POV-Ray : Newsgroups : povray.unofficial.patches : Voxel output from POV? Server Time
17 Jun 2026 01:56:43 EDT (-0400)
  Voxel output from POV? (Message 1 to 1 of 1)
Subject: Voxel output from POV?
Date: 22 Jan 2002 18:14:49
Message: <1416110.YRq4vBrkhl@3-e.net>
How complex a task would it be to patch POV so that is could render a scene
to a wavelet compressed voxel (3d pixel) file.
I know some of these voxel files could be huge but tricks can be used to
reduce their size. Remove all data inside opaque volumes and use a separate
data layer for media and atmospherics so that it can be turned off or very
high levels of compression applied to it. Multiple LOD points could be set
to allow for navigation through the scene. Imagine these LODs as a set of
overlapping spherical gradients that control the compression level.
I often wonder what it would be like to wander/look around inside some of
the first class work on from the IRTC.
Think of it as extreme POV-VRML
:o) Dan.
Subject: Re: Voxel output from POV?
Date: 22 Jan 2002 18:21:48
Message: <3c4df40c$1@news.povray.org>
I have a friend who has a voxel engine that accepts height maps from POV Ray
and color maps to lay over them. It works very well. Let me know if that is
something that would interest you.
"Daniel Matthews" <dan### [at] 3-enet> wrote in message
news:141### [at] 3-enet...
scene
separate
> :o) Dan.
Date: 22 Jan 2002 19:31:13
Message: <13863242.0VBb9nUPly@3-e.net>
No it doesn't.
I was interested in a patched version of POV that has the exact features
that I described, or a reasonable subset of them. Or a discussion on it's
feasibility..
Unless your friend's engine is GPL and can handle multidimensional wavelet
arrays, including alpha/mask dimensional sets?
> Ray and color maps to lay over them. It works very well. Let me know if
> that is something that would interest you.
> scene
> separate
>> very high levels of compression applied to it. Multiple LOD points could
>> be set to allow for navigation through the scene. Imagine these LODs as a
>> set of overlapping spherical gradients that control the compression
>> level.
>> :o) Dan.
Date: 22 Jan 2002 19:48:44
Message: <chrishuff-482EC3.19494722012002@netplex.aussie.org>
MegaPOV has a feature that can be used to create 3D density files, but
that is purely geometry and uncompressed. Your idea sounds
interesting...I think it would have to be another rendering engine
attached to the same parser, though.
I think it would be possible, but a huge amount of work.
BTW, do you have any information on voxel file formats? I've been
working on a voxel file editor...
Date: 22 Jan 2002 20:09:44
Message: <2652268.5OnKVQPIDv@3-e.net>
I have a few PDF files of papers related to 3d wavelet compression of
voxels. Look up stuff on medical imaging.
Date: 22 Jan 2002 20:33:45
Message: <3C4E12C2.578ABD05@aol.com>
Could this be what you are looking for?
 A Fast Depth-Buffer-Based Voxelization Algorithm
Date: 22 Jan 2002 21:01:04
Message: <1022879.ASKD2KPVSP@3-e.net>
Yes! Thank you, that hint + google.com gave me this link
http://www.acm.org/jgt/papers/KarabassiEtAl99b/
Date: 22 Jan 2002 21:10:01
Message: <1173651.usQuhbGJ8B@3-e.net>
The VolVis link off that page also has related images.
http://www.cs.sunysb.edu/~vislab/volvis_home.html
So the steps are
Generate the matrix in POV via a 3d render.
Encode the matrix with compression.
View the Matrix from any point.
No fancy lighting of the Volume is required as the original 3d render will
supply this data. A good radiosity render should be a "fun" object to look
at.
Date: 22 Jan 2002 21:12:54
Message: <2103066.dPhlSkOF2f@3-e.net>
http://www.google.com/search?q=wavelet+voxel
Date: 23 Jan 2002 00:25:50
Message: <MPG.16b8680c1ddc3f7d9896d2@news.povray.org>
In article <141### [at] 3-enet>, dan### [at] 3-enet says...
What about the camera-location-dependent features: reflections,
refractions, highlights...
You can't precalculate and store them all (you would have to this for
every possible camera location) and you can't recalculate them later
on-the-fly.
Lutz-Peter
