>> Also look at nVidia's Gelato, they use the 3D card to help with
>> rendering, so it can't be all bad. Maybe there is some technical paper
>> somewhere about what Gelato does that would give some ideas for POV4?
> Gelato uses undocumented proprietary GPU commands on the cards.
> NVIDIA may (probably will) introduce new commands as hardware
> improves, making their products better, while public standards will always
> lag behind. It's just a matter of competition.
I was thinking more of just using the "standard" shaders rather than
programming the cards directly. AFAIK the shaders are available to program
in both OpenGL and DirectX, and will run on both ATI and nVidia cards.
Warp <war### [at] tag povray org> wrote:
> Allen <nomail@nomail> wrote:
> > Would it be possible to use the GPU as well as the CPU to render?
> The general answer is: No.
> - Warp
The general answer is: Yes.
"Gelato is a software program that leverages the NVIDIA GPU as a floating point
math processor. This allows Gelato to render images faster than comparable
renderers, but without the quality limitations traditionally associated with
real-time graphics processing on the GPU."
The *general* answer is yes and then you give *one* isolated case where
hardware is used for rendering by unknown (proprietary) means?
The general answer is still no.
"zeroin23" <zer### [at] gmail com> wrote:
> anyone looked at the below?>
> Last Updated: 10 / 11 / 2007
> http://developer.nvidia.com/object/cuda.html
Yes, I have. It has severe limitations in place that wouldn't affect game (or
many scanline renderers, for that matter), but which make it unusable for POV.
I'll take another look at it in a year or two, and see if its changed enough by
then. However, it's my personal prediction that for POV, the most efficient
course will be to wait for Intel and AMD to up the number of cores in their
chips (Intel has blabbed about the possibility of *thousands* of cores, while
AMD is being a bit more conservative in their predictions).
....Chambers
Search Criterion on Google: use the GPU as well as the CPU to render
If you click here:
http://www.google.com/search?q=use+the+GPU+as+well+as+the+CPU+to+render&sourceid=mozilla-search&start=0&start=0&ie=utf-8&oe=utf-8&client=mozilla&rls=org.mozilla:es-ES:unofficial
you find some of these:
2CPU.com - The one stop source for everything SMP!
(http://www.2cpu.com/story.php?id=3946)
BorisFX, HollywoodFX, and lots of other effects plug-ins use the GPU,
too. ... But even a single-core CPU can render most effects in
real-time, these days, ...
[PDF]CPU-GPU Hybrid Real Time Ray Tracing Framework
(http://www.uni-weimar.de/cms/fileadmin/medien/vr/documents/Dokus/rtrt-paper.pdf)
ing the overall rendering into five render-passes. We there-. fore use
the GPU wherever possible and only assign our fast. CPU Ray Tracing
algorithm where ...
[PPT]Implementing the Render Cache and the Edge-and-Point Image on ...
(http://www.cs.cornell.edu/~eva5/ppt/epiGPU06.ppt)
We wanted to use Vertex Texture Fetch (VTF) for mapping the point cloud
update but ... We presented a hybrid GPU/CPU system for the Render Cache
and the EPI ...
www.gpgpu.org :: View topic - Problem with CPU-GPU parallel processing
(http://gpgpu.org/forums/viewtopic.php?t=4783)
Hi, I am trying to render a bloodtree data set. I use both CPU and GPU
to do this. ...
[PDF]The GPU as a high performance computational resource
(http://www.math.sintef.no/gpu/pdf/Dokken_SCCG_2005.pdf)
CPU and GPU provided that the results can reside in the GPU. .... this
efficiently we use the GPU to sample and evaluate the
and there are other 9 pages on goggle over this.
looks like many people are doing it, all over the world, so i think the
general answer is: yes.
I think you are mistaken here. nVidia has lots of info about how to
program their GPUs, just go to the developer section, they have lots of
MegaBytes of info and a free developer enviroment, downloadable.
