POV-Ray : Newsgroups : povray.unofficial.patches : Shadowless is hotspot-less - a bug??? Server Time
15 Jun 2026 17:09:42 EDT (-0400)
  Shadowless is hotspot-less - a bug??? (Message 1 to 3 of 3)
Subject: Shadowless is hotspot-less - a bug???
Date: 12 Jun 2001 17:06:52
Message: <3b26846c$1@news.povray.org>
Hi there,
i've tested some texture options and metioned that all my objects has no
hotspots and they are not shaded (looking 2D...flat...). I've tested this
with spheres.
After removing the "shadowless" keyword from my light_source all objects are
shaded and have hot spots. First i was working in mp 0.7 and tested it also
with 3.1g, but with the same result.
Is this a bug??  When i turn on shadows in the light definition and shut off
the shadow in the objects ("no_shadow" keyword) they are shaded and have
hotspots!!!
But that is not the result i expect, because i'm using some lights to make
hotspots on a object (lit this) but only one or two lights should have
shadows on.
Paul
Subject: Re: Shadowless is hotspot-less - a bug???
Date: 12 Jun 2001 17:54:29
Message: <slrn9id3sn.amp.ron.parker@fwi.com>
>with spheres.
It's exactly as you describe, but believe it or not it was by design.  This
has been covered before somewhere around here.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
Date: 14 Jun 2001 15:41:43
Message: <m2ehits3vo09t5n39jvf9tmn9b3kdtq74p@4ax.com>
On 12 Jun 2001 17:54:29 -0400, ron### [at] povrayorg (Ron Parker)
>>with spheres.
To shed more light on the subject, shadowless lights were designed
with the thought of fill lights in the head of whoever introduced
them. This can easily be seen in the POV source code. Hotspots, or
highlights, given off by fill lights are usually unwanted, so the
developer made shadowless lights highlightless as well. This has been
discussed before and has a workaround, namely the no_shadow object
flag.
Peter Popov ICQ : 15002700
