POV-Ray : Newsgroups : povray.programming : Alternative Box Intersection Algorithm Server Time
10 Jun 2026 17:27:13 EDT (-0400)
  Alternative Box Intersection Algorithm (Message 1 to 10 of 10)
Subject: Alternative Box Intersection Algorithm
Date: 14 Sep 2004 14:13:16
Message: <414734bc@news.povray.org>
In my studies of POV-Ray's source, I've discovered an alternative box
intersection algorithm.  This one is far less branchy and far less prone
to floating-point floatiness problems.
The only C++ compiler I have is Microsoft's (VS.NET 2003), so I'm not
able to compare the speed with the official version (which uses Intel's
compiler).  Theoretically, it should be faster because it's so much
simpler.  Some casual tests on image quality (like StackerDay.pov)
indicate that this has at least the same quality as the old code.
This is a complete replacement for the body of the Intersect_Box
function in boxes.cpp.
Thoughts and opinions are welcome :)
-Ryan
int smin = 0, smax = 0;    /* Side hit for min/max intersection. */
   DBL t, tmin, tmax;
   VECTOR P, D;
   /* Transform the point into the boxes space */
   if (Trans != NULL)
     MInvTransPoint(P, Ray->Initial, Trans);
     MInvTransDirection(D, Ray->Direction, Trans);
   else
     Assign_Vector(P, Ray->Initial);
     Assign_Vector(D, Ray->Direction);
   DBL tYMin, tYMax, tZMin, tZMax;
           //Based on http://www.cs.utah.edu/~rmorley/pubs/box.pdf
           //Credits go to Amy L. Williams, Steve Barrus,
           //R. Keith Morley, and Peter Shirly
           //for developing this technique.
           // Adapted for use with POV-Ray by Ryan Lamansky
           smin = SIDE_X_0;
           smax = SIDE_X_1;
           DBL //Provides a free way out of the negative zero problem.
                    divx = 1/D[X],
                    divy = 1/D[Y];
           if (divx >= 0)
                    tmin = (Corner1[X] - P[X]) * divx;
                    tmax = (Corner2[X] - P[X]) * divx;
           else
                    tmin = (Corner2[X] - P[X]) * divx;
                    tmax = (Corner1[X] - P[X]) * divx;
           if (divy >= 0)
                    tYMin = (Corner1[Y] - P[Y]) * divy;
                    tYMax = (Corner2[Y] - P[Y]) * divy;
           else
                    tYMin = (Corner2[Y] - P[Y]) * divy;
                    tYMax = (Corner1[Y] - P[Y]) * divy;
           if (tmin > tYMax || tYMin > tmax)
                    return false;
           if (tYMin > tmin)
                    tmin = tYMin;
                     smin = SIDE_Y_0;
           if (tYMax < tmax)
                    tmax = tYMax;
                    smax = SIDE_Y_1;
           DBL divz = 1/D[Z];
           if (divz >= 0)
                    tZMin = (Corner1[Z] - P[Z]) * divz;
                    tZMax = (Corner2[Z] - P[Z]) * divz;
           else
                    tZMin = (Corner2[Z] - P[Z]) * divz;
                    tZMax = (Corner1[Z] - P[Z]) * divz;
           if (tmin > tZMax || tZMin > tmax)
                    return false;
           if (tZMin > tmin)
                    tmin = tZMin;
                    smin = SIDE_Z_0;
           if (tZMax < tmax)
                    tmax = tZMax;
                    smax = SIDE_Z_1;
   *Depth1 = tmin;
   *Depth2 = tmax;
   *Side1 = smin;
   *Side2 = smax;
           return tmax > EPSILON; //Prevents same-point self-shadowing.
Subject: Re: Alternative Box Intersection Algorithm
Date: 14 Sep 2004 15:15:02
Message: <ci7fs3$ihf$1@chho.imagico.de>
> compiler).
Let me get this straight - you can't compare the speed because you can
only compile your patched version but not the unmodified code?
Concerning your code - you do:
   divx = 1/D[X]
without checking if D[X] is zero for example (the paper you cited
clearly states that it relies on the IEEE floating point standard for this).
