POV-Ray : Newsgroups : povray.off-topic : Web page construction Server Time
18 Mar 2026 20:53:01 EDT (-0400)
  Web page construction (Message 16 to 25 of 35)
Subject: Re: Web page construction
Date: 14 Sep 2010 04:03:20
Message: <4c8f2c48$1@news.povray.org>
On 13/09/2010 10:14 PM, nemesis wrote:
> You indeed can generate the tree server-side. What's the problem with
> nested ul's again?
I want the other columns (e.g., timestamp, attributes, owner, etc.) to
line up vertically.
Date: 14 Sep 2010 04:04:12
Message: <4c8f2c7c$1@news.povray.org>
>> Hmm, so why doesn't the next heading tag get inlined into the previous
>> paragraph?
> because paragraphs are display:block by default?
True - but that still doesn't explain how the spacing is still correct.
(I.e., there's more space around a heading than there is around a
paragraph.)
Date: 14 Sep 2010 04:07:29
Message: <4c8f2d41$1@news.povray.org>
On 13/09/2010 09:15 PM, Le_Forgeron wrote:
> You are far too optimistic.
Well that's officially a first! ;-)
> (and even IE has a glitch mode: the very same document can be rendered
> with either the standard html+css or the old html engine... all
> triggered by some fancy first line... in doubt, it revert to old engine!)
Yes, all modern browsers appear to do this. If there's no declaration
saying what version of HTML/XHTML/XML this document is, the browser goes
into "quirks mode", where it attempts to emulate the broken behaviour of
obsolete browsers, which old web pages sometimes depend on. If you put
in all the proper declarations, you get standards-compliance mode. (And
if you don't put in those declarations, the W3C validator complains
bitterly.)
The puzzling thing is that W3C designed it so you can't just write a
line that says "this is XHTML v1". You have to put in half a dozen lines
reiterating this information...
> And firefox might display an xml document when served by a server, but
> not as a file:// (and if the xlt are not on the same server, it won't
> allow it!)
So far, Firefox has displayed everything I've asked of it. The same
cannot be said for IE...
Date: 14 Sep 2010 06:31:35
Message: <op.vi0p66qlmn4jds@phils>
And lo On Sun, 12 Sep 2010 13:21:32 +0100, Orchid XP v8 <voi### [at] devnull>
did spake thusly:
> OK, here's a couple of little questions that somebody here might know
> the answer to...
<snip>
> Is there some way I can style it so that it shows up more like
>    Introduction
>    (Show/hide)
>    ...real content...
.h1 {margin-bottom:0}
> or even
>    Introduction (Show/hide)
>    ...real content...
As nemesis states
  .h1 {display: inline}
> If so, how do I do it?
> 2. I want to build a file tree where you can collapse or expand tree
> nodes. The obvious way to do this is with the <ul> element. However, I
> also want each file to have attributes, a creation date, and so forth,
> and all these columns should line up vertically. The obvious way to do
> that is with a table. But it can't be a table and a list at the same
> time!
> I could use nested tables I suppose, but nested tables are EVIL! Is
> there some more semantically-transparent way that I can do this?
>    Root                               2009-09-12  Ahsc
>      Resources                        2009-09-10  Ahsc
>        Main.css                       2009-09-10  Ahsc
>        Main.js                        2009-09-10  Ahsc
>      Packages                         2009-09-12  Ahsc
>        ansi-terminal                  2009-09-12  Ahsc
Other than using absolute positioning why not:
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<style>
ul, li {list-style-type: none; margin: 0px; padding: 0px;}
span {width: 100px; display:inline-block;}
.indent{margin-left: 100px;}
.col1 {margin-left: 200px;}
.col2 {margin-left: 100px;}
</style>
</head>
<body>
<ul>
	<li><span>Root</span><span
class="col1">2009-09-12</span><span>Ahsc</span></li>
		<ul class="indent">
			<li><span>Resources</span><span
class="col2">2009-09-10</span><span>Ahsc</span></li>
			<ul class="indent">
				<li><span>Main.css</span><span>2009-09-10</span><span>Ahsc</span></li>
				<li><span>Main.js</span><span>2009-09-10</span><span>Ahsc</span></li>
			</ul>
			<li><span>Packages</span><span
class="col2">2009-09-12</span><span>Ahsc</span></li>
			<ul class="indent">
				<li><span>ansi-terminal</span><span>2009-09-12</span><span>Ahsc</span></li>
			</ul>
		</ul>
</ul>
</body>
</html>
Works in IE7, Firefox, Opera and Chrome. I mean technically you don't need
the ul li as you're indenting manually, but it does keep it tidy both in
code and for text readers.
