POV-Ray : Newsgroups : povray.off-topic : New LuxRender web site (http://www.luxrender.net) Server Time
22 Mar 2026 22:12:18 EDT (-0400)
  New LuxRender web site (http://www.luxrender.net) (Message 61 to 70 of 175)
Subject: Re: New LuxRender web site (http://www.luxrender.net)
Date: 20 Feb 2008 16:38:07
Message: <47bc9dbf$1@news.povray.org>
Severi Salminen wrote:
> Mike Raiford wrote:
>> You didn't answer his question. I'm also curious about render times, but
>> you completely dodged the question.
> See the indigo site gallery. Some captions include render time. Of
> course that tells you nothing about how good/bad the image looked in
> less time. Remember that with brute force you see a lot even after 1 minute.
How long do you have to wait before the graininess has reliably become
unnoticeable?  That's a question I need an answer to before I can use
any unbiased renderer for animation work.  I need a renderer that won't
give me a picture unless the quality is consistent from one frame to the
next.
With scanline and ray-tracing renderers, there comes a specific point at
which the renderer is *done* with the image and is ready to render the
next image.  Unbiased renderers are never really done; they just go
until the user decides the quality is good enough.  Sure, the user may
be able to set the renderer to go only a certain amount of time, but
except for a very short clip, and only after rendering a couple of
frames in that clip, can the time required for each frame be predicted
with any meaningful reliability.
John
Date: 20 Feb 2008 16:44:49
Message: <47bc9f51$1@news.povray.org>
On the only unbiased renderer I used, it uses passes. Being *based* on
random numbers (shooting rays in random directions), of course the time
each pass takes is non-deterministic, but you surely could render the
same number of passes for all frames (instead of leaving it the same
amount of time), and you would get approximately the same amount of
noise on all.
Subject: Re: Brute force renderers
Date: 20 Feb 2008 17:22:04
Message: <47bca80c$1@news.povray.org>
Nekar wrote:
> Do scientist completely understand all the
> properties of light?
Pretty much, yes. :-)
     On what day did God create the body thetans?
Date: 20 Feb 2008 18:29:34
Message: <47bcb7de$1@news.povray.org>
news: 47bc9dbf$1@news.povray.org...
> unnoticeable?  That's a question I need an answer to before I can use any
> unbiased renderer for animation work.  I need a renderer that won't give
> me a picture unless the quality is consistent from one frame to the next.
I saw a commercial (an animation of course) rendered with MaxwellRender the
other day on TV so whatever theoretical problems exist with unbiased
renderers and animation seem to be have been solved in production (perhaps
with the help of a large render farm, but that another issue...). IIRC
there's a page about animation in the Maxwell manual, you can look it up
(it's free for download).
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 20 Feb 2008 18:30:40
Message: <47bcb820@news.povray.org>
47bc9c10$1@news.povray.org...
> If you buy top hardware, model, texture, and drop accurate lighting in
> your scene, PoV can do it, too.
> The trick is the accurate lighting.  It's not impossible to do in PoV.
Unfortunately, it is.
POV can do a lot of things, but there are many common lighting situations
that are just out of reach from a practical point of view. It's not just the
lighting model, but also the texturing model that is insufficient.
When I was busy playing with POV, the key to get good images was to
precisely to avoid these kind of lighting/texturing situations. There are
things that POV sucks at rendering unless one spends a lot of time trying to
find workarounds (or brushing off artifacts...).
The area_illumination feature that Warp introduced in the latest 3.7 beta is
one of those things that the previous versions couldn't do: of course one
could simulate it with grids of point lights, but it was just too
impractical for common usage. Another feature that is sorely missing is
efficient blurred reflection. There's a trick to do that in POV but the
results are usable in only certain (limited) circumstances. In modern
renderers, blurred reflection can be applied to all the materials in the
scene, thus allowing correct specularity and (inter-)reflections, and this
adds tremendously to realism.
The beauty of using more advanced renderers (biased or unbiased) is that
those blocks no longer exist, either because the results are accurate from
the start (unbiased) or because they are lots of optimisations for speed
(biased). Just describe accurately your lights and materials, and the system
works out of the box.
G.
- Posters
Date: 20 Feb 2008 19:02:30
Message: <47bcbf96@news.povray.org>
> unnoticeable?
  I wonder if an automatic measurement and then a threshold couldn't be
developed. For example, if a given pixel hasn't changed color for the
last n rays which have affected that pixel, then that pixel is done.
When all the pixels fulfill this requirement, the image is done.
Date: 20 Feb 2008 19:04:47
Message: <47bcc01f@news.povray.org>
nemesis <nam### [at] nospamgmailcom> wrote:
> >   POV-Ray is simply a great tool to create "3D'ish" images like those.
> > It's easy and fast.
> so, pov-ray will end up its days as a 3D button design tool?  Are
> pov-ray users ok with that evolutionary idea?
  Why are you trolling?
Date: 20 Feb 2008 19:12:41
Message: <47bcc1f9@news.povray.org>
Btw, does unbiased rendering support volumetric lighting? I can't find
any example image in this site nor int the indigo gallery.
Date: 20 Feb 2008 22:27:53
Message: <47bcefb9$1@news.povray.org>
Impossible and impractical are not the same thing.  Impractical is fine
for us geeks with lots of time to fiddle on our hands.  XD
Ah, I missed reading that 'efficient' bit when I hit reply.  The blurred
reflection that you can do in POV is physically accurate per
'micronormals are how you get blurred reflections anyhow'.
'course, until the next version of Moray gets released, I'm stuck with
good old POV 3.5 anyways...
Tim Cook
http://empyrean.digitalartsuk.com
Version: 3.12
Date: 21 Feb 2008 00:42:02
Message: <47bd0f2a@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:47bca80c$1@news.povray.org...
But not _perfectly_. if they understood light perfectly there wouldn't be
any search for unified field theories, etc. :o]
- Nekar X -