Last updated 06 Jul. 2004 _____./\/^>_*_<^\/\.______
Date: 14 Sep 2004 16:03:07
Message: <41474e7b@news.povray.org>
Ryan Lamansky <Spa### [at] kardaxcom> wrote:
> Theoretically, it should be faster because it's so much simpler.
  Code simplicity is in no way a measurement of speed. (For example,
insertion sort is much simpler than quicksort, yet it's also much
slower.)
  I'm not saying your code is not faster, I'm just saying that you
should be careful on what you claim. :)
Date: 14 Sep 2004 17:58:52
Message: <4147699c$1@news.povray.org>
I can compile the original and the modified version of POV-Ray with
VS.NET 2003... but the results are inconclusive.  In my limited testing,
both builds look exactly the same, perform exactly the same (even with
the Vista Buffer off), and still lose to the Official version.
Despite much effort with compiler tweaking, I've never gotten a VS.NET
2003 build of POV-Ray 3.6 that defeated an official release.
>   divx = 1/D[X]
> this).
Yes.  The result of a 1.0/0.0 in IEEE floating point is
PositiveInfinity.  The math related to infinite values is interesting,
but doesn't break the algorithm in any way.
-Ryan
Date: 14 Sep 2004 18:20:01
Message: <ci7qp4$iac$1@chho.imagico.de>
But it does not work on non-IEEE floating point systems.   The C
language standards do not guarantee this to work like you expect it.
Date: 14 Sep 2004 18:22:32
Message: <41476f28$1@news.povray.org>
> slower.)
That's true, but in this case there simply isn't much work going on.  A
few ifs, a few comparisons, and a few math operations.  There's really
no way you can look at it and claim that it's slow :)
When I initially discovered this algorithm, I ran some tests on both the
  alternative and the original in C#.  The alternative one was more than
twice as fast in that environment.  Since the Intersect_Box function
could be called millions of times in a render, I was hoping to see
_some_ kind of improvement when converted to POV-Ray.
In spite of the mysterious absence of any performance difference, I
still think it's "good" code because it's much simpler, and it's much
more accurate since the EPSILON test is delayed until the very end.  A
possible drawback is that IEEE floating point behavior is required--I
don't have enough experience with the various POV-Ray-supported
platforms to know if this is a problem.
-Ryan
Date: 14 Sep 2004 18:24:17
Message: <41476f91$1@news.povray.org>
How about C++?
(I'm not trying to be sarcastic--I really don't know)
-Ryan
Date: 14 Sep 2004 19:07:31
Message: <414779b3@news.povray.org>
> How about C++?
  Most of the C standard holds for C++ as well.
Date: 15 Sep 2004 14:51:18
Message: <41488f26@news.povray.org>
In article <41476f28$1@news.povray.org> , Ryan Lamansky <Spa### [at] kardaxcom>
The algorithm you show is hardly any different for the miss case.  It
exchanges two divisions for one division and two multiplications in the best
case, but exchanges one divisions against two divisions and one
multiplication in the worst case for the first if/else block alone.
And all your code assumes division is so much slower that it can offset the
difference in the average case.  I seriously doubt it can by a serious
margin except for specially constructed cases because the average case is a
miss of a bounding box in a reasonably complex scene.
Your point about EPSILON is, well, pointless because you trade the division
by zero for the EPSILON comparison, which produces little if any gain in
precision.
However, I do agree that the complexity of the Z if/else with its case could
be better implemented.  This is something the algorithm you show has
optimized very well.  However, this is also the code most infrequently
executed.
I think the main reason you see no real difference is because there simply
is none to be measured.  The code parts that are better are not important
enough to show a difference in complex scenes, and simple scenes render fast
already :-)
If you are interested in optimizing POV-Ray, I would recommend to profile
first to find where most time is wasted.
    Thorsten
e-mail: tho### [at] trfde
Date: 15 Sep 2004 15:24:10
Message: <414896da$1@news.povray.org>
Most?? :-|
OK, I'm scared...
Andrew @ home.
Oh... wait a sec... I don't *use* C or C++... *relief*
