies of the light bulb: one with not too high ambient
and no_reflection. The other one with high ambient (10 or up) and the
no_image flag.
That's what I used for the Cornell box scenes posted in p.b-i.
Jonathan.
"Kari Kivisalo" <ray### [at] engineercom> ha scritto nel messaggio
news:3C2622C4.2B630268@engineer.com...
> JRG wrote:
> > no_radiosity
> I would use it for realistic light sources.
> If pure ambient sources are used this is not a problem.
> When light sources are used the ambient object still has
> to be there for reflections and in direct view but not
> emit light.
> _____________
> Kari Kivisalo
Date: 23 Dec 2001 15:42:51
Message: <3c2641cb@news.povray.org>
In article <3c2515a3@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
> The problem arises if
> you're using radiosity, since the *no_image* wall won't *participate* to the
> radiosity calculations, which is not what I want.
Well, this is exactly like in the real world: If something is invisible you
can't see it.  (Of course, no_reflection isn't natural either.)
However, your idea of a "visibility_level flag" is fundamentally flawed.
First of all, you say it is a flag but what you say it should do has nothing
to do with a flag.  More important, what you want it to do is actually three
(or more?) things in one.  But how would you combine effects?  You soon have
to start assigning arbitrary numbers to effects, which makes it unusable
without a table that maps effect combinations to numbers.
And as for your "if n> max_trace_level-1 the object wouldn't be visible at
all" idea, well, how do you define the maximum level?  What intersections
would count and how would one define which intersections count?  Remember
that an object can have any from 0 to and infinite number of intersections.
So depending on the viewpoint you could have ten intersections with one
object while from another you only have two.
In no way would make the feature you suggest any sense.
A much more practical solution to your problem would be to design your scene
so that the camera fits properly "inside".  After all, the effect you want
is physically impossible a camera looking through a invisible wall that is
visible in indirect reflections.  Maybe you should simply consider a
different camera type and some creativity of what you have got rather than
thinking of the most complicated possible solution to such a simple problem
as perspective camera distortion effects...
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Dec 2001 19:06:24
Message: <3c267180@news.povray.org>
Aw, come on it was just an example.
Lightflow has got it for example:
string "visibility", int depth
Specify the tracing depth at which the objects made from this material start
to be visible.
This is useful to make objects appear only inside reflections, for example
to create rich environments though mantaining a black background.
The default value is 0.
To me it does make sense. Look at the Lightflow's cornell box posted to
p.b-i. You wouldn't say it's physically impossible, but the camera is just
two units outside the actual box. And I won't mention how many times I would
have wanted to render a nice radiosity scene with a black background (using
a no_image sky_sphere).
Really, I thought about this as a more general and simple way to resolve
many different problems. One single keyword which would include so many
different effects. I don't need it just now for an actual scene.
What I'd need is truly the _no_image_ objects to participate to radiosity
calculations. Of course this may be an undesirable effect in some
circumstances. Thus I think a no_radiosity flag would be more logical (as
long as no_image doesn't directly imply no_radiosity).
But you can forget what I asked for, because I somehow dislike the tone of
some responses here.
Jonathan.
Date: 24 Dec 2001 00:58:00
Message: <3c26c3e8@news.povray.org>
JRG <jrg### [at] hotmailcom> wrote in message news:3c267180@news.povray.org...
start
> to be visible.
would
(using
> Jonathan.
My  $0.02: It is a good idea, I could use it in a lot of scenes. the tones
of
 some responses were a little off, but thats life.
Gary
Date: 24 Dec 2001 15:21:13
Message: <chrishuff-6D4B0A.15212424122001@netplex.aussie.org>
In article <3c2515a3@news.povray.org>, "JRG" <jrg### [at] hotmailcom>
wrote:
I think the most flexible way would be to have some kind of
"interaction_group" that covers lights (including highlights),
reflection, refraction, etc...basically "this object only reflects this
group of objects, and only has highlights from this group of lights". I
think radiosity would still have to be a separate flag.
However, this would probably be too complex to use...it would most
likely be simpler to use a shader of some sort.
Date: 25 Dec 2001 06:57:06
Message: <3c286992@news.povray.org>
In article <3c267180@news.povray.org> , "JRG" <jrg### [at] hotmailcom> wrote:
I somehow do not believe the original Cornell box was designed this way...
I just think you are taking the wrong approach to the problem with your
scene.  Instead of thinking for hours how POV-Ry could be changed, try to go
with what you have and you will get amazing results and maybe find a
creative way without someone else adding a feature to POV-Ray for you.
Somehow what you suggest is like suggesting to add drills to cars so you can
drill for oil when you run out of fuel.  Sure you could do it, but it might
not be the most practical solution :-)
    Thorsten
Date: 25 Dec 2001 07:39:09
Message: <3c28736c@news.povray.org>
> emit light.
 I've found a half-workaround for this problem, if you are not going to use
media interacting radiosity. You can put a very intense emission media
inside your ambient object, with a clear pigment, and of course mantain
media off on the radiosity block. This gives a nice solid luminous object
for reflections/refraction withouth emitting any light. It works nicely for
me, because I will surely never use "media on" with radiosity.
Jaime Vives Piqueres
http://www.ignorancia.org
Date: 25 Dec 2001 15:52:17
Message: <3C28E2DA.64614B6@free.fr>
> radiosity.
> mentioned there).
Ok, my fault.
> > BUT:
> YHO
Exactly, Even the no_* are still rarely used/needed.
And the scene you described did not convince me for the suggested solution.
> Morally?
Sort of.
Your suggestion needs to modify the very heart of the engine.
patches from safe/simple to unsafe/complex are in order (IMNSHO):
 - new pattern
 - new warp
 - new object
 - alternative behaviour/adding flags
So, when you asked directly for the most dangerous, it triggered a red flag ;-)
> radiosity...
Well, I would said that you jumped to the conclusion :-)
Moreover, the problem of the "spy-mirror" (one side see the other, whereas
the other see only itself) was recently discussed (even if I cannot here find the
reference to it) and is very similar to your exposed problem.
You may have wanted to discuss your problem in newsgroups, before requesting
your solution... there is usually more than one way to solve a problem.
BTW, have a look in p.b.i, I have a proposition for your problem.
It's bigger than the needed code change for your solution, because it needs a
new object, but I consider it to be safer because it won't touch any shared code.
Non Sine Numine
http://grimbert.cjb.net/
Etiquette is for those with no breeding;
fashion for those with no taste.
Date: 2 Jan 2002 18:43:27
Message: <3c339b1f$1@news.povray.org>
can
*lol*
sigged ...
"Somehow what you suggest is like suggesting to add drills \ jan### [at] lzernet
to cars so you can drill for oil when you run out of fuel.  \
Sure you could do it, but it might not be the most practical >          Jan
solution." [Thorsten Froehlich in p.u.p]                    /        Walzer
