![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
At your lack of comment on wxMaxima. I would have expected some remark...
I remember some time ago you posting about how horrible the pricing if
Mathematica is ... I thought for sure you'd have some interest in a GPL
tool that can do some of the core things + it uses LISP.
Hmm... maybe the girl has gone to your head? ;)
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Yeah, well, I've used a couple of programs that are meant to be "like
Mathematica, but free". Every single one of them has sucked beyond
belief. A few of them can solve easy equations or do very simple
graphing, but none of them come close to the power and sophistication of
Mathematica.
Of course, when you consider that Mathematica has had tends of thousands
of man-years of R&D poured into it over the last 22 years, it's kind of
unsurprising that it's so good. (In fact, it's surprising it's not even
better, come to think of it. Why the **** doesn't it do anti-aliased
graphics yet?!)
Also: I hate Lisp.
It's not my *head* that's... uh... never mind. ;-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Also: I hate Lisp.
yeah, we all knew it comes down to this, you weeny.
In any case, browsing through the pictures:
http://maxima.sourceforge.net/screenshots.html
I only see usual math formulas in usual ambiguous infix syntax and common
function syntax, which means Maxima is only written in Lisp, not that its user
interface uses it.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Also: I hate Lisp.
I only meant that "it's written in Lisp" is no particular
recommendation, as far as I'm concerned.
> interface uses it.
Yes, quite.
Note, though, that unlike Mathematica, you cannot write "2 Pi" or even
"2 pi". You must write "2 * %pi". How irritating...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible escreveu:
>>> Also: I hate Lisp.
but who was recommending it on the basis that "it's written in Lisp"?
>> its user
>> interface uses it.
> Yes, quite.
hmm... if that's the case, seems like the user interface is just sugared
Lisp macros... :p
a game sig: http://tinyurl.com/d3rxz9
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Its not so bad.... I suppose if the %(special character) notation
bothered you, you could technically define variables as the special
characters and use them instead. Heck, you could define a batch that
does this and include it in the init.
And .... what's with the lack of love for Lisp?
Though using * for multiplication is a bit annoying, It's not really a
dealbreaker for me. It still does a reasonably good job of solving and
expanding equations, and the wx version makes nice output. You can also
grab the output in TeX format, as well.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Its not so bad....
No, just irritating.
People say "Lisp is a beautiful language; everything is a list". Which
is a nice idea. But when you actually look at the language, it's kludgy
and ad hoc, with lots of crufty backwards-compatibility junk. No thanks.
> dealbreaker for me.
It just irritates me, that's all.
I love the way that neither Mathematica nor Maxima have yet heard of
this cool innovation called *anti-aliased graphics*. :-P Although,
Mathematica at least manages to do AA on text, with Maxima doesn't.
Maxima provides two plotting commands. The plot2d() function calls
GNUplot to do its work (and hence has all the limitations of GNUplot),
while the wxplot2d() function plots in the window itself (and hence is
even more limited). In either case, it's maddeningly difficult to make
it plot what you actually want.
Reading through the FAQ, it quickly becomes clear that Maxima isn't
nearly as polished as Mathematica. Lots of statements like "if you want
to solve an equation that looks like this, use foo(), but if that
doesn't work you could try bar(), but if the equation has a form more
like this then bar() won't work and you have to use baz() which uses a
different algorithm internally". In Mathematica, you'd just say "solve
this, now" and it uses 20 years of R&D and production refinement to
compute the answer any way it can.
I also love the way Maxima defaults to machine-precision and you have to
explicitly request arbitrary precision. Oh, but some functions don't
actually *support* arbitrary precision. (I don't know what happens in
that case - whether you get no answer or a wrong answer or an error
message or what.)
I haven't even looked at the possibility of programming in Maxima. Hell,
I don't know if it's even *possible*. Mathematica is basically a
powerful pattern-matching engine, and you can program new patterns into
it and it will transform them. I have no idea if Maxima can do that.
But most of all, when I got the trial version of Mathematica what I
quickly discovered is that most of the equations I want to solve do not
possess a closed-form solution anyway. And in fact, as awesome as
Mathematica is, it turns out I don't really need a CAS for anything. And
if I do, I can usually trick Wolfram Alpha into doing what I want. (And
since that's powered by Mathematica, it gives you the correct answer -
assuming you can make it comprehend the question...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Its not so bad....
>> dealbreaker for me.
Maxima seems to AA text just fine. If you're using the TeX fonts for
JSMath, All of the Symbols like summation, product, integration, etc...
are drawn using the OS font rendering engine, so, under Windows I get
everything rendered with ClearType.
Plot is really basic. Draw has more capability
Now, that /is/ irritating. I have encountered some of the rough edges
like this already
Maxima is very programmable, you can go as far as defining your own
infix operators and such, and even further than that right down to Lisp
What I like about Alpha is that I can actually learn something from it
in some cases. Maxima just produces the final result, whereas Wolfram
Alpha will sometimes have "possible" intermediate steps. I like to know
how something was arrived at. Rather than simply accepting the answer
spit back. But for piddling around with mathematics and not being at the
mercy of an internet connection, Maxima works for me.
~Mike
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible <voi### [at] dev null> writes:
Ever tried Sage?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Ever tried Sage?
Yes, but I'm not seeing the connection...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
