Le 31/01/2011 21:24, stbenge a écrit :
> Thank you all for your input! I'd still like to hear any comments you
> might have, if you can take the time.
I spent more time with it, and it is really fascinating ! It looks a lot
like some sort of physical/biological process. If you can give some
qualitative information on the way the algorithm works, I'll be very
interested. A few things I like particularly:
- the different 'timescales' : after a click with the mouse, there is
the rapid process destroying the cell, but the system takes a long time
to reach a steady state as a whole
- I enjoy a lot when 'thin white lines' enter a big cell, and propagate
slowly with successive branching, changing in the end a big part of the
entire geometry.
Thibaut
> One of my goals is to prepare a full-on cellular automata gallery that
> anyone (with a graphics card) can view.
> Sam
stbenge wrote:
> On 1/31/2011 1:38 PM, Darren New wrote:
>> stbenge wrote:
>>> Sometimes it seems like the problems expand outward in a branching
>>> structure...
>> I have coined the term Zeno's Debugger for that.
>> Every time you try to figure out what's causing the error, you have to
>> first debug the tool you're using to figure out what's causing that
>> error, recursively.
> But what do you call it when the only thing stopping your software's
> deployment is one tiny exe that happens to be bundled into one humongous
> development kit?
So you go to download the kit and you need to make up an account to download
it. But the make-up-the-account doesn't work through the corporate firewall,
so you go home. But your home computer has firefox and the download doesn't
work with that. So you install Chrome and manage to sign up, but they don't
take gmail addresses for logins. So you go to log in over the VPN, but the
VPN software has been upgraded, so you need to take your VPN box back to
work anyway to get reflashed. So you go back to work to download the file
but it doesn't come through the proxy. So you bypass the proxy but there
isn't enough temp space to download the package. So you go to back up some
useful files but the USB drive has gone missing. So you ask around to see
who has the USB drive .....
When, really, all you wanted was to write a f'ing piece of code.
"How did he die?" "He got shot in the hand."
"That was fatal?"
"He was holding a live grenade at the time."
>> development kit?
> A b*st*rd? o_O
My inclination _is_ to to start using profane expletives, but the Zen
method of realizing the path I must take fills me with peace. At least I
know I /can/ resume a long, drawn-out broken download with this
particular development kit. Fortunately, Sun hasn't taken Microsoft's
route of providing a "user friendly" download installer that resumes the
downloads only at 20MB intervals X_x
Sam
>> humongous development kit?
> download it. But the make-up-the-account doesn't work through the
> corporate firewall, so you go home. But your home computer has firefox
> and the download doesn't work with that. So you install Chrome and
> manage to sign up, but they don't take gmail addresses for logins. So
> you go to log in over the VPN, but the VPN software has been upgraded,
> so you need to take your VPN box back to work anyway to get reflashed.
> So you go back to work to download the file but it doesn't come through
> the proxy. So you bypass the proxy but there isn't enough temp space to
> download the package. So you go to back up some useful files but the USB
> drive has gone missing. So you ask around to see who has the USB drive
Is that talking from personal experience, or extrapolating from a
possibility? I can see that happening. If only half of what you said has
actually happened to you, I no longer feel so bad.
I know the thing must be less than 200K, but after reading the
license/user agreement, I know that that one tiny file can't be
distributed singularly (without legal repercussions). At least after I
download the monolith-of-an-development-kit, I can start learning actual
Java and go beyond the scope of Processing.
Sam
Well... cellular automaton simulations are an entirely natural process,
so these things happen as a matter of consequence. As to just
/what/exactly/ is being modeled is determined by the purity of the
calculations. I know that some of my calculations have resulted in an
approximation of a minimal surface, but others were added to increase
growth. So maybe we have a biological organism with a lot of mucus...
> entire geometry.
That's one of the things that puts this sim into its own category. What
you are seeing is related to reaction/diffusion and minimal surface
systems, but I really don't think that its behavior is indicative of a
"pure" minimal surface.
> interested.
