POV-Ray : Newsgroups : povray.unofficial.patches : Hey, Warp (Tesselation patch: the fire test) Server Time
22 Mar 2026 12:55:01 EDT (-0400)
  Hey, Warp (Tesselation patch: the fire test) (Message 1 to 10 of 22)
Subject: Hey, Warp (Tesselation patch: the fire test)
Date: 5 Oct 2001 08:11:32
Message: <3BBDA379.B5B45581@atosorigin.com>
I believe I have solved the tesselation bug...
More on that later, but before exposing my solution and myself to ridicule,
I would like to test it with some scenes whose tesselation previously failed
 (well, not really failed, just a bogus mesh).
I did my experiment on a bogus cylinder I once get, and
all I could find is the tesselation of the moving sphere on the
patch page (and also the newsgroup).
So, does anyone have some bogus generated mesh that I could try ?
(Possibly only with object from 3.1, because I have not Megapov installed,
so no isosurface, please).
Subject: Re: Hey, Warp (Tesselation patch: the fire test)
Date: 5 Oct 2001 08:34:32
Message: <3BBDA9AF.C615BB94@gmx.de>
I think isosurfaces would not be very good to prove things anyway, because
the whole isosurface intersection stuff is quite critical.
I don't have any specific object here you should try, but i think some
CSG's,  blobs and text objects would be good examples to test.
I will save my congratulations until you reveal your solution. ;-)
Date: 5 Oct 2001 08:38:44
Message: <3bbda9d3@news.povray.org>
I recall trying to tesselate BlobMan objects and the bug showing up there.
Date: 5 Oct 2001 11:12:41
Message: <3BBDCDEB.773F74CF@atosorigin.com>
Any specific scene ?
I cannot try every values for the blobman parameters...,
I'm not immortal yet...
Date: 5 Oct 2001 11:12:59
Message: <3bbdcdfb@news.povray.org>
Oo - can't wait!
BTW which version does it run on? 3.1, 3.5, Megapov .6, .7 ?
- Nekar
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 5 Oct 2001 11:30:33
Message: <3BBDD219.712DD301@atosorigin.com>
I have done some tests with blobs already, but maybe not the Bogus blobs...
I have also my own set of test objects... BUT...
Given the fact that the initial bogus (sphere) only appeared when
moving the sphere, I may very well miss a bogus case that someone
already know about. So, I would like to perform a kind of private beta
(with scene from other people, even if I'm not yet ready to publish
the correction
[before that, I need to gain confidence with my analysis
of the cause of the problem {I'm nearly OK for the theory, and so far the
scenes I tested where fine, but know problem scenes are the better}]
Thanks for the suggestion of ttf ! I missed that basic one, as well as CSG
(I played with torus, superellipsoid, cylinder and so on, but still missed the
basic CSG and ttf one! I would better reopen the pov manual and check with
each finite solid primitive...
Date: 5 Oct 2001 11:37:25
Message: <3BBDD3B6.E11BF559@atosorigin.com>
Nekar Xenos wrote:
> Oo - can't wait!
You will have to. At least a little.
(Anyway, for this weekend, you should have the next 3.5 beta to install,
 or otherwise it will be expired for everybody,
so you will have something to do.)
Currently, only MY personnal 3.1 derivative... on Linux. The patch code is
not in a publishable state. But you will have the explanation sooner than the
code IF it is really the cause that I have isolated.
Maybe someone incorporated the initial patch of Warp (which was for
Megapov [UV mapping was required]) in a variant of Megapov ?
Date: 5 Oct 2001 11:51:24
Message: <3bbdd6fc@news.povray.org>
news:3BBDD3B6.E11BF559@atosorigin.com...
> Nekar Xenos wrote:
> > Oo - can't wait!
Will it work on Windoze?
- Nekar
Date: 5 Oct 2001 11:59:15
Message: <3BBDD8D3.2465C66D@atosorigin.com>
Of course, when someone with the ZinZin compilation system will have
 incorporated it in whatever (Mega)Pov version.
There is no Linux dependancy, It's just that I only have the compiler for Linux.
Pov is portable. Pov is great.
Date: 5 Oct 2001 12:44:06
Message: <3bbde356@news.povray.org>
I look forward to seeing this patch working and integrated into the next
incarnation of megapov based on the 3.5 code as I belive it to be
potentially one of the most useful additions to Pov. So good luck, fingers
crossed.
Mick
