POV-Ray : Newsgroups : povray.unofficial.patches : UV problems Server Time
11 Jul 2026 19:54:12 EDT (-0400)
  UV problems (Message 1 to 10 of 11)
Subject: UV problems
Date: 12 Aug 2001 06:11:00
Message: <3b765634$1@news.povray.org>
When I try to render a Poser2POV cenverted scene in MegaPov I get this error
message: "Mesh normal index out of range."
Where's the problem?
Subject: Re: UV problems
Date: 12 Aug 2001 07:17:13
Message: <3b7665b8@news.povray.org>
Artis <art### [at] aaaapollolv> wrote:
: When I try to render a Poser2POV cenverted scene in MegaPov I get this error
: message: "Mesh normal index out of range."
: Where's the problem?
  Isn't the error message clear enough?
Date: 12 Aug 2001 07:22:52
Message: <3b76670c$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3b7665b8@news.povray.org...
error
And what can I do to correct it?
Date: 12 Aug 2001 07:24:02
Message: <3b766751@news.povray.org>
: And what can I do to correct it?
  Ask the author of Poser2POV to fix his program?
Date: 12 Aug 2001 07:57:18
Message: <3B766E72.E1FB55AF@taconic.net>
I had to slog my way through this same problem a short while ago. I not
sure of the cause but I suspect it may have to do with whether or not
the origional model was supplied with normals. (In my case I had a
Hammapatch model that I wanted to UV map.)
My solution was to run the model through Crossroads 3D and have the
normals calculated there before going on.
I don't know though if this solution is applicable to you or not. Good
luck.
Abe
Date: 12 Aug 2001 08:19:17
Message: <3b767445$1@news.povray.org>
I am using a hamapatch model too, but Crossroads 3D doesn't helps.
Date: 12 Aug 2001 08:20:42
Message: <3b76749a$1@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3b766751@news.povray.org...
I'm already waiting for the answere.
Date: 12 Aug 2001 10:40:16
Message: <3B7694A5.9D9E7A1C@taconic.net>
Did you try applying smooth normals in Crossroads 3D (you'll need to
_Select All_ and then choose _Smooth_ from the menu after right-clicking
on the model window).
Abe
Date: 12 Aug 2001 12:50:05
Message: <3B76B39B.450674EB@inapg.inra.fr>
Try another converter, such as 3DWin (http://www.stmuc.com/thbaier/) or
Poseray (http://people.tamu.edu/~sfg2113/poserayhelp.htm)
G.
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Date: 13 Aug 2001 06:09:19
Message: <3b77a74f@news.povray.org>
That was it, thank you a lot.
Abe <bul### [at] taconicnet> wrote in message
news:3B7694A5.9D9E7A1C@taconic.net...
> Abe
not