I can't really explain what I did. I know *what* I did, and *why* it
does it, but ask me to put it into scientific or mathematical terms, and
you won't get a satisfactory answer.
But here's the GLSL code. I'll attempt to provide useful descriptions:
// these uniform variables are piped in from the governing program:
uniform sampler2D bufA; // a 768x768 16-bit surface
uniform vec2 offset; // offset.s = 1/768, offset.t = 1/768
uniform int DoPaint; // is the mouse clicked? (a boolean would be better)
uniform float MX, MY, RX, RY; // mouse X/Y, random values X/Y
// variables for the red, green & blue components
float R, G, B;
// CA = blur sample
// C0 - C8 = point samples
vec4 CA, C0, C1, C2, C3, C4, C5, C6, C7, C8;
// a noise function (not mine, used for adding noise to Area_Add[below])
float rand(vec2 UV){
return
fract(
sin(
dot(
vec2(
UV.x+RX,
UV.y+RY
vec2(12.9898,78.233)
)*43758.5453
void main(void){
float dx = offset.s; // 1/768
float dy = offset.t; // 1/768
// UV.x = 0.0 to 1.0, UV.y = 0.0 to 1.0
vec2 UV = gl_TexCoord[0].st;
// expansion vector (realized with POV)
// uses the green channel
vec2 Expansion =
.0625*vec2(
texture2D( bufA, UV + .5*vec2(-dx, 0.0) ).g
-texture2D( bufA, UV + .5*vec2(dx, 0.0) ).g,
texture2D( bufA, UV + .5*vec2(0.0, -dy) ).g
-texture2D( bufA, UV + .5*vec2(0.0, dy) ).g
// applying the expansion to "UV"
UV += 1.0*Expansion*(texture2D( bufA, UV).g);
// center sample
C0 = texture2D( bufA, UV);
// samples clockwise from upper-left
// total (with C0): 1 + 2 + .92 = 3.92 (values are also thanks to POV)
C1 = texture2D( bufA, UV + vec2(-dx, -dy) )*0.23;
C2 = texture2D( bufA, UV + vec2(0.0, -dy) )*0.5;
C3 = texture2D( bufA, UV + vec2(+dx, -dy) )*0.23;
C4 = texture2D( bufA, UV + vec2(+dx, 0.0) )*0.5;
C5 = texture2D( bufA, UV + vec2(+dx, +dy) )*0.23;
C6 = texture2D( bufA, UV + vec2(0.0, +dy) )*0.5;
C7 = texture2D( bufA, UV + vec2(-dx, +dy) )*0.23;
C8 = texture2D( bufA, UV + vec2(-dx, 0.0) )*0.5;
// blur sample
CA = (C0+C1+C2+C3+C4+C5+C6+C7+C8)/3.92;
if(DoPaint==1){ // paint circular area
// adds a noisy, circular density when the mouse is clicked
float Area_Add =
rand(UV)*clamp(
1.0-16.0*sqrt( pow(UV.x-MX, 2.0) + pow(UV.y-MY, 2.0) ),
0.0,
1.0
R = clamp(CA.r + .05*Area_Add, 0.0, 1.0);
// green is given a blurred version of the red channel
G = CA.r;
// blue is given a blurred version of its own channel
B = CA.b;
}else{ // return the usual values
R = CA.r;
G = CA.r;
B = CA.b;
// edge-finding
B = C0.r+(C0.r-CA.r)*760.0;
// mix old values with squared edge values
// ("mix" is the same as a linear interpolation["lerp"])
B = mix(CA.b, B*B, .025);
// add blurred edges to primary evaluation channel
// and decrease all red values over time
R = R + .045*CA.b - .0203065;
// subtract blurred edge values from the green channel
G = G - .107*CA.b;
// prevent values from going below 0.0 (black) or above 1.0 (white)
R = clamp(R, 0.0, 1.0);
G = clamp(G, 0.0, 1.0);
B = clamp(B, 0.0, 1.0);
// carry values over to next iteration
gl_FragColor = vec4(R, G, B, 1.0);
That was a description of the *kind* of thing that happened to me on a
regular basis at my previous job, yes. Between the code and the people
providing the code, it was the most distasteful job I've ever had, really.