Phil Cook
I once tried to be apathetic, but I just couldn't be bothered
http://flipc.blogspot.com
Date: 14 Sep 2010 07:33:06
Message: <4c8f5d72$1@news.povray.org>
>> Introduction
>> (Show/hide)
>> ...real content...
Wouldn't that mean that the margin between the header and the real
content would now be incorrect?
>> or even
>> ...real content...
> As nemesis states
Yeah, that's what I went with ultimately.
> <head>
> <style>
> </style>
> </head>
> <body>
> <ul>
> <ul class="indent">
> <ul class="indent">
> </ul>
> <ul class="indent">
> </ul>
> </ul>
> </ul>
> </body>
> </html>
> need the ul li as you're indenting manually, but it does keep it tidy
> both in code and for text readers.
I always try to design my pages so that if you totally disable all CSS,
it still displays sensibly. It might not be pretty, but it's readable.
Then I apply CSS to make it pretty.
Not sure you need to use ".indent"; why not just "li ul" or something?
Anyway, absolute positioning seems to work fine, but for the minor
detail that I need to figure out how wide the columns are supposed to be...
Also, whenever I try to open an XHTML document in IE (v7), it asks me
what application I want to use it open it with, and defaults to Firefox.
I can't seem to convince it to open it. The best I can do is get it to
display a blank page.
Date: 14 Sep 2010 08:47:49
Message: <4c8f6ef5$1@news.povray.org>
>>> paragraph?
> paragraph.)
Because both <h1>'s and <p>'s margin-top and margin-bottom are 1ex; in
height, but since usually <h1> uses a bigger font, its margin will be
bigger.
/*   gmail.com     */}camera{orthographic location<6,1.25,-6>look_at a }
Date: 14 Sep 2010 12:15:36
Message: <op.vi054jw4mn4jds@phils>
And lo On Tue, 14 Sep 2010 12:33:05 +0100, Invisible <voi### [at] devnull> did
spake thusly:
>>> Introduction
>>> (Show/hide)
>>> ...real content...
Should still conform to line-height
<snip>
Because the first ul isn't indented and it allows you to create an extra
indent for a third level if needed without messing with child indicators
that IE doesn't understand.
> be...
I try to avoid absolute positioning when possible, just because it takes
things out of the flow. if I have to use it I ensure it's well-wrapped,
but even then there can be some glitches where the positioning relates to
the first parent that specifies a position rather than its container.
Well I know they separated out online and offline content between two
windows, perhaps its related to that?
Phil Cook
Date: 14 Sep 2010 13:22:43
Message: <4c8faf63$1@news.povray.org>
> <snip>
I didn't think inline elements could have margins?
Ah. So the answer to "why not use child selectors" is simply "IE doesn't
understand child selectors"? Oh I *so* don't give a damn. :-P
>> be...
> to the first parent that specifies a position rather than its container.
Yeah, it looks like styling this correctly is going to be fun... Still,
at this point, I'm still getting the page content to be generated
correctly. Assuming I tag enough stuff, it should be possible to fiddle
with the CSS later.
http://blog.orphi.me.uk/
Date: 14 Sep 2010 13:55:17
Message: <4c8fb705$1@news.povray.org>
Invisible escreveu:
>> nested ul's again?
> line up vertically.
see Phill Cook's reply
a game sig: http://tinyurl.com/d3rxz9
Date: 15 Sep 2010 04:03:32
Message: <op.vi2d0ggcmn4jds@phils>
And lo On Tue, 14 Sep 2010 18:22:43 +0100, Orchid XP v8 <voi### [at] devnull>
did spake thusly:
>> <snip>
No it's just that the default is 0 for inline elements but some differ.
Ah well they do work for IE7 so ul>ul would have been neater.
>>> be...
> with the CSS later.
Well the benefit to the way I've done it is that it keeps the flow. That
is the third column will be positioned by default behind the second column
with no extra styling so you only need to set the sizes to indent+width
for everything to line up.
Phil Cook
