POV-Ray : Newsgroups : povray.off-topic : Help! Server Time
18 Mar 2026 22:30:48 EDT (-0400)
  Help! (Message 11 to 16 of 16)
Subject: Re: Help!
Date: 30 Apr 2008 11:37:33
Message: <4818923d$1@news.povray.org>
Patrick Elliott wrote:
> Would have probably made a HUD for that if I was doing it,
HUDs came out about a month after I gave up. :-)
> or secluded people so they couldn't "see" outside their spot,
I made them sit in a chair, and stay in mouse-look mode, and ended the
game if they stood up or left first-person mode.  But it was a pain in
the butt, moreso than actually writing the game.
Even genning up the game board was annoying, because it had to be made
from a board, two chairs, and 25 playing pieces on each side, so if the
plot was close to full, it would fail to create things halfway through
and you couldn't tell.
> pay to "upload" the result to SL. Thought it would be a nice solution to
> something I considered doing, but... What a fracking pain.
Strange. I read on their blog recently you could just use Bryce to make
some geometry and use it. Maybe I misunderstood, or the article wasn't
completely clear.
> Things are improving though, especially now that the client in open, but
> there are just some things that are damn stupid still, and no idea when
> they might be fixed.
Yeah.  Like I said, interesting idea, suboptimal execution. At some
point, someone will get it right and eat their lunch.
     "That's pretty. Where's that?"
          "It's the Age of Channelwood."
     "We should go there on vacation some time."
Subject: Re: Help!
Date: 30 Apr 2008 11:38:53
Message: <4818928d$1@news.povray.org>
Nicolas Alvarez wrote:
> Btw I got that image from an email my dad forwarded me, asking if I knew
> what the hell SecondLife was :P
http://www.getafirstlife.com/
Subject: Re: Help!
Date: 1 May 2008 00:45:31
Message: <MPG.2282f8b8e15ace7098a152@news.povray.org>
In article <4818923d$1@news.povray.org>, dne### [at] sanrrcom says...
Ah..
o
> completely clear.
Maybe you could. Bryce may actually export the correct sort of tri-color
png file needed to do it. I will have to look at that.
t
Well, they spent a lot more time thinking about how to get the data to
and from the client and run sims on servers, than they did making the
client work. I would have imho, done things more the other way around
(or found someone that had a clue to work on the front end, while I
worked on the back).
void main () {
    if version = "Vista" {
      call slow_by_half();
      call DRM_everything();
    call functional_code();
  else
    call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Subject: Re: Help!
Date: 1 May 2008 11:29:10
Message: <4819e1c6$1@news.povray.org>
No question it's a difficult problem. Making a 3D world with physics
that you can have multiple players manipulating stuff they themselves
created and wrote the interaction code for? Awesome.
Business model where you're actually selling what costs you money and
enlisting the aid of people paying you to create more value? Awesome.
It's just really hard to program some sorts of things because you *have*
to deal with the physics, and their security model sucks. Everything is
independent once you create it - you can't have two parts of one object
communicate with each other except by actually talking out loud within
earshot of the other part. There's no simulation of "wiring" or "radio"
or anything (I know about the channels - not the same thing), and things
have to move by actually moving at some fixed maximum speed. Plus, as I
said, since they're independent, there's no good error recovery. You
can't, for example, make a button on a machine that changes a picture
from a plus sign to a circle when you push it and also causes some other
object to run a script without the player being able to overhear the two
items whispering back and forth.
Plus, to prevent abuse, they had to make it a PITA to affect any player
with any sorts of restrictions on what they could do. They should have
had a mode where you get prompted once "can I take over your character?"
If so, then the script can do whatever it needs until you issue some GUI
command like "take me home", at which point you go back to the state you
were in when you gave permission to the script. *Then* you could do cool
kinds of interactive fiction/story, rather than just having interactive
environments.
That's why the vast majority of everything interactive is either dance
balls or vending machines selling dance balls.
I wanted to build a jumpman type game, but there was no way to make it
work - no way to set the weight of the character, or keep them from
flying or setting teleport points, or etc.
Altho some of the costumes were really awesome. :-)
Subject: Re: Help!
Date: 1 May 2008 23:10:17
Message: <MPG.228433e3c665909e98a153@news.povray.org>
In article <4819e1c6$1@news.povray.org>, dne### [at] sanrrcom says...