And that counts customer service at the deli.
"That was fatal?"
Ah! My son. You will realise, after years of study and training that the
circle can be completed and the mind’s control of the body is as nothing
to letting rip when the hammer of fate connects with the thumb of life.
So take yourself into the desert and kick the coyote until He gives you
the gift of fire.
Regards
> Ah! My son.
You aren't my father! No! No! (getting carried away with Star Wars
geekiabilia there)
> the gift of fire.
I've done that, but it really doesn't work. Expressing emotional turmoil
to desert creatures (or other socially arid inhabitants) doesn't really
accomplish much, although you /do/ get some exercise.
Sam
Profanity is my number one debugging tool.
"That was fatal?"
> As it turns out, there were two places to change the window size, so it
> should be fixed now.
OK it's working now, very smooth.
Neither URL works for me on my work PC. I get a security warning asking
if I want to run the applet, and then a blank page. The new URL works
just fine on my home PC. I have no idea why there would be a difference.
(But I recall that this kind of thing is highly typical of Java. Isn't
that their slogan? Write once, test everywhere?)
I don't know about cellular automaton; it looks more like some sort of
reaction-diffusion system.
http://texturegarden.com/java/rd/
Then again, there are other types of differential equations which
apparently produce similar results. Which is why I find it quite
surprising that you claim this is a *discrete* system, not a continuous
one. It certainly doesn't look very discrete.
I also wonder whether the visible image on-screen actually represents
all the information in the frame, or whether there are details too faint
to see. Certainly the simulation behaves in a wonderfully unpredictable way.
Clicking the mouse is like detonating a high-yield nuclear bomb, and the
fallout usually dies away quickly, but sometimes inexplicably lasts for
a very, very long time.
It is worth noting that, certainly for RD systems, almost all
combinations of parameter settings do absolutely nothing interesting at
all. Only a tiny fraction of possible settings do anything remotely
worth watching. Finding these interesting bits is highly non-trivial.
And yet, you seem to have hit upon something quite interesting here.
It appears that the image boundaries are held at a constant state. You
might try toroidal symmetry (i.e., joining the edges together). Also, it
occurs to me that if you were to run a simulation and stack each
successive frame one on top of the other, you could make some rather
interesting 3D shapes.
(Alternatively, perhaps the algorithm generalises easily to 3D. I'm not
sure how easy to visualise that would be though...)
It still amuses me that way, waaaay back in 1997 or so, I was playing
with Java, trying to copy the output of the ground-breaking Geiss
visualisation for WinAmp. Of course, Geiss used hand-optimised machine
code for all the main loops, and still ran cripplingly slowly. (E.g.,
about 12 frames/second at 800x600, only rising to sane speeds at 320x240.)
Unsurprisingly, Java was orders of magnitude slower. I had it render at
256x256, and draw 4x larger on screen. And still it was absurdly slow.
(I didn't measure exactly how slow.)
And yet, your little Java applet sucks about 5% CPU out of my obsolete
AMD Athlon 2X 4200+ with its 2.2 GHz clock rate. How times have changed!
I'm curious to know how you manage to get it to render at a constant
frame rate, rather than "as fast as you can".
>> Ah! My son.
> geekiabilia there)
It is so easy. :-)
>> the gift of fire.
Just slap your computer, then.
Regards
lol!
>>> Ah! My son.
>> geekiabilia there)
> It is so easy. :-)
Just when you think you have it under control, someone cuts off your
hand and starts making outrageous parental claims :(
OK... . whoa, that's a lot of dust!
Cool.
Part of the problem is that I'm using OpenGL libraries, and the security
restrictions imposed by the new version of JRE is keeping the thing from
loading completely. In a few days (after the download is complete) I can
start signing my applets, which should help.
It /is/ partly a reaction-diffusion system. I've never made a "pure" RD
system, though the edge-finding portion of mine is considered a type of RD.
