I am trying to compile PovRAY under HPUX 11.0 using the native C compiler
and aCC. I get the following error:
aCC -O -I /usr/local/include -AA -L/usr/lib/X11R6 -Wl,-a -Wl,archive -o
povray svga.o unix.o xwin.o ../source/libpovray.a ../source/base/libbase.a
..../source/frontend/libfrontend.a ../libraries/png/libpng.a
..../libraries/tiff/libtiff/libtiff.a ../libraries/zlib/libz.a
..../libraries/jpeg/libjpeg.a -lSM -lICE -lX11 -lm
/usr/ccs/bin/ld: Unsatisfied symbols:
Frame (first referenced in ../source/libpovray.a(benchmark.o)) (data)
Can someone help me get past this? I appreciate it.
I've read your thread in p.general, and would like to ask you first
how you did "fix" the two compiling problems you faced before.
Could you tell me what does the '-AA' option you added? I cannot find it
in the HP online docs at http://docs.hp.com/en/8/options.htm (there is the
-Aa instead for strict-ansi).
The -Wl,-a -Wl,archive linker options tell me that you try to build
POV-Ray as a fully static binary. Did you try linking with shared libs instead?
- NC
I fixed the previous problems by including the -AA option to the C++
compiler. Here is the text from the man page on it:
-AA Turns on newly supported ANSI C++ Standard features
like namespace std and the new C++ Standard Library.
This option also implies -Aa. Include paths are
changed to include_std and libraries are libCsup_v2 and
libstd_v2.
NOTE: Objects and libraries compiled with -AA are
binary incompatible with objects and libraries compiled
without -AA.
I just tried remaking with dynamic libraries and it gave me the same error.
Nicolas Calimet <pov### [at] free fr> wrote:
> Hi,
> - NC
Here is my configure:
../configure COMPILED_BY="JC" --disable-vsnprintf-check --without-x
--disable-io-restrictions CXXFLAGS="-AA -I/usr/local/include +W728 +W749
+W829"
> Hi,
> - NC
Concerning your linking problem, I believe this is caused by
a faulty linker, as it seems unable to resolve symbols contained in a
single library. Maybe there is some special option to turn on; please
consult your ld manual.
> .../configure COMPILED_BY="JC" --disable-vsnprintf-check --without-x
> +W829"
Are you sure this is the actual command-line that you invoqued?
First you don't seem to use the --disable-shared option as I expected.
Moreover, if you specify --without-x, you shouldn't end up with the linker
trying to link with various X libraries (-lSM -lICE -lX11).
- NC
Quoting myself:
The above assumes you're trying to compile the POV-Ray 3.6.1
source distribution.
- NC
Yes, that is the line I have invoked. I cut/pasted into this form from my
terminal window. Whenever I re-do a configuration line, I do a 'make
clean' and then run the configure script again. Should I do something else
to make sure that it starts clean? Maybe there is stuff lying around that
is left over from the previous configure run.
> Quoting myself:
> - NC
You may try 'make distclean' instead.
I'd be interested if you could mail me (see my e-mail in the INSTALL
file) your config.log file.
- NC