You have been out for a while then. lol For example, the stargates have
three prims that do things, at minimum, some have at least 6 others, and
they do talk to each other "without" you hearing them chat at all. Not
sure the maximum speed thing is a problem any more either. I am not sure
if error handling is possible yet, but there is a "script error" window,
for when things fail. Just not sure if it works internally to the script
too. I think a fair number of these things where corrected along with
the adding of huds and menus, where you obviously don't want the
hud/menu "talking" to the item to make it do anything. Again, using the
stargate as an example, you can either tell the gate "/d SGC", or, if
you know the address and there is a DHD there, you can actually click
the buttons on the DHD. Each one, without whispering or showing visible
text at all, will send data to a script, which then lights the panel for
that, and if you have 6 lit and press the center button, it will attempt
to "dial" that, again, talking to the gate, without you seeing anything
at all, other than the gate saying, "Dialing SGC". Note, this is also,
somehow, linked to a DB on Alpha Fox's website, which keeps track of
active gates, so that when you dial the address, it knows where the gate
in that "region" is, and can send the gates event horizon a "location".
When you click on the horizon, you get the map location shown for where
the gate is, and can then teleport. Supposedly there is an up and coming
script function that will also allow llteleportagent, which will just
teleport you direct, so you would just detect collision with the event
horizon and have it go "llteleportagent(123,456,789)", or something like
that.
But the limitations you are talking about... Don't exist anymore.
Hmm. Mind you, the communication between them "may" still be talking,
but if so, its like channel -900000 or something, so, its hidden from
view for anyone that can't "see" the channel in question.
Mind you, however it "does" work, there must be some bugs. Tried to
install a script to have the event horizon automatically give me a map
link, so I could come "close" to what its supposed to do, but either the
existing script in the object messed it up, or it just doesn't work
right. :(
> environments.
You mean, like a pose stand. Bought a swim override recently that way,
you click "pose" on the menu, it moves you up onto the platform and
places you in the right position, then starts the animation. Some of
them will "ask" if you want to allow certain things too. When you want
to leave it you just use the menu, or a button at the bottom of the
screen, which says "stand up", works just like the pose balls, but with
more control. There is also huds like the Zhao which store overrides for
your motion, so you can have better walks, etc. You drop them into the
device, change some settings in the note card in there, then wear it,
click load, and now you don't walk like everyone else does. It can
override all of them. The only gripe I have is that it takes over your
keys, so if you also wear one of the "flight assist" devices, which do
the same, then clicking "release keys" to remover the assist also kills
your animation overrides. Sigh...
You can now set an area to disallow flying, as well as preventing
teleports.
I think you would find that while there is a lot the same as you
remember, there is a *lot* that is different too now.
void main () {
  else
Subject: Re: Help!
Date: 2 May 2008 12:33:01
Message: <481b423d$1@news.povray.org>
Possibly. It's possible to "whisper" on a separate channel, but it's
also possible that anyone nearby can hear the whisper *if* they listen
on that channel. That might be how they're talking.
Well, sure. That's unhelpful when you want the game to (say) show the
gun as overheating when it can't create new bullets or something.
Probably talking over channels, of which there are 2^15 or something if
I remember. If you knew which it was using, you could probably overhear
it talking. Definitely not good for things like poker tables talking to
the cards and the pot.
 > Note, this is also,
Most likely email. Or at least that's all that was available last I
looked. That's also how you get information between components if
they're too far apart to hear each other talking.
OK.
That's what I mean. If you know the channel, you can hear it (which is
*bad* for a game where money is an actual component), and if the parts
are too far apart, suddenly you have to switch to an entirely new
communication mechanism. If you have a button at one side of the sim
that opens a door at the other side of the sim, you actually have to
talk via email between them, because you can't "shout" loud enough even
on a channel. Makes something like Jumpman difficult.
Plus, you have to listen for properly structured "sentences" and parse
them out to understand what to do.
> right. :(
That was my other complaint. Plus, "community-supported wiki" is really
geek-speak for "we can't be bothered to document our system."
Yeah. Stuff like that.
> teleports.
You could do that before, but only if you actually own the land where
you set up the game.  And I realized the physics would make it
challenging, too, when someone decides they're really big or really
small, for exmaple.
I'm sure it has improved greatly, yes. Do I have time to keep up with
such things for fun?  Sadly not. :-)
