POV-Ray : Newsgroups : povray.unofficial.patches : Tesselation process Server Time
27 Mar 2026 12:27:45 EDT (-0400)
  Tesselation process (Message 16 to 25 of 35)
Subject: Re: Tesselation process
Date: 19 Feb 2002 07:43:57
Message: <3C7248A9.A515605B@atosorigin.com>
"Rick [Kitty5]" wrote:
> have you considered assigning standard pov objects (eg sphere) a pre defined
> mesh, marching for all non regular objects (such as blobs) then deal with
> csg
Sorry to sound offensive but:
<Irony on>
 Please do the same for UV-Mapping first,
then I will slaveshly copy your solution to perform tesselation.
Afterall, UV mapping is present in megapov since so much time...
<Irony off>
Just think about both problem, they are very similar.
To reassure you, I should post soon a tesselation of a sphere in p.b.i.
(Low resolution of tessel, unsmoothed mesh). How many slice do you want ?
Do you have any other fetish object that you (or someone else) would like
to see tesselated ? (you provide the code or the pointer to it !)
P.S.: To really answer your question, Yes I did, and I consider it was
not forth it (adding pre-tesselated primitive) as long as the marching
variant were able to provide a good result. And most mesh are not simple
primitive anyway. With the marching approach, I have a hammer, so everything
is going to be a nail !
(But I have different hammers (6), not just one big universal one...)
Non Sine Numine
http://grimbert.cjb.net/
Puis, s'il advient d'un peu triompher, par hasard,
Date: 19 Feb 2002 08:08:36
Message: <fbj47u804kf0v7r7949cmesonpobde4hid@4ax.com>
> to see tesselated ?
new povlogo
it's realy is good testing object: cone, sphere, difference, union,
translations, rotations, splitted volume, sharp edges, smooth surface
ABX
Date: 19 Feb 2002 09:06:27
Message: <3c725be3@news.povray.org>
news:3C7248A9.A515605B@atosorigin.com...
My car =)
http://news.povray.org/povray.binaries.scene-files/22093/150317/NekCar_F15.pov
http://news.povray.org/povray.binaries.scene-files/22093/150317/Car_F15.inc
I wonder how long it would take to tessellate it...
#local X=20*<-2,2,5>;#local K=2*z*X-X;#local R=seed(frame_number);blob{#while(K
.x>X.x)#local N=X+<rand(R)rand(R)1>/3;#local X=(vlength(N-K)<vlength(X-K)?N:2*X
-N);sphere{X,1,1rotate z*90}sphere{X,1,1}#end pigment{rgbt 1}interior{media{
emission<2,4,5>*5}}hollow scale.05}//   http://nekar_xenos.tripod.com/metanoia/
sphere_sweep{catmull_rom_spline 6<-8,-8>1<-8,-8>1<-8,8>1<8,-8>1<8,8>1<8,8>1
translate 20*z pigment{gradient z scale 3color_map{[0rgb<0,9,18>][1rgb 0]}}}
Version: 6.0.324 / Virus Database: 181 - Release Date: 2002/02/14
Date: 19 Feb 2002 09:30:53
Message: <3C726191.7E0F3F4A@namtar.qub.ac.uk>
Nekar Xenos wrote:
> My car =)
You and that car... I think you're obssessed ;)
signature{
Date: 19 Feb 2002 18:53:18
Message: <chrishuff-DCA06F.18530219022002@netplex.aussie.org>
None of that would be a problem.
This is what I'm thinking:
1: A "tesselate" flag for each shape. Some shapes (simple ones like
spheres, cylinders, boxes, triangles, polygons, meshes, height
fields...) will have specialized tesselation methods, the rest will use
the generic methods. I actually got most of the work on this done using
Warp's tesselation code, but never finished it.
When the tesselate flag is specified, the object is tesselated. Copies
of it share the same mesh data, unless tesselation is specified for the
copy, in which case it gets its own mesh (useful if you want multiple
copies with different tesselation parameters). The resulting object uses
the mesh for intersection calculations, but the original insideness
calculations, so it is still useful for CSG.
2: Objects can be used in a mesh statement. The object is then
tesselated and the resulting triangles placed in the mesh. The
"tesselate" flag is used to give any special settings to the tesselation
code, if not specified the defaults are used.
3: Possibly, allow non-linear deformations for all shapes. Those shapes
that don't support a more direct method will tesselate and deform the
mesh.
Date: 19 Feb 2002 19:33:28
Message: <3C72EE49.979B5315@hotmail.com>
Christopher James Huff wrote:
> In article <3C7### [at] onlineno>,
>  Tor Olav Kristensen <tor### [at] onlineno> wrote:
> > I think that it would be a great pity if
> > a POV-patch were to perform tessellation
> > of an object without providing the possi-
> > bility to texture different copies of it
> > differently.
> I wasn't talking about copies, but an alternate rendering method. A
> "tesselate" flag that would cause the object to be tesselated and
> rendered (and traced) as a mesh. Copies would be textured the same way
> any other object copies are textured.
I am hoping for the possibility to tweak
the individual copies of a mesh before
texturing them.
If one has direct access to the 3D coordinates
of the vertexes and the normal vectors, then
the tessellated shapes could be transformed
in very weird ways.
(POV's usual matrix<> related transformations
would only allow for linear transformations.)
Tor Olav
Date: 19 Feb 2002 20:31:45
Message: <chrishuff-1D3D25.20313219022002@netplex.aussie.org>
In article <3C72EE49.979B5315@hotmail.com>,
 Tor Olav Kristensen <tor### [at] hotmailcom> wrote:
> I am hoping for the possibility to tweak the individual copies of a
> mesh before texturing them.
I don't see how it would be a problem...just include a
"preserve_textures" option for objects being added to meshes. If it is
on, the triangles get the texture of the original object, if it is off
you get an untextured mesh.
> If one has direct access to the 3D coordinates of the vertexes and
> the normal vectors, then the tessellated shapes could be transformed
> in very weird ways.
I once attempted a patch that would allow any warp to be applied to a
mesh...my only problem was that I couldn't seem to move the mesh points.
My attempts all resulted in "scrambled triangles".
Date: 19 Feb 2002 22:40:24
Message: <3c731aa8@news.povray.org>
When my cloth-fur-thing has managed to produce something nice (like a towel
or maybe even a sitting poodle), I'll let you (or your program or your
script) tesselate it. And then maybe there are some fetishists that are
willing to recreate it with snippets of paper in real life.      :-)
Date: 20 Feb 2002 01:35:12
Message: <3c7343a0@news.povray.org>
"Grey Knight" <s16### [at] namtarqubacuk> wrote in message
news:3C726191.7E0F3F4A@namtar.qub.ac.uk...
> Nekar Xenos wrote:
> > My car =)
Yeah..  ;o)
Version: 6.0.325 / Virus Database: 182 - Release Date: 2002/02/19
Date: 20 Feb 2002 03:13:06
Message: <3C735AB2.1797C402@atosorigin.com>
Ok, looks like we are going for the 'all option' versions...
It seems there is two opposite approachs, each with good arguments.
It might be better afterall, but it will be harder for me...
> > in very weird ways.
I'm sorry, really sorry... I made such thing last weeks... :-< ... and it works fine.
Just currently, it is just forgetting to copy individual textures... and
smooth triangles do not survive as smooth...
Non Sine Numine