I read once that OpenGL was concieved as a multi-platform 3D manager for
3D GPUs, regardless the brand of the Video Card, so this could be useful
IMHO, I think also that anyway would be A LOT of effort to write
efficient code, to actually make a harmonious coordination with any
CPU/GPU combination. Among possible obstacles to solve:
-Calculate accurately the CPU-GPU latency.
-Calculate accurately GPU-RAM latency
-Calculate accurately CPU-RAM latency
-CPU-GPU coordination latancy.
I have also read that the GPU is been used as a second powerful math
co-processor, so I think POV-Ray should take advantage features like
this. Would be great for POV-Ray. It already gave a great jump to
paralelism in ver 4 I think we are half way to get to CPU-GPU paralell
rendering. Maybe there are some Open Source free-wares already on The
Net that could help in a practical way to embed this feature
faster/easier, who knows...
I just love this program, I only want THE BEST tech for it :)
In article <4796cbbb@news.povray.org>, sau### [at] netscape net says...
I am going to try to hit the main issues that always come up when this
idea is presented. I may miss some. However, the two ***key*** issues
here are:
1. Graphics cards are designed to operate using scanline systems, so 90%
of what they do is completely useless to POVRay.
2. Even the stuff they could be used for, they can't, because not all
features use the same floating point sizes, and no card currently
supports 64-bit floating point. This creates two problems. A) POVRay
would be limited to using one those floating point processes that "do"
use the same sizes as it does, for 32-bit systems, and b) for the 90% of
us who are *probably* at this point running on 64-bit processors, it
simply won't work at all, since there is no practical way to *fake* 64-
bit operation via such a card, which wouldn't add more overhead than you
reduce by using the card, and that **assumes** that you could make it
work at all, since the cards are not designed to do that, and code that
does do such things uses methods that are not easy to (and may be
impossible to) adapt to a graphics card.
Put simply, by the time full 64 bit cards come out, some up and coming
companies might be making POVRay almost entirely redundant anyway, by
using real raytracing on the card (at least one I know of is trying to
build one that will do that). So, its not possible now, and it might be
pointless when it becomes possible. You can be sure however that once it
does become possible, someone will figure out a way to take advantage of
it, in the same fashion as its now being redone to support multiple
cores.
void main () {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Uh? It's talking about video encoding. That is, converting a series
of still images into a MPEG-2/MPEG-4 stream. It has nothing to do with
raytracing (or even scanline rendering).
> algorithm where ...
Looks to me like theoretical "perhaps it could be done a bit like this"
experimental paper.
"The depth of reection is currently limited to one and due to the current
implementation our framework provides only one directional light."
"The overall performance of our framework closely depends on the amount
of secondary rays red by the Ray Tracer, while the GPU will mostly remain
under-worked. As a final result Figure 6 illustrates the computation times
of each render-pass and faces GPU and CPU. As expected the render-time is
limited by the CPU which obviously is the bottle-neck of our algorithm."
And as far as I can see this was a very specialized (and limited)
raytracing algorithms which only supports triangles and GPU textures.
Mostly useless for a generic raytracer like POV-Ray.
> and the EPI ...
It doesn't seem to be talking about raytracing at all. Also, whatever
it's talking about, seems to be limited to what the GPU supports, ie.
triangles and GPU textures. Mostly useless for a generic raytracer.
> to do this. ...
Is not talking about raytracing at all.
Is not talking about raytracing at all. Seems to be talking about how
the GPU might be used for things like image processing, solving
differential equations and linear algebra. These are completely different
(and, from the point of view of the GPU, much simpler) things than generic
raytracing.
Only one of the pages you listed talked about raytracing, and even it
was limited (only triangles, only GPU textures, the CPU as a bit bottleneck,
the example implementation supported only one reflection and one light
source). The rest had nothing to do with the subject.
Why you say no when CPU-GPU combos are been used in several applications
like I listed, ray-tracing or there are trends to use this combo to
solve problems so I think is a yes, maybe is in very early stages but
this is tending to evolve and could become common ground and open
source. Why are you so negative about it? What would make you think in a
yes?