Oh yeah, I was there yesterday :) There's also another link at the same
site concerning fractal drainage patterns:
http://fd.alife.co.uk/model/plugin/index.html
When trying to model minimal surfaces, I inadvertently stumbled upon a
way to model such drainage patterns. What you see in my demo is the
result of the drainage ridges becoming stabilized. I think it might even
lead to a way for eroding height_field data.
No, it's definitely *not* discreet. After reading up on the definitions,
I'd have to say that it's most likely continuous. I guess I have lumped
all sorts of systems into the generalized term, "CA." There's a lot of
crossover. I'm pretty sure there is a continuous version of the Game of
Life (maybe still waiting to be found).
> way.
The video surfaces are not scaled down, but they /do/ use linear
interpolation, so there is inter-pixel testing going on. I didn't use
noise for the field, but when you click the mouse, it sprays
randomly-valued pixels locally. That's the only randomization present.
Well, it was a theory that actually worked! Usually when I hit upon
something, the next phase is the small adjustment of values, to express
what's truly going on. It's hard to tell exactly /what/ needs to be
changed beforehand, since each subsequent generation becomes more and
more difficult to predict. But that's what makes these systems so much
fun :)
Yeah, the library I'm using for the GLSL doesn't allow me to tell OpenGL
to wrap a texture. Which means I need to make a function, which means
things will slow down somewhat, though not appreciably.
> Also, it
I should try that. I don't see why it couldn't be done (unless I run out
of RAM).
I'm sure a 3D version would work just fine, but would be hecka slow.
I've thought about stacking 2D surfaces and testing between them. The
current setup (768x768) amounts to 589,824 pixels. A 64x64x64 stacked
planes setup would be 262,144 pixels total. But such a setup would
require more pixel samples to be taken, and some sort of way to test the
nearest surfaces. To visualize it, I could use alpha transparency and a
simple bump-mapping technique. But there are other problems with doing
all of that that I haven't resolved.
Whoa, that's pretty fast! I've gotten no better with SDL and C++...
Yeah. Java, as a rule, just isn't that fast.
Most of the work is being done on your graphics card. That's why GLSL
appeals to me so much: I can quickly type out an idea and see it play
out in real-time. I didn't even realize the potential until I saw some
of Milkdrop's presets... At one point I was like, "Wait a minute! That's
the Game of Life, running at 60FPS! Fullscreen!!!" I didn't get much
sleep that night.
It /is/ running all-out, but it's possible that either Processing or the
graphics hardware is capping the frame rate.
Sam
Security restrictions block OpenGL? Man, whatever next...
Hmm, OK.
I see... I think.
>> all.
> fun :)
Fun and frustrating at the same time, usually. ;-)
>> 320x240.)
Well, a tiny inner loop custom-coded in assembly... Go check out Project
Euler. Apparently people really do still write assembly by hand. Go figure!
No kidding. It certainly wasn't back in 1997.
Wait - it's written in *Java* and yet it can access the *graphics card*??
How is that even possible?
Oh, well, no wonder its fast then. The graphics card is purposely
engineered to eat calculations like this for breakfast.
> sleep that night.
Yeah, Milkdrop basically 0wnz. Created by the same guy as the old Geiss
plugin too... That is one talented guy!
I wish to God I could figure out how half of Milkdrop works. There are
some amazing 3D effects which cannot be done in realtime, and yet it
does them in realtime, even though that's clearly impossible.
Right. I assumed it way rate-limited because it wasn't using all
available CPU power.
>>> geekiabilia there)
>> It is so easy. :-)
There, there, there. :-)
Hot dust?
Regards
It's not. It's using a library interface between Java and OpenGL probably
written in C or C++. Hence the security restrictions people were talking about.
The CA is written in Java, but the graphics code is still in C-ish and
shader language and such.
Back to that again? ;-)
"That was fatal?"
>> of RD.
> Hmm, OK.
It's the edge technique described in Milkdrop's preset authoring page.
When used carefully, you can produce reaction/diffusion and "skin dot"
effects.
