POV-Ray : Newsgroups : povray.off-topic : solid assignment Server Time
10 Feb 2026 04:12:31 EST (-0500)
  solid assignment (Message 1 to 5 of 5)
Subject: solid assignment
Date: 4 Mar 2008 01:00:01
Message: <web.47cce4aa5d6af01e2a42a77a0@news.povray.org>
Currently I write a simple tool, which allows to split scenes in up
to 16 segments and let them render parallel(See the snapshot below).
After all segments has been rendered, the segments are automatic
build up to the general view.
In the past I wrote a similar tool for animations...so this is *not*
the problem to realize  it.
My problem is:
The program must check all running tasks. This is no problem, as long only
one scene is rendered. But I sometimes rendering more the one scene/animation
parallel. And so with this "Splitter"-tool something like this
will be "normal".
Example:
 scene 1  - running with 2 tasks  (PID 1202 and PID 1203)
 sence 2 -  runnning with 1 task  (PID 2078)
 scene 3 - running with 4 tasks    (PID's 3207 .. 3210 )
 animation - running with 2 tasks   PID's  3921 and 3922)
and all this is running at the same time.
To read out the PID of a task is no problem, but the method to identify and
assign a specific task to a specific scene in a *solid* way...this is my
problem.
So my question:
How can assign in a *solid* way, the  tasks to a specific scene/animation ?
Or does anybody know, where I can finde more infos (links, books) ?
btw.
I'm using LINUX
Download 'snapshot.png' (34 KB)
Preview of image 'snapshot.png'
Subject: Re: solid assignment
Date: 4 Mar 2008 03:59:17
Message: <47cd0f65@news.povray.org>
  I assume that means that rendering the scene takes 16 times as much
memory as usual?
  Isn't this kind of obsolete, as the new POV-Ray 3.7 supports parallel
rendering (and without taking any additional memory for that)?
Date: 5 Mar 2008 00:55:00
Message: <web.47ce3504bb3159a22a42a77a0@news.povray.org>
> memory as usual?
May be on Windows...but not on LINUX.
I never have seen more than 1.5 GB RAM in usage (AFAIR running 32 task)
No it isn't.
Date: 5 Mar 2008 00:59:37
Message: <47ce36c9$1@news.povray.org>
Not if you have multiple machines you can use for rendering. :-)  True
that the tool doesn't seem to have that functionality yet, but that would
be my first enhancement request - a job control system that let you farm
the job out to multiple networked machines.  (I know that's not a new
idea, though).
If you run in an environment that supports true clustered computing,
though, I could see this being helpful even without a job control
system.  I want to say Mepis provides this functionality (clustered
processing), but I might be thinking of something else.
Jim
Date: 5 Mar 2008 03:01:32
Message: <47ce535b@news.povray.org>
> > memory as usual?
  Well, if rendering a particular scene with one instance of POV-Ray
requires 44 MB of memory, rendering with 32 instances requires 1.5 GB.
It's not a question of how much the total memory usage is, but how much
it is compared to running only one instance.
  POV-Ray 3.7 can render that same scene using 32 threads and it will
only require the 44 MB of memory.
  Or are you saying that you can run 32 instances of POV-Ray 3.6 without
it requiring 32 times as much memory as running 1 instance? Exactly how
does it achieve that feat?
> No it isn't.
  What does it do that POV-Ray 3.7 doesn't (besides consuming more memory)?
