POV-Ray : Newsgroups : povray.pov4.discussion.general : Request: frame number in status and title bars Server Time
17 Nov 2025 09:40:36 EST (-0500)
  Request: frame number in status and title bars (Message 1 to 8 of 8)
Subject: Request: frame number in status and title bars
Date: 2 Jul 2008 21:00:00
Message: <web.486c23a336d6ae943cc4f9660@news.povray.org>
I would like to request that Povray state the frame number in an animation in
the status bar and title bar. When I run animations, unless I keep careful
track, there's no obvious or trivial way to tell (without maybe digging through
the messages window) which frame in the sequence the program is currently
rendering.
-Mike
Subject: Re: Request: frame number in status and title bars
Date: 3 Jul 2008 04:17:21
Message: <486c8b11$1@news.povray.org>
"SharkD" <nomail@nomail> wrote in message
news:web.486c23a336d6ae943cc4f9660@news.povray.org...
>in
> through
> rendering.
also, I would like to request the possibility to show an approximation of
how long the render will still take.  I know it wouldn't be accurate, but it
might give just an idea of how long we still have to wait for our reflective
spheres :)
cu!
Date: 3 Jul 2008 10:45:21
Message: <486ce601$1@news.povray.org>
>> in
>> through
>> rendering.
> spheres :)
> cu!
Actually, I bet POV could do a fairly accurate approximation by first
shooting one ray from each block, and figuring the speed based on those
tests.  That is, by sending out those test rays, it would know (roughly)
how long each block should take, and so could approximate the final
render time.
...Chambers
Date: 3 Jul 2008 11:43:49
Message: <486cf3b5@news.povray.org>
> render time.
  Too complicated. Much easier is to simply update the estimated time after
each block has been rendered with a simple formula like this:
ETA = total_blocks * time_so_far / bloks_rendered
Date: 3 Jul 2008 23:05:01
Message: <web.486d9299ecb9600e3fea8c830@news.povray.org>
A lot of times, the first and last few blocks render much more quickly than the
middle blocks if they are composed of mostly empty space.
-Mike
Date: 4 Jul 2008 06:44:18
Message: <486dff02@news.povray.org>
  No matter what you try to do, the estimation will always be off.
However, a simple algorithm like I described is very easy to implement
and contains basically no overhead whatsoever, and may be more useful
than nothing.
Date: 4 Jul 2008 15:36:41
Message: <486e7bc9$1@news.povray.org>
> than nothing.
In fact, if the blocks are rendered in random order (rather than across
rows like they are now), then area locality would have less of an effect
on the estimate, making it more accurate.
That is, many times local blocks have correlated render times, while
blocks that are separated by some distance have unrelated render times
(much like the Noise3D function that I'm so fond of :) ).  During tough
patches, the render time will be overestimated.  The corollary is that
in fast to render areas, the render time will be underestimated.  This
is compounded by having several slow-to-render or quick-to-render blocks
in a row.  Randomly picking between the blocks will alleviate this
(although I don't know what effect it will have on Radiosity).
...Chambers
Date: 25 Nov 2008 20:02:44
Message: <492ca033@news.povray.org>
> it might give just an idea of how long we still have to wait for our
> reflective spheres :)
I wrote a GUI extension for that :)