> I see... I think.
From Wikipedia's stub on Continuous automaton:
"A continuous automaton can be described as a cellular automaton
extended so the valid states a cell can take are not just discrete (for
example, the states consist of integers between 0 and 3), but
continuous, for example, the real number range [0,1]."
You can enforce discrete rules into continuous CA, hence my argument
that there can be some crossover between the two. This is *probably*
something you would have to do to make a continuous version of Conway's GOL.
Last night I began producing a "hard" version of continuous CA in which
ships are born or killed based on area evaluation. It's looking to be a
promising method. Already, it has managed to produce three main types of
"ships," all relatively huge. In fact, it's nothing /but/ ships :S
>> fun :)
I don't find it frustrating at all <G>
Robust code, of course.
Evidently there are some security issues involved with allowing an
applet to access graphics hardware, which is likely the reason the new
version of JRE is so intolerant.
It's really not that difficult to learn (mastering it OTOH...). It draws
graphics (shapes, dots) to a texture residing on a screen-wide, flat
quad mesh (the detail of which can be changed through settings) and then
recycles the drawn graphics for the next frame. The quad mesh can be
warped to "push" the graphics around. Many 3D effects are created by
slightly altering the mesh. Then there are two pixel shaders allowing
you filter all the graphics. The first pixel shader can let you to
produce CA, reaction/diffusion, etc., since it "recycles." The other
shader is the final composite function that lets you apply a pixel
filter without affecting the next frame.
Some of the 3D effects which look too detailed, and seem to exist on a
per-pixel level, are probably effects created by a 2D shader.
Oh yeah, the common link between the reaction/diffusion link you posted
and the drainage pattern link I posted is this: http://www.cell-auto.com/
There are many interesting things to be found there :)
Sam
> probably written in C or C++. Hence the security restrictions people
> were talking about.
You mean it's not "pure" Java? :S
I was always amused to see things on software like "100% Pure Java!"(*)
(*) Requires Java 1.5.2.4 or later.
In other words, it's 100% pure java because their particular native
interface got incorporated into the JVM just recently. :-)
"That was fatal?"
Did you get it working on the new version? I kind of lost track.
"That was fatal?"
No, but when I get the JDK downloaded/installed, I will (assuming that
signing my applets is the cure).
Sam
stbenge wrote:
> (assuming that signing my applets is the cure).
Heh heh heh. Remember all the crap that Microsoft got for ActiveX security? :-)
"That was fatal?"
> security? :-)
I missed that... But I imagine if a company is faced with a potential
lawsuit, they'd rather make things more difficult for developers rather
than suffer the pain inflicted by hurled legal documents :/
Sam
>> security? :-)
Back when Java applets first came out, and ActiveX, everyone mocked ActiveX
because it allowed unsafe code to run as long as the developer had signed
the ActiveX package so you could track it back to him.
Now, 15 years later, Java gives in and does the same thing, because people
really do want to run unsafe code sometimes. (Altho what's unsafe about
OpenGL I can't guess. :-)
"That was fatal?"
>>> security? :-)
>> rather than suffer the pain inflicted by hurled legal documents :/
> ActiveX because it allowed unsafe code to run as long as the developer
> had signed the ActiveX package so you could track it back to him.
Ah, so /that's/ the point. I *knew* there had to be some reason behind
it. But... aren't there file-hosting servers a person can use in
conjunction with free website companies that would make anonymously
distributing applets possible? I guess it can all be tracked down
eventually, but it's not stopping some people, evidently.
> people really do want to run unsafe code sometimes. (Altho what's unsafe
> about OpenGL I can't guess. :-)
I don't know either. I'm sure there's a weakness somewhere (there always
is [this is somehow more true for Microsoft apps]), or they wouldn't
have made it an issue. Right? :(
Sam
From what I can tell, very little is actually *described* in the
Milkdrop documentation.
> effects.
Yeah, you can do all kinds of really funky stuff with systems of
differential equations, and the graphics hardware is pretty much
designed for this type of number crunching.
