POV-Ray : Newsgroups : povray.text.scene-files : edge_pigment02.inc (a proximity pattern) Server Time
14 May 2024 01:03:31 EDT (-0400)
  edge_pigment02.inc (a proximity pattern) (Message 5 to 14 of 14)
<<< Previous 4 Messages Goto Initial 10 Messages
Subject: Re: edge_pigment02.inc (a proximity pattern)
Date: 24 Aug 2009 09:06:57
Message: <4a929071@news.povray.org>
stbenge schrieb:
>> Have you /actually/ gotten that to work?
> Oh crap, /I/ just got it to work! When did this start being possible??
> Oh cool :)
Phew - I just was about to confess that no, I never actually tested it
with the inside() function ;-)
(But I'd have been surprised if the SDL inside() function would used any
other mechanism than the very same inside test that's used in CSG, which
I knew works fine with inside_vector.)
Date: 24 Aug 2009 13:50:00
Message: <web.4a92d28499d0b70cffeb02cf0@news.povray.org>
> > Oh cool :)
Which kind of makes me wonder why inside_vector doesn't have a default value.
It seems like the direction rarely matters that much, but if you forget to
specify it...
-Reactor
Date: 24 Aug 2009 15:44:52
Message: <4a92edb4$1@news.povray.org>
stbenge wrote:
> clipka wrote:
>> stbenge schrieb:
>>> And of course you can never use this with meshes. That is, not until
>>> somebody figures out how to convince POV into turning a mesh into a
>>> bona-fide object pattern...
>> You mean, like adding an "inside_vector" statement to the mesh? :-P
http://tinyurl.com/kvww3t
Date: 24 Aug 2009 16:05:41
Message: <4a92f295@news.povray.org>
> specify it...
  My guess is that specifying inside_vector makes the rendering of the
mesh slower in some situations (probably eg. when there's media or fog
around), which is why it's turned off by default.
Date: 24 Aug 2009 17:15:22
Message: <4a9302ea@news.povray.org>
Awesome image! I'm guessing that beautiful chalice is a mesh?
I have tried making meshes into object patterns in the past, but without
success. Even after defining an inside_vector, I received errors.
Date: 24 Aug 2009 18:08:18
Message: <4a930f52$1@news.povray.org>
I don't remember anymore, it's so long ago. I do remember that I got the
idea from you, when you rounded the corners off a cube by jittering it
inside a intersection block, I believe.
Date: 24 Aug 2009 19:29:56
Message: <4a932274$1@news.povray.org>
> specify it...
Backward compat I suppose: Until the introduction of inside_vector, I
assume intersecting a mesh with a solid would give you the same result
as clipping the mesh by that object, and some scenes might have relied
on this effect; defaulting to a proper inside_vector would obviously
break such scenes.
Then again, I guess it would be not much of a problem to default to
inside_vector y (for instance) unless a #version statement is used to
request compat with 3.6 or lower. And a warning could be given even
then, suggesting to use clipped_by instead.
Date: 24 Aug 2009 19:35:24
Message: <4a9323bc@news.povray.org>
I don't think so. Media would only be computed inside a mesh if the
"hollow" keyword is also used anyway.
The only place where it should make a difference is when used with CSG
intersection: In that case, performing proper inside tests instead of
just returning "not inside" would be faster of course.
Anyway, the speed issue could be mitigated by allowing to explicitly
specify "inside_vector <0,0,0>" (or, being equivalent yet more talktive,
"inside_vector no") to disable inside tests.
Date: 25 Aug 2009 11:01:32
Message: <4a93fccc@news.povray.org>
  Except that meshes have no inside and thus no insideness is computed for
them. (Except if inside_vector is specified, of course.)
  That might break existing scenes, especially those which use *open* meshes
and assume that meshes have no inside.
Date: 25 Aug 2009 20:03:06
Message: <4a947bba$1@news.povray.org>
... which is exactly the difference we're discussing here: Whether
having meshes to default to a valid inside_vector would make a difference.
That's what I already mentioned in the first place, and commented on
possible solutions, in case you didn't notice. Here I just focused on
the speed issues.
