![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hehehehe, white-out!
Now we have some "snow" worth talking about. Roughly 12 cm or something.
The roads have vanished under a carpet of white. (At least, the roads I
can see.) And, unsurprisingly, a number of road traffic accidents have
gridlocked most of the road system. So apparently I'm staying at home
today. :-)
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
More snow is falling. Unlike yesterday, this time my dad decided we
would attempt to get to work today.
Usually that takes 1 hour. Not today. Every time we reached a hill,
there was a lorry at the bottom of it spinning its wheels. We managed to
illegally overtake a few of them, but then we'd drive a mile or so and
hit another 4-mile traffic jam behind another lorry stuck on another hill.
At 9:30 AM we decided to turn round and come home. Except the route we
came by was now blocked as well. We got less than half way to work, and
it took until noon to get back home again - several times longer than
the outbound journey. :-D
Oh, and we also helped a damsel in distress on a deserted backroad we
found. She was sitting in her heavy car with its powerful engine,
spinning the wheels. Me and my dad were able to rock the car until it
attained traction. (I make it sound easy. It wasn't. My office shoes
have no tred; they are flat at the bottom. I couldn't get any traction
to push with.)
While I'm here, can we straighten this out? I was under the impression
that the correct way to drive in snow is the following:
- The correct way to get traction is to turn the wheels as slowly as
possible, not spin them at maximum power.
- If your car skids, turn into the direction of the skid.
- If you skip under braking, ease off the brakes. If you skid under
acceleration, reduce power a little.
- If you need to go up hill, do it fast so the momentum will carry you
over. (I saw lots of people slowing down for the hills in case they
skid, or trying to go up a hill from a stationary position.)
Can anyone confirm or refuse these claims?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's about right, yes.
"Ouch ouch ouch!"
"What's wrong? Noodles too hot?"
"No, I have Chopstick Tunnel Syndrome."
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yes, that is correct. Spinning the wheels will generally dig you in
deeper.
Correct, but you have to be careful not to over-correct, lest you hit a
dry patch on the road and spin the car. I did that and ended up in the
ditch, once - after doing a 360 in one direction and then a 720 in the
opposite.
Well, brakes tend to be "on or off", if you don't have ABS, pumping the
brake pedal generally works well, but also if you can drop to a lower
gear, do that. Don't do anything that would normally cause a fast change
in speed because you'll lose control.
What I do on ice if accelerating is take my foot off the gas and drop the
car to 3rd gear (I drive an automatic, but this works in a manual
transmission car as well). Don't touch the brakes, because in general it
won't do anything but cause you to lose control.
I also will occasionally tap the brakes to see if the car will slow
down. It's important to do this while the wheels are pointing forward,
though; if you do this and have the wheels turned, you could spin out of
control if the circumstances are right.
It depends on the hill. If you go fast and there's a stop sign at the
top of the hill, your chances of blowing through the intersection are
really good, and there's always a chance when you do that of running into
cross traffic if it's not a 4-way stop.
The best option is to find a different route if you encounter an icy hill
- up or down.
The important thing when driving on ice is to not make any sudden changes
- sudden turns, slamming on the brakes, fast acceleration - all of these
can cause a loss of control.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> deeper.
And yet, the girl we helped had her big, powerful BWM running at maximum
revs. Perhaps she thinks if she revs it fast enough, eventually it will
have some effect?
(Logically, if you spin the wheels long enough, you'll dig down to where
the road is. Unfortunately, you now have to drive up a rather big hill
to go anywhere...)
Anybody remember Ice Cold in Alex? Didn't they do something weird like
put the car into 1st gear and turn the starting crank to make the wheels
turn *really* slowly so it wouldn't disturb the sand?
> opposite.
Well, the incidents I whitnessed today all happened at around 5 MPH or less.
So not "OMG, I'm skidding, MAXIMUM BRAKES!!" then?
We're talking about hilly country roads that go on for miles without any
junctions.