I can't imagine what the possible security risk could be...
> graphics (shapes, dots) to a texture residing on a screen-wide...
Oh, yeah, I get how a graphics card works. What I can't figure out is
how some of the effects that Milkdrop generates are mathematically
possible. Figuring out the math is the hard part; actually making the
hardware do it is usually quite simple.
It's enough to get a person going with preset authoring.
Actually, I was describing what /Milkdrop/ does with a graphics card.
All VJ'ing apps are pretty similar, I think.
> possible.
OK, you're going to have give me an example... give it over! Pick a
preset from Milkdrop's standard distribution that epitomizes this
nearly-impossible effect, and I'll tell you how I *think* it's done.
Maybe other, more knowledgeable people will join in as well, and we can
get to the bottom of this thing ;)
Sam
Distributing signed code via MS technologies requires you to get your
signature from MS, at least in many cases. Bascially, you buy a normal web
cert from a CA that MS trusts (any of several of the big ones), and then
sign an empty ActiveX file with it, and send that to MS along with your
public key, and MS signs the public key and sends it back. You can't just
use a self-signed cert, at least for most of the stuff I've seen that deal
with certs.
"That was fatal?"
> web cert from a CA that MS trusts (any of several of the big ones), and
> then sign an empty ActiveX file with it, and send that to MS along with
> your public key, and MS signs the public key and sends it back. You
> can't just use a self-signed cert, at least for most of the stuff I've
> seen that deal with certs.
It would seem that Sun doesn't require the purchase a web certification,
which is good for me since I don't plan on selling anything.
Hey, you seem knowledgeable about these things. I'm looking into using a
file-hosting service to free up more space for my (future) site. Do you
know of a good service that will allow me to store Java applets and use
them directly in my pages? My ISP gives me a measly 5MB site space (you
would think they'd be more generous, since I'm paying $20/mo for 24Kbps
dialup), so to post more content I must rely on file-hosting services.
I'm confident that I can use Photobucket for my images, but Java applets
might be a little more difficult to get working.
I think that if I can get away with using my 5MBs for only HTML/CSS, I
can stop worrying about running out of (my preciousss) space.
Sam
Yep. It also brings up that whole responsibility thing. Why do they make you
sign it if they're not going to do even a nominal check on the signature, I
wonder? :-)
Last I looked (and that was a while ago), Java applets had to be served from
the same host the HTML that embeds them come from.
Myself, I use amazon.com's s3 service for sloshing web files around. You can
set the content type as you need it there, make stuff public or private,
etc, and it's super cheap. (I think I wind up payin <$2/month to store all
the random crap up there I have.) There's no execution, you can't easily
put a home page on it (since http://..../ doesn't default to redirecting to
http://..../index.html or anything like that), and as I said the applet
probably has to come from the same place as the html.
That said, you could put an HTML page up on your expensive host that's
simple meta-refresh redirect to an HTML page on amazon that references the
applet.
I don't really do anything web-sophisticated on my own dime any more, so I'm
kind of out of date on the options.
"That was fatal?"
On 2/3/2011 5:14 PM, Darren New wrote:
>> certification, which is good for me since I don't plan on selling
>> anything.
> you sign it if they're not going to do even a nominal check on the
> signature, I wonder? :-)
>> a file-hosting service to free up more space for my (future) site. Do
>> you know of a good service that will allow me to store Java applets
>> and use them directly in my pages?
> from the same host the HTML that embeds them come from.
> can set the content type as you need it there, make stuff public or
> private, etc, and it's super cheap. (I think I wind up payin <$2/month
> to store all the random crap up there I have.) There's no execution, you
> can't easily put a home page on it (since http://..../ doesn't default
> to redirecting to http://..../index.html or anything like that), and as
> I said the applet probably has to come from the same place as the html.
> the applet.
> I'm kind of out of date on the options.
If you don't mind administrating your own site entirely, and having it
on a virtual machine, some people are using this:
http://www.tektonic.net/
to host their own applications even, like OpenSim, and the like, since
you can install more or less what ever you want into it.
