POV-Ray : Newsgroups : povray.off-topic : Radiance and irradiance question Server Time
1 Mar 2026 12:51:19 EST (-0500)
  Radiance and irradiance question (Message 1 to 10 of 11)
Subject: Radiance and irradiance question
Date: 14 Sep 2008 06:25:01
Message: <web.48cce3fb751daa7b33b2d9360@news.povray.org>
I have a question about radiance and irradiance in a very simple scene.
Let's have a scene with just 2 infinite planes: ground and sky. The camera is
somewhere between them so that both are visible.
The ground is pure lambertian surface (ie. totally matte surface, like a white
piece of paper).
The sky emits light evenly and let's say the outgoing radiance is 1.0.
(Actually, I'm not sure what is the correct unit to define this light source,
radiant exitance is probably correct?) And the camera registers that value as
pure white pixel.
The question is: what is the irradiance at each point in the ground? I guess it
should also be 1.0. So the sky should look identical to ground: pure white.
Right? This is the most important question as I need a reference scene to verify
my renderer.
But how do I calculate it?
The way to do it is to integrate over hemisphere at that point acording to light
transport equation. In 2D scene it would be I(1.0 * cos x  dx) and we have to do
it from -pi/2 to pi/2. Right?
The value of that is sin (pi/2) - sin(-pi/2) = 2. Hmm. Not right. Or is it? Most
likely I'm integrating incorrectly or the wrong thing.
Yes, I'm lost and my maths suck...but the correct result would help a lot.
Thanks,
Severi
Subject: Re: Radiance and irradiance question
Date: 15 Sep 2008 03:52:38
Message: <48ce1446$1@news.povray.org>
> light
> to do
> it? Most
You calculated the total light power collected at that point from all
direction (and hence the amount emitted assuming 100% reflectance).  The
correct answer is 2.  You'll get the same answer if you try to work out how
much light power is emitted from a point on the sky, in fact the integral is
the same.
Date: 15 Sep 2008 07:59:05
Message: <48ce4e09$1@news.povray.org>
>> acording to light
>> have to do
>> is it? Most
> how much light power is emitted from a point on the sky, in fact the
> integral is the same.
Ok. And in 3D the result is? Basically revolving "y=cos x" around y-axis
and calculating the volume. I have forgotten it but I'll figure it out
later...
If irradiance in above case is 2, what about the radiance than is
reflected from that point to a certain direction? (That is equal no
matter what the direction as it is lambertian).
Thanks for your help!
Date: 15 Sep 2008 08:25:58
Message: <48ce5456$1@news.povray.org>
No it's not equal, it's proportional to cos(x), that is what lambertian
means.  It then "looks" the same brightness to a camera/eye/surface from any
angle, because the area you see for each pixel/cone/rod/patch is
proportional to 1/cos(x), so the cos factor cancels out leaving constant
"brightness" from any angle.
In the case of irradiance of 2, the radiance is actually exactly cos(x),
because if you integrate cos(x) over -pi/2 to pi/2, you will get 2, as you
already found out.  So in fact your sky and ground are identically looking
planes (assuming the sky is not reflective at all), which you proved
already.
In 3D your radiance is now in units of power per solid angle per area,
compared to power per angle per area.  Lambertian still means that the
radiance is proportional to cos(x) (where x is the angle between the surface
normal and radiated/reflected light), it's just you need to integrate over a
hemi-sphere rather than a semi-circle.
For lambertian surfaces, in reality this just means that your units are
different and you only integrate from 0 to pi/2.
So in 3D, if you have a lambertian surface with radiance function 1*cos(x)
Watts/steradian/metre2, the total irradiance from a point will be 1
Watt/metre2.
Date: 15 Sep 2008 13:40:06
Message: <48ce9df6@news.povray.org>
> any angle, because the area you see for each pixel/cone/rod/patch is
> you already found out.  So in fact your sky and ground are identically
> looking planes (assuming the sky is not reflective at all), which you
> proved already.
