POV-Ray : Newsgroups : povray.text.scene-files : Looking for rendering Omnidirectional Stereo images for VR headset Server Time
2 Jun 2024 14:33:44 EDT (-0400)
  Looking for rendering Omnidirectional Stereo images for VR headset (Message 11 to 20 of 38)
Subject: Re: Looking for rendering Omnidirectional Stereo images for VR headset
Date: 11 Mar 2016 06:35:35
Message: <56e2ad87$1@news.povray.org>
> 2- Use this camera in your scene:
> (sorry, actually doesn't support vector3 direction)
> #declare ipd = 0.065; // Interpupillary distance
> #declare cameraLocationX = 0;
> #declare cameraLocationY = 0;
> #declare cameraLocationZ = 0;
> camera {
>        user_defined
>        location {
>          function { cameraLocationX + cos(select(x,(x+0.5)*2,(x*2)) * 2 * pi -
> pi)*ipd/2*select(x,-1,1) }
>          function { cameraLocationY }
>          function { cameraLocationZ + sin(select(x,(x+0.5)*2,(x*2)) * 2 * pi -
>        direction {
>          function { sin(select(x,(x+0.5)*2,(x*2)) * 2 * pi - pi) * cos(pi / 2 -
> (1-(y+0.5))*pi) }
>          function { sin(pi / 2 - (1-(y+0.5))*pi) }
>          function { cos(select(x,(x+0.5)*2,(x*2)) * 2 * pi - pi) * cos(pi / 2 -
> (1-(y+0.5))*pi) }
   Hmmm... I don't know what I'm doing wrong, but even with a simple
test scene all I get is a black image. I'm using the latest alpha, and
it doesn't gives any error, but the ray count on the output is zero. Any
ideas?
#version 3.7;
global_settings{
   assumed_gamma 1.0
plane{y,-10
   pigment{rgb 1}
sphere{0,10
   pigment{rgb <1,0,0>}
   translate <0,0,50>
light_source{
   100*y,10
camera{
   location <0,0,-1>
   direction 1*z
// ODS camera by Clodo
#declare odsIPD = 0.065;
#declare odsLocationX = 0;
#declare odsLocationY = 0;
#declare odsLocationZ = -1;
#declare odsDirectionX = 0;
#declare odsDirectionY = 0;
#declare odsDirectionZ = 1;
       user_defined
       location {
         function { odsLocationX + cos(select(x,(x+0.5)*2,(x*2)) * 2 * pi -
pi)*odsIPD/2*select(x,-1,1) }
         function { odsLocationY }
         function { odsLocationZ + sin(select(x,(x+0.5)*2,(x*2)) * 2 * pi -
       direction {
cos(pi / 2 -
(1-(y+0.5))*pi) }
cos(pi / 2 -
(1-(y+0.5))*pi) }
jaime
Subject: Re: Looking for rendering Omnidirectional Stereo images for VRheadset
Date: 11 Mar 2016 07:44:05
Message: <56e2bd95$1@news.povray.org>
> ideas?
I see the same with your scene. This user defined camera:
        user_defined
        location {
          function { x }
          function { y }
          function { 0 }
        direction {
          function { x }
          function { y }
          function { 1 }
works for me. Something other than the new camera amiss I guess, but
what...
Bill P.
Date: 11 Mar 2016 09:35:00
Message: <web.56e2d72e6ae27ba34e8811590@news.povray.org>
> ideas?
- I downloaded the official POV-Ray.
- I downloaded this build (64 bit) and replace only the .exe in the POV-Ray
official
https://github.com/POV-Ray/povray/releases/tag/v3.7.1-alpha.8509766%2Bav119
- Open, create jaime.pov with exactly your code above, render:
http://www.clodo.it/host/images/a1c9425560bdcc869a362d71bfb6b11b339e3512.png
(480000 rays count).
Maybe you have a different Alpha build?
Date: 11 Mar 2016 10:03:47
Message: <56e2de53$1@news.povray.org>
   Yes, I have the latest one (8514084), compiled from sources with gcc.
It should have the user defined camera too, because it accepts the
syntax and works when using functions that mimic the default camera:
camera{
   user_defined
   location{
     function{x}
     function{y}
     function{-1}
   direction{
     function{x*4/3}
     function{y}
     function{1}
hmmmm...
jaime
Date: 11 Mar 2016 10:17:23
Message: <56e2e183$1@news.povray.org>
>> ideas?
> official
I am on Ubuntu 14.04 - as is Jamie normally - and using
3.7.1-alpha.8514084.unofficial.
I am starting to wonder if this is another windows/unix difference. I
think Christoph said something like a direction of 0 renders nothing. If
I change Jamie's directional functions only to :
                    direction {
cos(pi / 2 - (1-(y+0.5))*pi) }
         //  function { cos(select(x,(x+0.5)*2,(x*2)) * 2 * pi - pi) *
             function { 1 }
I do see a result though not the correct one. Guess I'll see if I can
step back to 8509766 first.
Bill P.
Date: 11 Mar 2016 10:31:16
Message: <56e2e4c4$1@news.povray.org>
>                     direction {
>              function { 1 }
> Bill P.
8509766 gives me the same result on Ubuntu 14.04.
Interesting too is that changing the z directional function to:
function { 0.1+cos((select(x,(x+0.5)*2,(x*2)) * 2 * pi) - pi) * cos(pi /
gives a partial image.
Bill P.
Date: 11 Mar 2016 10:37:17
Message: <56e2e62d$1@news.povray.org>
   Yes, for me +1 gives one part, and -1 seems to give the rest.
jaime
Date: 11 Mar 2016 19:13:37
Message: <56e35f31$1@news.povray.org>
> jaime
It looks like the difference has something to do with this test in
<install>/source/core/render/tracepixel.cpp :
//          if (cameraDirection.IsNearNull(EPSILON))
//              return false;
because if commented as shown above, I get the same result seen from the
posted windows exe result. I'm still playing and I'll post more if I
learn more.
Bill P.
Date: 11 Mar 2016 19:47:31
Message: <56e36723$1@news.povray.org>
> //              return false;
> learn more.
> Bill P.
Using fabs() instead of abs() in the following two places in
<install>/source/coure/math/vector.h fixes the Ubuntu 14.04 issue for me.
... for 2D vectors
          inline bool IsNearNull(T epsilon) const
             return (fabs(vect[X]) < epsilon) &&
                    (fabs(vect[Y]) < epsilon);
... for 3D vectors
                    (fabs(vect[Y]) < epsilon) &&
                    (fabs(vect[Z]) < epsilon);
I believe fabs() is the safe function to use. Must be the MS compiler in
use did the right thing with just abs() on seeing the input is a float.
Bill P.
Date: 12 Mar 2016 04:43:20
Message: <56e3e4b8$1@news.povray.org>
> me.
   Yep... that fixes it also for me. Good job, Bill... thanks!
   I will let rendering the cave in ODS format this night, then will make
the image available so those with VR glasses can test it (I did buy
yesterday some cheap Cardboard glasses for 3 euros, and lost an hour
mounting them just to discover that my Android phone is not
compatible... :).
jaime
