POV-Ray : Newsgroups : povray.unofficial.patches : Question about normal bug fix Server Time
2 Nov 2024 11:26:16 EDT (-0400)
  Question about normal bug fix (Message 1 to 10 of 12)
Subject: Question about normal bug fix
Date: 12 Dec 1999 23:04:08
Message: <chrishuff_99-3DE868.23043612121999@news.povray.org>
In the documentation for MacMegaPOV, it says "Now, whenever you scale a
normal pattern or an object that has a surface normal, the depth
(amount) of the normal will scale proportionally.".
Now, for most cases, this is fine, but what does it do when the normal
is unevenly scaled? Like if you scale it by scale < 1, 5, 3>. How is the
depth of the normal affected in this case?
Chris Huff
e-mail: chr### [at] yahoocom
Subject: Re: Question about normal bug fix
Date: 13 Dec 1999 16:02:41
Message: <38555ef1@news.povray.org>
I believe any normal is going to be surface-only dependant.  So uneven
scaling will probably average out, maybe.  Like <1,5,3>=3 perhaps for the
"depth".  The person to answer decisively of course would be the author of
that particular change.
"Chris Huff" <chr### [at] yahoocom> wrote in message
news:chrishuff_99-3DE868.23043612121999@news.povray.org...
> Chris Huff
> Web page: http://chrishuff.dhs.org/
Date: 13 Dec 1999 22:41:50
Message: <3855bc7e@news.povray.org>
The depth is scaled unevenly.
The bugfix does not actually scale the 'amount' property of the normal.
Instead, it rearranges the order of some events that happen.
You see, to determine a normal from a pattern (using a non-normal pattern),
the gradient of the pattern must be found.  To determine this gradient, four
sample points are used.  The location of those points and their distance
from the original center point will have a great affect on the apparant
depth of the bumps.
The problem was when POV-Ray applied warps (including turbulence and
transformations).  Did it do this before choosing the four sample points or
after?  The truth was that sometimes it did it before, sometimes after.  Any
transformations applied to the deepest-level normals would get done after
choosing sample points.  Any other transformations (such as to parent
patterns) would get done before.
Example:
normal{
  average
  normal_map{
    [1 crackle 1 scale 2 ]
  scale 10
Here's the order of events (original point is called P):
1) inverse-scale P by 10
2) choose 4 sample points, s1,s2,s3,s4
     all 0.02 POV-units away from P
3) inverse-scale s1,s2,s3,s4 by 2
4) determine the gradient using s1,s2,s3,s4
So, in this case, the 'scale 10' in the outer pattern would increase the
apparant depth of the bumps by a factor of 10, while the inner 'scale 2'
would only stretch out the pattern without affecting the apparant depth.
I changed it so that the order of events will be consistent.  In MegaPov,
the above sequence would look like this:
2) inverse-scale P by 2
3) choose 4 sample points, s1,s2,s3,s4
-Nathan
Chris Huff <chr### [at] yahoocom> wrote...
> Chris Huff
Date: 14 Dec 1999 06:22:30
Message: <38562876@news.povray.org>
As I wrote in p.b.i I think that evenly scaling a normal modifier should
not change its slope. This is because if we replace the normal modifier
with a heighfield, scaling it uniformly will not change its slope either.
Date: 14 Dec 1999 08:58:00
Message: <38564D04.868D297A@inapg.inra.fr>
After running a few tests, I realize now that the previous implementation was
actually wrong...
You can run this little script and see that in Megapov the cube aspect doesn't
change for different values of sc. In regular POV, it behaves a little
strangely, to say the less.
#declare sc=1; //#declare sc=100;
camera{ location  20*<1,1,-1>   direction sc*z   right     4/3*x   look_at 0}
background{color rgb 1} light_source{1000*<1,1,-1> color rgb 2}
box{-1,1 texture{pigment{rgb <0,1,1>} normal{crackle 1}} scale 5/sc}
However, I'm a little bit concerned about the fact that, unless I'm mistaken,
the normal bug fix is changing the way all the scenes that include scaled
normals are now appearing. There is a serious problem of backward
compatibility here because fine-tuning again the normals of every previous
scene to obtain the same result as before is not something people will
spontaneously enjoy... Perhaps there should be something in global_settings to
make it easier.
G.
Date: 14 Dec 1999 09:26:30
Message: <38565272.961CDA4B@pacbell.net>
> make it easier.
...or perhaps the version directive can keep the functions seperate. I too
would be hard pressed to reproduce some of my earlier textures that are
heavily dependant on surface normals.
Wishing you Seasons Greetings, A Merry Christmas, and A Happy New Year !
Ken Tyler -  1200+ Povray, Graphics, 3D Rendering, and Raytracing Links:
Date: 14 Dec 1999 22:29:23
Message: <38570b13@news.povray.org>
Ok.  Due to popluar demand, in the next version of MegaPov, you will be able
to use #version 3.1 to revert (mostly) to the old buggy surface normals.
The normal rotation bug will still be fixed, though (I think... I must test
that more).
- Nathan
Ken <tyl### [at] pacbellnet> wrote...
mistaken,
scaled
previous
global_settings to
> > make it easier.
Date: 15 Dec 1999 05:08:14
Message: <3857688e@news.povray.org>
Wouldn't a good solution to make a translator program that tweak the
settings to get the same scene? It could also make other adjustments like,
old style color_maps, blobs, radiosity, adding ";" and perhaps even convert
halo to media.
I know this isn't a new idea. I know it is probably quite a work (and maybe
even impossible for halos). But I think it is one of the best solution for
this kind of backward compatibility problems. And, er, an idea (maybe a
stupid one) the translation could be done by patched POV itself, using the
parser but outputting a POV file rather than / together with the image file.
And this would keep everything in one place.
Please don't flame me. I have no idea how hard or unintelligent this is, I
am no programmer.
And many thanks to everybody who made and make POV the wonderful renderer it
is.
Povingly
Philippe
Date: 15 Dec 1999 05:51:32
Message: <385772b4@news.povray.org>
Philippe Debar <phi### [at] hotmailcom> wrote:
: Wouldn't a good solution to make a translator program that tweak the
: settings to get the same scene?
  Your idea is good. However it shouldn't be necessary because the behaviour
of megapov is wrong while the behaviour of povray is right (except for
normal_maps).
Date: 15 Dec 1999 08:06:14
Message: <38579266.E22838FB@inapg.inra.fr>
Thanks Nathan !
G.
> that more).
> - Nathan
