POV-Ray : Newsgroups : povray.unofficial.patches : MegaPov 0.4 Now Available (Windows/Macintosh) Server Time
9 Apr 2026 01:31:44 EDT (-0400)
  MegaPov 0.4 Now Available (Windows/Macintosh) (Message 3 to 12 of 32)
<<< Previous 2 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: MegaPov 0.4 Now Available (Windows/Macintosh)
Date: 30 Jan 2000 13:11:56
Message: <chrishuff_99-D4FEA3.13124230012000@news.povray.org>
In article <38947d50@news.povray.org>, Nieminen Juha
<war### [at] punarastascstutfi> wrote:
>   The new features are amazing, as usual... :)
>   I have a question about the trace function (perhaps this is not the
>   correct
> thread for this, but I'm too lazy to write a separate article...):
>   The documentation says:
> "If a fourth parameter in the form of a vector identifier is provided,
> the normal of the object at the intersection point (not including any
> normal
> perturbations due to textures) is stored into that vector."
>   What if I really want the perturbed normal? I can think of some uses of
> this.
>   Perhaps a 5th parameter (of boolen type) could be added? If the
>   parameter
> is true, then the returned normal is perturbed by the texture before
> returning. The default value could be false.
How about adding a "perturb_normal()" function instead?
Chris Huff
e-mail: chr### [at] yahoocom
Date: 30 Jan 2000 13:25:24
Message: <38948214@news.povray.org>
Chris Huff <chr### [at] yahoocom> wrote:
: How about adding a "perturb_normal()" function instead?
  It may be one solution, but difficult to use if the object in question
has complex transformations (you would have to apply the same transformations
to the texture before calling perturb_normal()).
Date: 30 Jan 2000 13:43:22
Message: <chrishuff_99-C50692.13440830012000@news.povray.org>
In article <38948214@news.povray.org>, Nieminen Juha
> transformations
How about also adding a way to access the texture of the object? That
way you could trace against the object, then use the object's texture
normal(which was transformed along with the object) to perturb the real
normal. The normal could be accessed by either a dot
operator(preferable, something like this: Obj.texture.normal), or by a
function(less flexible syntax, more keywords, etc. Something like
get_tex_normal(Obj)).
Chris Huff
Date: 30 Jan 2000 16:19:22
Message: <3894aada@news.povray.org>
Maybe I forget something, but the 'reset-children' feature doesn't work even
after adding the #version etc. line. What do I do wrong??
Sander
smellenbergh <sme### [at] skynetbe> schreef in berichtnieuws
1e589wt.1fbph7bq1ekdqN%smellenbergh@skynet.be...
> MegaPov 0.4 is ready for downloading.
Date: 30 Jan 2000 16:23:42
Message: <3894ABB8.FA864E23@pacbell.net>
Did you by any chance check it against the code Ron Parker recently
posted in povray.text.scene-files ? That code is known to work with
earlier versions.
    Subject:  Re: Brick wall and paving stones macros (~80kb)
       Date:  19 Jan 2000 10:15:35 -0500
 Newsgroups:  povray.binaries.images, povray.text.scene-files
 Followup-To: povray.text.scene-files
  References: 1 , 2 , 3 , 4
Date: 30 Jan 2000 16:28:11
Message: <3894aceb@news.povray.org>
No I didn't. Not that I know what code you have in mind: but I will look
first. Thanks!
Sander
Ken <tyl### [at] pacbellnet> schreef in berichtnieuws
3894ABB8.FA864E23@pacbell.net...
> earlier versions.
>        From:  ron### [at] povrayorg (Ron Parker)
Date: 30 Jan 2000 16:32:44
Message: <slrn899but.16e.ron.parker@linux.parkerr.fwi.com>
>the normal of the object at the intersection point (not including any normal
>this.
The main problem, if I recall correctly, is that the object may or may
not have a normal pattern applied to it at that point in parsing, since
it was #declared but not actually instantiated.  I could certainly check
if it does have one applied and if so do the extra calculations to perturb
the normal; it's just not something that occurred to me at the time.  I'm
not even sure you need the fifth boolean parameter: if you don't want
the perturbed normal, don't perturb it.
Date: 30 Jan 2000 18:43:41
Message: <3894CCD9.EBCD2FD1@enter.net>
Do you by chance have the warp listed in an include file?
I have a work in progress that uses reset_children and it
conked out until I put the #version line at the top of the
inc file that actually contained the warp. Even once I
put it in the texture inc file, it still didn't work properly
until I also added the #version to the scene file where the
#declared texture was actually referenced. It's much more
restrictive than it was, but it still works...with a
little more typing <g>.
Charles
Subject: A trivial #version conundrum
Date: 30 Jan 2000 19:00:19
Message: <3894D0C0.CBF01B51@enter.net>
While I'm on the subject, I'll mention here for the benefit of
anyone else who doesn't bother putting Version=3.1 in their INI
files (like me, duh!), if you don't tell MegaPOV anything going
in, it apparently automatically sets itself for version 3.00 which
of course kills the #macro directive.
For some reason, setting ...
#version unofficial MegaPov 0.4;"
...won't change this behaviour even though setting...
"#version official 3.1;"
..will fix it. (??) Anyway, the best solution is fix your
INI files, I guess, but another workaround is to use
"#version official 3.1;" before you define your macros, then
"#version unofficial MegaPov 0.4;" after you're finished.
For whatever reasons, once they're defined, the version
doesn't have any affect on the macros performance. Personally
I don't see why any version switch should turn off macros.
I mean, obviously macros didn't always exist and older
versions of POV won't handle them, but if the program
version you're using knows what they are, why be fussy and
shut down with an error messgae because of a version switch?
Anyway, thought I'd post this observation in case it affects
anyone else as dumb as me.
Charles
Subject: Re: A trivial #version conundrum
Date: 30 Jan 2000 19:21:09
Message: <3894D588.404FCA3C@gci.net>
I have used the #macro statement without any problem.
I did have to set  #version unofficial MegaPov 0.4; to
get isosurfaces to work, but that was all.
I am using WinMeagPov0.4. Are you on a different os?
> Charles
Mr. Art
"Often the appearance of reality is more important
than the reality of the appearance."
Bill DeWitt 2000