> surface normal and radiated/reflected light), it's just you need to
> integrate over a hemi-sphere rather than a semi-circle.
> 1*cos(x) Watts/steradian/metre2, the total irradiance from a point will
> be 1 Watt/metre2.
Damn it. I have to chew on this one a bit. I need my renderer to give
accurate results and I want to be able to define light sources using
real units.
Now ssRay gives good looking results which are or are not accurate. I
have no way to verify it. I'll be back later...
Date: 15 Sep 2008 14:12:02
Message: <48cea572$1@news.povray.org>
> be 1 Watt/metre2.
All of human endevour is in here, my friends!
http://blog.orphi.me.uk/
Date: 15 Sep 2008 15:04:58
Message: <48ceb1da$1@news.povray.org>
I have to ask about this. Many sources say that radiance is analogous to
luminance. And they also say that luminance "is most often used to
characterize the brightness". Like here:
http://www.optics.arizona.edu/Palmer/rpfaq/rpfaq.htm
So that means radiance also describes "brightness"?? And lambertian
surface has equal brightness no matter where you look at it from if the
light source remains stationary.
So what is the deal here?
Date: 16 Sep 2008 03:39:03
Message: <48cf6297$1@news.povray.org>
> luminance.
OK sorry I didn't understand the radiance/irradiance thing (I usually work
with luminance and luminous intensity etc) - so I looked them up.
Illuminance is the same as irradiance, and describes how much power per unit
area hits a surface from all directions.  If you were dealing with infra-red
light, you could use this to work out how hot something got.
Luminance is the same as radiance, it describes how bright something seems
to be from a particular direction.  It tells you how much power is coming in
a certain direction in a certain area, it is directly related to how many
photons would hit a pixel in a camera or a rod in your eye (or anything else
with finite area).
Luminous intensity is the same as radiant intensity, this describes how much
power is emitted in a certain direction, but it says nothing about the area
that the energy is spread over.  So the same luminous intensity could be
coming from two planes, but because one is tilted differently from the other
the luminance would appear to be different.
For a lambertian surface, the luminance is constant from all viewing angles,
but the luminous intensity of each point depends on cos(x).
In your calculations, you can either use luminous intensity and factor in
for the geometry, or use the luminance directly and not worry about the
geometry.  The 1st will simpplify to the 2nd in most cases anyway, but I
don't know, maybe it is easier to understand the 1st case, or better for
later when you have non-lambertian surfaces, I don't know.
Date: 16 Sep 2008 17:15:39
Message: <48d021fb$1@news.povray.org>
Severi Salminen nous illumina en ce 2008-09-15 13:40 -->
> real units.
Just what do you call "real" units for your light?
Each and every "real" unit we use are totaly arbitrary, and somewhet dependent
on the method used to mesure them.
You can define the power and intensity of a given light several way, and
different light that have the same value for any given unit can look very different.
Just try to compare a 1000 LUX incadessent light bulb, sodium light, mercury
light, fluoressent light, and argon light. They all look different. Some will
look brighter, some dimmer, not counting the variation in colouration...
In fact, the sodium will probably look the brighter, and the argon one dimmer.
The yellow sodium keep your iris more open, while the bluish argon light will
cause your iris to contract a lot.
If you are good, you will be assigned all the work. If you are really good, you
will get out of it.
Date: 16 Sep 2008 17:26:37
Message: <48d0248d$1@news.povray.org>
> dependent on the method used to mesure them.
My point was that if I use real meaningful units I can verify that the
integration works properly. For example: if I have a theoretical light
source emitting certain power and a perfect lambertian surface, I can
check if the surface reflects the correct radiance. I didn't mean that I
would necessarily get more photorealistic images with those units. Well,
actually, I will, if using real units helps to solve errors.
Now I don't specify light sources that way and I can't verify the
results (and I do have some very possible errors now in the code...). I
only get pretty images and that is only half the fun :)
