POV-Ray : Newsgroups : povray.off-topic : This is another "free" unbiased engine: Indigo Render Server Time
20 Mar 2026 23:19:13 EDT (-0400)
  This is another "free" unbiased engine: Indigo Render (Message 25 to 34 of 54)
Subject: Re: This is another "free" unbiased engine: Indigo Render
Date: 27 Oct 2007 12:53:22
Message: <47236d02@news.povray.org>
"Orchid XP v7" <voi### [at] devnull> wrote in message
news:47234bd4$1@news.povray.org...
> Gilles Tran wrote:
> > The problem being that doing equivalent scenes in POV-Ray (particularly
> > interior scenes) is, from a practical point of view, impossible. Light
> > sources in POV-Ray are much too primitive for that, there's no support
for
> > true area lights or good-looking blurred reflections and while there are
> > situations where it's more or less possible to simulate this (using
various
> > tricks), in most cases it just doesn't work.
> Wait... since when does POV not have "true" area lights?
Since always. Area lights are implemented as arrays of point lights
Date: 27 Oct 2007 13:10:54
Message: <4723711e$1@news.povray.org>
> Is it possible to automatically know when a scene is good enough? Or
> does it take human intervention to say "ok, stop now and move on to the
> next frame"?
On the only forwards-raytracer I have ever used (WinOSi), the rendering
algorithm is two passes inside an infinite loop. You stop it when you
want to. You can also render for a while on different computers, and
*merge* the results.
Date: 27 Oct 2007 13:13:20
Message: <472371af@news.povray.org>
  I wouldn't say there's too much difference between having, technically
speaking, an array of (perhaps jittered) point lights and randomly shooting
samples towards an area light. They are extremely similar ways of doing
the same thing, although the minor differences introduce advantages and
disadvantages to both methods.
  A randomly-sampled "illuminating object" can have any shape, form,
brightness variation and surface coloration whatsoever, without any limit.
You can simulate this to some extent with the point lights idea, but with
very large free-form shapes it can become quite inefficient because you
would need hundreds if not thousands of point lights, and freedom of form
makes it more difficult to implement adaptive sub-sampling.
  OTOH a grid of point lights becomes much more efficient if the physical
size of the area light is small. The smaller the area light, the more
efficient it becomes compared to random sampling (because if the light
source is very small, the vast majority of random samples will miss it).
  Both methods suffer from speed/graininess tradeoffs. The less grainy you
want the result to be, the more it takes to render (even though the light
grid method becomes the faster the smaller the area light is).
  Perhaps the best "true area light" lighting method is radiosity (the
algorithm called "radiosity", which is related to calculating lightmaps,
not the stochastic sampling method used by POV-Ray), even though in this
case it's also a discrete sampling method because you are basically
calculating light maps which have a certain pixel resolution. The end
result are completely grain-free regardless of this resolution, though.
(The only artifact caused by low sampling is unrealistic smoothing).
This also suffers somewhat if the area light is very small, although not
nearly as badly as random sampling. (Another problem with radiosity is
that it cannot be used to calculate specular reflections caused by area
lights.)
Date: 27 Oct 2007 13:20:19
Message: <47237353@news.povray.org>
> Why one more? Programs like PBRT were designed from the ground up to support
> multiple approaches to solving the rendering equation, and it shows in the
> code. POV wasn't, in fact it's tedious enough to make even minor
> alterations to the way it currently works.
I said it on other threads, but why not repeat: I would like POV-Ray to
support adding rendering algorithms with similar ease as adding objects
or patterns or camera projections. As long as it involves shooting rays,
it would be compatible with all existing objects and pigments. Finish{}
would need to be customized for each lighting algorithm, and some
algorithms can't use normal perturbations, but pigments should work.
I want a forward raytracer with the power of existing POV-Ray SDL and
CSG. And isosurfaces. POV-Ray with an unbiased renderer "plugin" seems
like the best candidate; better than rewriting the SDL parser and
isosurface code on an existing unbiased renderer...
Date: 27 Oct 2007 13:26:42
Message: <472374d2$1@news.povray.org>
> Even with the grain, the quality of the illumination in unbiaised renderers
> is unparalleled, simply because there's no cheating involved.
Question is : is that kind of algorithm "compatible" with a
'traditional' ray-tracing engine (like POV-Ray), so that radiosity
and other features could be treated that way, or would it be
like two different renderers in one ?
Could POV-Ray, in some future, integrate these algorithms without
a complete core change ?
Fabien.
Date: 27 Oct 2007 14:06:43
Message: <47237e33$1@news.povray.org>
Orchid XP v7 wrote:
> Tom York wrote:
>> What unbiased methods give you is certainty. If you leave them long
>> enough
>> they *will* approach the true solution.
> So will POV-Ray's radiosity system, if you turn the settings up high
> enough. (And wait a damn long time...) Your point?
Except you can't.  Turn the settings up high enough, that is.  POV 3.5
has a hardcoded limit of 1500 radiosity samples.  Which hopefully will
be (has already been?) fixed by the next version that has a compatible
Moray to use with it.
Tim Cook
Version: 3.12
Date: 27 Oct 2007 14:07:22
Message: <47237e5a$1@news.povray.org>
Indeed...repeat.  This time I got it.
Date: 27 Oct 2007 15:11:35
Message: <47238d67$1@news.povray.org>
And this is observably different how, exactly?
Also, what about radiosity with a big square on the ceiling set to have
a nonzero ambient figure?
Date: 27 Oct 2007 16:57:30
Message: <4723a63a@news.povray.org>
My memory of the algorithm is that you could build it in a way that let
the areas with lots of detail have finer resolution than the areas with
less detail, and still get all the benefits of the "real" radiosity
algoritm. Am I mistaken here?
     Remember the good old days, when we
     used to complain about cryptography
     being export-restricted?
Date: 27 Oct 2007 17:25:09
Message: <4723acb5$1@news.povray.org>
47238d67$1@news.povray.org...
> Also, what about radiosity with a big square on the ceiling set to have a
You still won't get specular highlights. Unless of course you give every
material the physically correct blurred reflection necessary to obtain
specularity. Good luck with that.
G.