And yet, almost every person I observed either immediately slammed on
the brakes, or started wildly trying to correct the steering.
Jesus, people don't know how to drive in the snow... And this is...
England?? O_O
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> deeper.
> have some effect?
Well, yeah, a lot of people have mistaken ideas about a lot of different
topics.
I suppose the logic is that if you dig in deep enough, you'll hit the
real ground and the car will have enough momentum to jump out of the
hole. That can happen, but it also can be quite dangerous.
> to go anywhere...)
Yep (guess I should've read a bit further, eh?)
>> opposite.
> less.
Yeah, it doesn't take much. I spun out going onto a motorway, hit a
patch of black ice while accelerating, and then overcorrected.
Experience is a good teacher, but some things shouldn't need to be
experienced. ;-)
>> change in speed because you'll lose control.
Exactly. Yet a lot of people's instinct is to slam on the brakes. It's
not always a conscious thing, though - and it's the sort of thing you
have to be aware of as it happens.
There's been a couple of very public examples of not freaking out under
extreme life-threatening pressure lately: The guy who was in a tandem
skydiving jump when his instructor had a heart attack and died, and the
plane that went down in the Hudson river.
In both cases, the person in control (the student jumper in the skydiving
incident, the pilot in the Hudson incident) didn't freak out, but
remained calm. The skydiving student had military training and that just
kinda kicked in from the reports I've read of his account. The pilot did
ditch the plane in the river - which given the situation was better than
hitting a residential section, and he managed to keep the plane level.
IIRC there were some minor injuries, but all 55 passengers and the crew
survived his "water landing".
This same need to remain calm carries into driving on slippery roads.
You need a good situational awareness as well - keeping yourself from
skidding out of control does little good if some lunatic runs into you
because they're not there.
The best place to be when the roads are slick is not on the roads,
obviously, but keeping an eye out all around (which requires very intense
concentration IME) is important so if someone's driving like a lunatic,
you're not in their way by the time they get to you.
>> into cross traffic if it's not a 4-way stop.
> junctions.
Well, having driven on country roads such as you describe in England, I
observed that they rarely have long straight stretches; going fast on a
slippery winding road also doesn't help.
Actually, there's a drive I took in New York State (north of NYC) where I
was teaching a class a few years ago. Ran into slippery, winding, snow-
packed country roads to get to the site (a school, oddly enough), and the
rental car was from Georgia with all-purpose tires (not winter driving
tires). It took me about 90 minutes to go 10 miles, I just put the car
in low gear and let the engine do the work, giving it very little gas the
entire way.
Up hills, down hills, around corners, etc. Fast wouldn't have helped
there because of the lay of the roads.
>> changes - sudden turns, slamming on the brakes, fast acceleration - all
>> of these can cause a loss of control.
Yep. Every year at the beginning of the winter season, I observe what
I've come to term "vehicular darwinism" - people with big 4x4 vehicles
driving like lunatics and letting their instincts/reactions guide them
straight off the road. Sometimes with very bad results, usually with
slightly bad results.
> England?? O_O
Well, your weather tends to be pretty moderate; driving on snow and ice
is something that can improve with practice, but in England you don't get
a lot of practice.
I learned to drive on packed snow and ice - and when you're doing your
behind-the-wheel instruction in those circumstances, the experience is
very different. There were days my entire lesson was "get the car from
the high school to your house" (about 15 miles).
Learning to drive in that situation also had a downside - I couldn't
correctly judge stopping distances on dry pavement properly because I'd
had no practice at it at all. I learned quickly, of course, but the
first time I tried to stop on dry ice-free roads was interesting, and
even kinda funny. Fortunately, I didn't run into anything/anyone.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> opposite.
>> less.
I mean, I don't support you're that likely to spin the car when it's
barely moving to start with. Just slide into the curb, really. (Or into
some expensive car, at least...)
> experienced. ;-)
Like practicing how to repair a punctured lung using only a coat hanger?