Found it nosing around to see what sort of places out their might host a
sim, to make building easier, without paying someone else anywhere from
$40-$250 a month for it instead.
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Yeah, Amazon has a lot more services than their S3 storage server, but
there's a lot of competition that is cheaper than Amazon's rates on compute
time. Amazon has a bunch of different storage and CDN and hosting and
database solutions too, but if you're just looking for plain old cycles, you
can get it cheaper than amazon these days. Their raw storage, however, is
super cheap. Like, $0.15/gig/month or some such.
"That was fatal?"
> compute time. Amazon has a bunch of different storage and CDN and
> hosting and database solutions too, but if you're just looking for plain
> old cycles, you can get it cheaper than amazon these days. Their raw
> storage, however, is super cheap. Like, $0.15/gig/month or some such.
I have yet to find a virtual server offering that I could even plausibly
afford. The cheapest I've seen is, like, £15/month, which is way more
than I want to pay. Any suggestions?
y
ore
Not offhand. You could bid spot prices on Amazon servers for whatever pri
ce
you want to pay and see if you get any. :-) But there's a lot out there.
It's possible there's a virtual server farm that cheap.
"That was fatal?"
On 1/31/2011 12:49 PM, stbenge wrote:
> On 1/31/2011 9:46 AM, nemesis wrote:
>> 404: not found
> I just uploaded it to a new directory:
> http://www.caltel.com/~abenge/applet/index.html
"Error: Class not found: RDMinim"
John
>>> 404: not found
> Regards,
> John
Yeah, I've narrowed down the cause to one probability: the new version
of JRE requires the signing of applets when used in conjunction with
OpenGL. I'll be able to sign my applets pretty soon.
Thanks,
Sam
Gah!
I was hoping that after downloading the JDK, the process of signing my
applets (thus making them viewable in a web page, on most computers)
would become possible. But no. Every turn I make takes me down a path
fraught with peril. And for what? For an applet that would take up a big
ol' chunk of my limited web space?
It's just not worth it!
So in order to save what's left of my sanity, I'll release anything I
make as a standalone application. I realize that this will limit my
audience, but if I make something truly worth seeing, then the download
will be worth it. I could then use a file-hosting service to provide
direct downloads. And, if I ever finish a game, save files will be
easier to manage.
At least Processing lets me export applications to the Big Three OSs :/
So, in short, I'm giving up... unless inspiration strikes and the
solution become clear `:(
Sam
Demo the screen. Post video to youtube. Right now I can only vaguely imagine
what you're talking about.
"That was fatal?"
> imagine what you're talking about.
In related news... How the hell do you take a video of something
actually on your computer screen? (Short of pointing a video camera at
your monitor, which just seems silly...)
http://en.wikipedia.org/wiki/Comparison_of_screencasting_software
If you are on Windows, I recommend camstudio, with their proprietary
codec, for the capture on disk. (and it's free of charge) (you can
capture fullscreen or partial area)
Next you will need to transcode it to a codec supported by your video
editor, but that's an offline operation.
(for conversion, Freemake Video Converter is my other recommendation)
Software is like dirt - it costs time and money to change it and move it
around.<br/><br/>
Just because you can't see it, it doesn't weigh anything,
and you can't drill a hole in it and stick a rivet into it doesn't mean
it's free.
Bizarrely, this claims that FFmpeg and VirtualDub can do screen capture...
Well, FRAPS is pretty much the standard for video games.
"That was fatal?"
Isn't that also insanely expensive though?
First 30 seconds is free, then it's like $39 or something here?
So, no, unless you're very poor. :-)
"That was fatal?"
The whole point was that I was trying my make an interactive applet,
which would have been much more interesting than watching a video or
staring at a static image. An image wouldn't look much more impressive
than a voronoi diagram.
I haven't given up completely. I've got other things to do ATM, but will
continue to research the topic...
Sam
I think if I was going to start throwing my money around, I would get
one of these:
http://craig.gp2x.de/review/GP2XReview.html
Sam
