POV-Ray : Newsgroups : povray.off-topic : Circular Server Time
26 Feb 2026 17:59:47 EST (-0500)
  Circular (Message 1 to 5 of 5)
Subject: Circular
Date: 28 Sep 2010 04:09:53
Message: <4ca1a2d1$1@news.povray.org>
Question: If you have one of those gizmos that transforms rotational
motion to reciprocating motion, what path does the reciprocating part trace?
Answer: As far as I can tell, the path is
   cos a + Sqrt(k^2 - sin^2 a)
where k is the length of the connecting rod that is free to pivot. As
you can see, that means that for large k, the path is approximately a
sine wave. However, for small k it deviates significantly from a simple
sine wave...
Subject: Re: Circular
Date: 28 Sep 2010 04:14:07
Message: <4ca1a3cf$1@news.povray.org>
> trace?
> sine wave...
You are also forgetting in the equation the offset between the axes
(when the center of rotation is not aligned with the translation path).
A: Because it messes up the order in which people normally read text.<br/>
Q: Why is it such a bad thing?<br/>
A: Top-posting.<br/>
Q: What is the most annoying thing on usenet and in e-mail?
Date: 28 Sep 2010 04:25:38
Message: <4ca1a682$1@news.povray.org>
If the center of rotation isn't aligned with the translation path, would
the device even *work* any more? Certainly I've never seen that done
(and hence it doesn't interest me).
Date: 28 Sep 2010 06:14:43
Message: <4ca1c013$1@news.povray.org>
If the "engine" is the wheel, it always works.
If the "engine" is the translation, it works also, but an inertial wheel
is recommended. (used with 8 mm offset on 450 Honda engine)
If you want a true sine movement (for a constant rotational speed), you
need a scotch yoke system.
http://demonstrations.wolfram.com/ComparingSimpleCrankSliderAndScotchYokeMechanisms/
http://demonstrations.wolfram.com/SliderAndCrankMechanism/
Date: 28 Sep 2010 06:53:54
Message: <4ca1c942$1@news.povray.org>
This is what I was really interested to find out - how much the motion
of a simple crank deviates from a pure sine wave. Apparently the answer
is "it varies, depending on the length of the crank".
