POV-Ray : Newsgroups : povray.unofficial.patches : Retaining persistent variables in MegaPov 1.0 Server Time
28 Sep 2024 18:13:05 EDT (-0400)
  Retaining persistent variables in MegaPov 1.0 (Message 1 to 10 of 23)
Subject: Retaining persistent variables in MegaPov 1.0
Date: 8 Oct 2003 03:10:01
Message: <web.3f83b795b9f31a6dd467bfc30@news.povray.org>
Hi!
I was trying to use persistent variables in an animation sequence using
MegaPov 1.0. I was using the same syntax as in MegaPov 0.7. i.e. use
Persistent_Animation=yes in the INI file and then using label and modify
inside the script. This is producing all kinds of errors. I was wondering
if there is a change of syntax in MegaPov 1.0 or persistent variables
supported at all. Can anybody throw light on this please. It will be of a
great help to me.
Sup
ps: Initially I posted it in the animation forum, but since this is more
related to megapov than animation, I thought 'would be appropriate to post
it here.
Subject: Re: Retaining persistent variables in MegaPov 1.0
Date: 8 Oct 2003 03:21:06
Message: <29e7ovsd1dv84lrh783bqrtng1r7i285i1@4ax.com>
> it here.
Thanks, Sup, for using this group now, but... is there anything wrong with the
answer you already received in povray.animation group? I quoted there sentence
we wrote at begining of http://megapov.inetart.net/manual/news.html where you
can find all features already reimplemented. The only other help I can give
you at this moment is workaround this feature with importing/exporting
variables through external file. Is this sufficient?
ABX
Date: 8 Oct 2003 13:30:01
Message: <web.3f844918b6855006d467bfc30@news.povray.org>
Hi ABX!
Thank you for both your replies. From your previous reply it was clear that
persistent variables may not have made it to MP1.0. But in the manuals of
MP1.0, nowhere it has been explicitly mentioned. Therefore I had the
slightest hope that this feature may be accesible in some other way. It
would be really nice to get this feature back since my code is not
compatible with MP0.7. I have tried the file I/O feature. Due to the very
large size of the file (476 Kb), reading seems extremely slow, almost same
time as generating the data. e.g. My parsing time is 5 min, rendering time
30 sec. I guess I have to wait till this feature gets implemented.
thanks again
Sup
>> it here.
>ABX
Date: 8 Oct 2003 13:45:36
Message: <4si8ovsu7bgdaato8e14rf9lf3bonc7rf0@4ax.com>
What method do you use to perform writing/reading ?
Do you use #write #read ? Perhaps reading through #include would be faster ?
Perhaps writing it into array would offer later fastest #include? Perhaps
other trick could be possible as well - for example you could write data into
ascii image and then read it through evaluation of colors on pigment. I
suggest to seeking for workarounds temporary as long as persistent variables
are not available.
ABX
Date: 8 Oct 2003 14:02:02
Message: <jtvd51-41u.ln1@triton.schunter.etc.tu-bs.de>
sups wrote:
> Hi ABX!
It is not very likely that this will happen any time soon.  The
persistence of variables patch was somewhat ugly and Nathan was probably
the only one who really understood it.
I would also prefer a different syntax for such a patch.  Like for
example a new #persistent directive which works like #declare and #local
but stores the data differently so it is not cleared after each frame.
Last updated 2 Sep. 2003 _____./\/^>_*_<^\/\.______
Date: 8 Oct 2003 14:10:01
Message: <web.3f8452f2b6855006d467bfc30@news.povray.org>
Right now, I have used the #read and it seems too slow. I will try #include
and let you know what happens. I also agree with Chris on the syntax of
persistent variables.
thank you
Sup
>are not available.
>ABX
Date: 8 Oct 2003 14:19:21
Message: <Xns940ECEBB9AD8Bseed7@netplex.aussie.org>
in news:jtv### [at] tritonschunteretctu-bsde Christoph Hormann
Just an idea, how about something inspired by Pythons pickle and shelve:
http://www.python.org/doc/current/lib/module-pickle.html
http://www.python.org/doc/current/lib/module-shelve.html
You could make not just variables persistent but whole objects or scene
sections.
Ingo
Date: 9 Oct 2003 08:39:32
Message: <3f855704$1@news.povray.org>
#declare_persistant = XXXX;
This seems like the best way. This would work for objects as well I would
assume. Just my thoughts.
news:jtv### [at] tritonschunteretctu-bsde...
> sups wrote:
> > Hi ABX!
that
of
> Christoph
> POV-Ray tutorials, include files, Sim-POV,
> HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Date: 9 Oct 2003 13:09:31
Message: <cjameshuff-C6E436.13070809102003@netplex.aussie.org>
In article <3f855704$1@news.povray.org>,
Simply #persistant should be enough, and consistent with the existing
#declare, #local keywords. And it should be possible without too much
work for anything that can be declared...but I haven't really looked at
the changes that would need to be made.
http://tag.povray.org/
Date: 9 Oct 2003 13:36:32
Message: <rk6bov0qt73b9hmm5af9oj8tgibihbemgb@4ax.com>
On Thu, 09 Oct 2003 13:07:08 -0400, Christopher James Huff
I suppose it will be more difficult at least because of functions existence.
#declare C=function{pigment{object{sphere{0,1}rgb 0 rgb 1}}}
#persistent D=function{C(x,y,z)+1}
BTW I would prefer #persist more than #persistent
ABX
