![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Welcome back, Nathan,
Nathan Kopp wrote:
> The default should be 3.1. Do you have Version=3.0 in an ini file
> somewhere? Otherwise, it might be a round-off error.
Ok, it seems the general consensus is round-off error. Just
to confirm: I've looked in all the INI files and found no older
"Version=" statements, including the "root" POVRAY.INI (which
contains no Version statement at all), so effectively if I pull
the Version=3.1 out of my INI file, it should be the equivalent
of telling POV nothing at all about version.
> Just "#version 3.1;" will work. The word "official" will disable the
> unofficial features, but if you don't use the word "official", then the
> unofficial features will remain activated.
Aha! I wondered what was up with the new keywords in the #version.
Not sure why anyone would want to disable the unofficial features
when the whole point of having an unoffical compile is playing with
the unofficial features <vbg> but I see what you're getting at. :)
Thanks.
Charles
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Charles Fusner <cfu### [at] enter net> wrote...
> Thanks.
Sometimes people want to temporarily disable some changes, such as changes
to layered textures and normals.
-Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: MegaPov 0.4 Now Available (Windows/Macintosh)
Date: 2 Feb 2000 00:50:57
Message: <3897c5c1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris Huff wrote in message ...
>In article <3897068A.7984E169@my-dejanews.com>,
>gre### [at] my-dejanews com wrote:
>> I have used noise3d, however, in 0.3. Was there some kind of change to
>> this function?
>I wrote a patch which allows it to be used in normal POV-Ray script,
>instead of only in isosurface functions.
Is there an example of that somewhere. It sounds really neat.
Gail
* gsh### [at] monotix co za * ERROR: COFFEE.COM not found *
* http://www.rucus.ru.ac.za/~gail/ * Insert cup and press any key *
* Definition of an upgrade: Take the old bugs out, put new ones in*
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 2 Feb 2000 06:11:12
Message: <389810d0@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello Nathan,
I would be happy if you had the time to look into my problem with MegaPov
0.4. I was a little vague: I get the following message:
Warning Stream to console.......On
translate 1000*x
warp {turbulence Vary octaves 1}
warp {planar z 0}
warp {reset_children <----ERROR
C:\Program Files\POV-Ray\Include\\vloer.inc:15: error: This feature requires
MegaPov 0.3.
Specify '#version unofficial MegaPov 0.4;' IN THIS FILE to enable this
feature.
Returned from renderer (non-zero return value)
The "vloer.inc" has the Ron Parker's inc with the irregular floor tiles. It
does OK in the 0.3 version.
I tried several #-statements in several places, but I am very unsure as how
this works and what to do.
0.3 suits me well, but why not use 0.4 if I can? (I have to include the
#version 3.1 at a certain spot to get my textures right: that I gathered
from earlier answers I got on the subject.
Thank you in advance,
Sander
Nathan Kopp <Nat### [at] Kopp com> schreef in berichtnieuws
389745a7@news.povray.org...
> Sander <san### [at] stols com> wrote...
> > Maybe I forget something, but the 'reset-children' feature doesn't work
> even
> > after adding the #version etc. line. What do I do wrong??
> What does 'not work' mean? Do you get a #version-related error message,
or
> does it parse and then not function.
> -Nathan
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 2 Feb 2000 07:39:59
Message: <3898259f@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Nathan,
I was too quick for once! I just added "#version unofficial MegaPov 0.4" at
the beginning of the vloer.inc and it works!
But I don't understand it... What does it do? Why didn't I have to add
anything in MegaPov 0.3?
Sander
Sander <san### [at] stols com> schreef in berichtnieuws
389810d0@news.povray.org...
> Hello Nathan,
> translate 1000*x
> warp {planar z 0}
<snip>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 2 Feb 2000 11:17:42
Message: <389858a6@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <3898259f@news.povray.org> , "Sander" <san### [at] stols com> wrote:
The reason is simple: There have been several occasions when (new) users
tried to use unofficial features in the official version (i.e. isosurfaces)
from some POV scene code they got on the web or here in the newsgroups.
In general it is hard for (new) users who do not know which feature is
official and which is part of an unofficial version only to identify such a
problem. Adding "#version unofficial" will on the one hand make the current
official version issue an error that "unofficial" is an undeclared
identifier with "#version unofficial <----ERROR", and future official
versions will issue a more helpful and explicit error message.
Thorsten
Thorsten Froehlich
e-mail: mac### [at] povray org
I am a member of the POV-Ray Team.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <qqm### [at] schlatt fmi uni-konstanz de>, Thomas
Willhalm <tho### [at] willhalm de> wrote:
> In frame.h it says:
> #define CLOCKDIVIDER CLK_TCK /*provided by standard c? */
> and as far as I know the answer is "No". According to the documentation
> available to me, you should use CLOCK_PER_SEC instead and include
> <time.h>.
Actually, it is CLOCKS_PER_SEC. :-)
I don't know about whether it is standard or not, but I had to modify my
compile to use it instead of CLK_TCK. It took a bit of searching through
headers to find out about that annoying little "S".
Chris Huff
e-mail: chr### [at] yahoo com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris Huff <chr### [at] yahoo com> writes:
> > In frame.h it says:
> > <time.h>.
I'm sorry about wasting your time. I should have used copy'n'paste instead
of typing.
According to Plauger/Brodie "Standard C" CLOCKS_PER_SEC is standard.
(Yes, I know that this book is from Microsoft Press, but let's assume
that their books contain less errors than their software.)
http://thomas.willhalm.de/ (includes pgp key)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> instead of typing.
No problem, it took me much less time to find that little typo than it
would have taken for me to figure out why CLK_TCK wasn't defined
anywhere.
Chris Huff
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > > In frame.h it says:
> > > <time.h>.
> of typing.
According to the gcc time.h file, "CLK_TCK" is "the obsolete POSIX.1-1988
name for the same constant" for "CLOCKS_PER_SEC"
And here's the bit of code they use:
/* This defines CLOCKS_PER_SEC, which is the number of processor clock
ticks per second. */
# include <bits/time.h>
/* This is the obsolete POSIX.1-1988 name for the same constant. */
# ifdef __USE_POSIX
# ifndef CLK_TCK
# define CLK_TCK CLOCKS_PER_SEC
# endif
# endif
"My new computer's got the clocks, it rocks
But it was obsolete before I opened the box" - W.A.Y.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
