POV-Ray : Newsgroups : povray.off-topic : An observation Server Time
5 Jul 2026 05:00:34 EDT (-0400)
  An observation (Message 68 to 77 of 107)
Subject: Re: An observation
Date: 31 Oct 2010 16:51:29
Message: <4ccdd6d1$1@news.povray.org>
On Sun, 31 Oct 2010 13:29:24 -0700, Patrick Elliott wrote:
> How so? Drivers can be compiled into kernel, but most are not any more,
> and they can be added or removed, without effecting the kernel itself.
> You do have to compile it for the specific processor though, so where
> exactly do you think I contradicted myself?
Looking at the source for the version of Android on my phone, I see the
drivers in with the kernel source.
My router (which is not Android-based, but Linux based) is the same.  Not
x86 hardware, but it uses drivers for hardware that is readily available
on x86 systems, so the drivers are in the kernel tree.
Jim
Date: 31 Oct 2010 16:52:37
Message: <4ccdd715$1@news.povray.org>
> Not x86 hardware, but it uses drivers for hardware that is readily
> available on x86 systems, so the drivers are in the kernel tree.
Note that when I do compiles for my router, the drivers are modules, but
they're still part of the kernel source tree.  Modular or compiled-in
modules still tend to be in the kernel source tree unless you're talking
about something like the proprietary NVidia or ATI drivers.
Jim
Date: 31 Oct 2010 17:14:01
Message: <4ccddc19$1@news.povray.org>
> Without a doubt.  Windows' roots (starting with NT) was on DEC equipment,
> after all, not x86.
Heh.  I don't think they took actual VMS code and tried to port it for Windows.
   Serving Suggestion:
     "Don't serve this any more. It's awful."
Date: 31 Oct 2010 17:21:45
Message: <4ccddde9$1@news.povray.org>
> On Sat, 30 Oct 2010 18:54:00 -0700, Patrick Elliott wrote:
>>  As I understand it the kernel may as well be the
>> same, assuming the same processor, but the interfaces, i.e. drivers, to
>> the rest of the stuff, isn't.
> Um, no, actually, the APIs would be the same because it's the same kernel
> code.
The kernel code (at least, the "same" kernel code) is generally not what
provides the APIs to device drivers on embedded devices.
> Wait, what?  You seem to be contradicting yourself....
No, he's saying you *could* do it, but generally that isn't what happens.
People don't port X11 to their cell phone, they use directFB. People don't
port Pulse to their cell phone, they use whatever API works with the
hardware. They don't use udev, they just write directly to the USB devices
they support. Etc.
That the drivers are in the kernel tree on *your* devices doesn't mean
they're part of the kernel on other devices.
Well, unless you're talking about anything that's not generic, really. Does
the standard Linux kernel have device drivers for CDMA chips? 4" LED
touchscreens? Power control modules for turning on and off various parts of
various chips? GSM codec hardware?
   Serving Suggestion:
Date: 31 Oct 2010 17:31:34
Message: <4ccde036$1@news.povray.org>
>> equipment, after all, not x86.
> Windows.
Maybe, maybe not.  I have a vague recollection of a book by Dave Cutler
(I think it was) who went to MS from DEC and was responsible for the bulk
of kernel coding in NT.  Probably didn't take DEC code (otherwise DEC
could've sued him), true.
Jim
Date: 31 Oct 2010 17:35:23
Message: <4ccde11b$1@news.povray.org>
>>> to the rest of the stuff, isn't.
>> kernel code.
Device drivers talk to the kernel through APIs the kernel provides,
though.
> happens. People don't port X11 to their cell phone, they use directFB.
> People don't port Pulse to their cell phone, they use whatever API works
> with the hardware. They don't use udev, they just write directly to the
> USB devices they support. Etc.
DirectFB IIRC is in the kernel...X isn't.  Pulse isn't kernel-level
stuff, it's middleware.  Sure the middleware isn't the same.
My router's kernel has devpts mounted and uses procfs.  Those are
provided by the kernel (or by kernel drivers interfacing to the kernel).
"something like the [...]" - now does that imply anything other than
"anything that's not generic"?
> Does the standard Linux kernel have device drivers for CDMA chips? 4"
> LED touchscreens? Power control modules for turning on and off various
> parts of various chips? GSM codec hardware?
Define "standard Linux kernel"?
Jim
Date: 31 Oct 2010 17:50:49
Message: <4ccde4b9@news.povray.org>
Yep. But the fact that Cutler came from DEC says nothing about how portable
the OS he helped write based on his experience was. People give them crap
for "stealing" VMS, but when you work at that level, your experience is why
you get hired.
Also, I think the XBox360 runs a version of Windows ported to a PowerPC, so
I think it's more ambiguous than you might think.
   Serving Suggestion:
Date: 1 Nov 2010 20:45:09
Message: <4ccf5f15$1@news.povray.org>
> Jim
Yes, but, as I said, you could add ones you don't have, or remove the
ones that are there. The kernel needs to know how to talk to the
hardware, but it doesn't give a crap, beyond the obvious need to run on
the processor you compiled to, *what* that hardware actually is. That
was my point. Sure, for stand alone cases, a lot of the drivers are in
the kernel tree. Same, to an extent, for "some" of the common ones for
PCs. Doesn't mean they have to be there, beyond the basics needed to get
something loaded in the first place.
void main () {
   If Schrödingers_cat is alive or version > 98 {
     if version = "Vista" {
       call slow_by_half();
       call DRM_everything();
     call functional_code();
   else
     call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
Date: 1 Nov 2010 23:54:07
Message: <4ccf8b5f$1@news.povray.org>
As software, it *can't* "care".  I don't understand your point at all.
Jim
Date: 3 Nov 2010 09:19:37
Message: <4cd16169$1@news.povray.org>
On 10/28/2010 3:12 PM, Darren New wrote:
> Well, no. There's interrupts, sensors saying how many coins are there,
> to signal when it's out of coins or has been filled incorrectly, timing
> delays for releasing various coins, dealing with power going out and
> coming back on while the mechanism is operating, etc.
Surely a lot of that should be handled by the firmware. How does it
communicate? RS232/RS485, TCP/IP, USB, CAN, etc?
What data does the device communicate back to the host? What does the
host send to the device?
Obviously there must be some sort of protocol, and the device's firmware
probably only communicates the bare minimum to work with the host. If
you don't have the messages it expects and the messages it sends laid
out for you, it could be a bit of a challenge. You'll probably miss a
corner case somewhere. (For example, upon host init, the coin counter
expects to be sent a certain set of data to initialize properly, or
perhaps you missed the "coin stuck" message because you never saw it in
your reverse engineering tests)
> Everything's trivial if you aren't the one writing the code.
Of course!
>> I guess the real question is "why are people manufacturing devices
>> that will only ever be used as part of an embedded system writing
>> drivers for it that won't work as part of an embedded system?"
> Except it *is* a driver working as part of an embedded system, obviously.
Also, less expensive to support only one embedded OS.
Of course, I wouldn't be surprised that even if the device communicated
over a common, easily accessible protocol that it's opaque through a set
of DLL's. I've seen a lot of devices like that when I was working on HMI
code. Some of the basic sensors are really quite easy to deal with. We
had a prox sensor whose communication protocol was to raise a single
line (RTS, I think ...) on the RS232 port as an indicator that something
was in proximity. Extremely simple to deal with.
~Mike