Yeah, well... some people don't seem to realise that this is even the
wrong response.
>> junctions.
Well, it all depends.
In Switzerland, the mountain roads are under snow for half the year, and
nobody seems to care much. OTOH... snowchains?
>> England?? O_O
> a lot of practice.
I guess that's the thing. When I was a child, it used to snow *every
year*. As in, the whole country would be under perhaps a foot or so of
snow for at least a few weeks every single year. There was so much snow
you could actually build a snowman.
These days, some years there isn't even any frost, let alone *snow*!
Every time I see a snowman, it looks very anemic - because nobody can
find enough snow to do it properly! ;-)
Which reminds me... the last time it really snowed properly, I was still
at school. It was about, I don't know, 30 cm or so, varying from place
to place. Anyway, being very bored schoolkids, somebody starting rolling
snow, and... well I think we used the *entire* football pitch. Do you
have any idea how much snow there is in an area that large??
By the end of it, half the school was rolling this boulder of compacted
ice along. We rolled it down the hill - Jesus, if anybody had been in
the way, they would have been killed! - and we dumped it into the school
pond. Man, it was like a nuke or something! One hell of a splash! ;-)
It took about 4 weeks for that ball to melt completely...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>>> a dry patch on the road and spin the car. I did that and ended up in
>>>> the ditch, once - after doing a 360 in one direction and then a 720
>>>> in the opposite.
>>> less.
Depends on the ice. I've seen cars spin out at low speed. They spin
slowly, but they can spin out.
>> experienced. ;-)
Yeah, that's a good example. ;-)
>> It's not always a conscious thing, though - and it's the sort of thing
>> you have to be aware of as it happens.
> wrong response.
That's because they don't think about it, they just react on instinct.
Their instinct is "if I press the brakes hard, I will stop". Add to that
a lack of experience that is contrary to what their instincts say, and,
well, there you go....
>>> any junctions.
Snowchains can help, but only in the right circumstances. Using them on
dry pavement is really bad - for the tires, for the roads.....
But also, in places where snow is on the ground a lot, people have
adapted to learn how to drive in the conditions.
>>> England?? O_O
>> get a lot of practice.
See, a foot of snow isn't a lot compared to what I grew up in - we could
tunnel under the snow and make forts. Which of course these days is
described as incredibly dangerous, and it probably was back then too, but
we lived to tell the tale.
And the snow was persistent from when it started in early November
through March. Not just a couple of weeks a year, but for months on end.
:-) Right now the landscape here in the state where the license plates
declare "The Greatest Snow on Earth" is pretty anemic. But the base in
the mountains is 75-100".
A lot. Cubing stuff (any stuff) tends to make the numbers big. :-)
That sounds like fun. :-)
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> gear, do that.
Watch out though when changing down (in a manual), you might lock the driven
wheels if you let up the clutch too quickly, in a rear wheel drive car this
can give you a good wake up call :-)
> down.
Yep this is good advice, when it's safe to do so then *try out* how much
grip you actually have, this will avoid a big surprise later up the road
when you really do need to stop or turn quickly.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Having a rear wheel drive car makes it vastly easier to spin around. In a
front wheel drive car you are more likely to just go straight in a corner
and hit the barrier/curb, in a RWD car you are more likely to end up facing
the wrong way.
> wrong response.
If you want to stop your car actually spinning around and are happy for it
just to carry on sliding in a predictable manner then slamming on the brakes
is the best thing to do. If you don't then at some point the car will get
some grip back and make some sudden movement you probably weren't expecting.
Depends on the situation of course, but it's wrong to say never brake if you
are skidding.
And thick snow is predictable, patchy ice isn't.
Sorry, but IIRC I'm roughly the same age as you and I certainly don't
remember it ever being like that. I can remember ONCE when we had as much
snow as you seem to have had recently, that was the only time I got to see a
snow plough come down our road. Certainly it never lasted for more than a
day or two, and certainly not every year.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
