![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Darren New <dne### [at] san rr com> wrote:
> scott wrote:
> > some implement to *push* the tooth down into its socket really hard
> I don't remember exactly what took out my first wisdom tooth, but I remember
> it looked something like a corkscrew. Good thing I don't get nervous about
> such stuff.
I have had only one wisdom tooth removed because it was horizontally
impacted and thus could with high probability cause problems later in
life (all the other three wisdom teeth have developed nicely, so there
has been no need to do anything to them).
The method they used was basically to break it into small pieces with
a drill (or some other similar tool, I'm not an expert) and then extract
all these pieces. It felt like a rather efficient way of doing it, without
causing too much discomfort or trouble.
Curiously (and thankfully) recovery was almost completely painless.
I didn't even need to use any pain medication (besides what they gave
me right after the procedure). There was quite visible swelling, of course,
but almost no pain at all.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> I hope it was a wisdom tooth.
>> Actually no. One of the molers, right on the middle.
> Why?
The filling kept getting infected. I lose count of how many times I had
it refilled. In the end, they decided to just remove the tooth and be
done with it.
http://blog.orphi.me.uk/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> > Why?
> done with it.
How is this possible? One would think that modern dentistry would have
solved such problems.
I assume getting an artificial tooth to replace it is such a specialized
form of "cosmetic" surgery that the health care system isn't going to pay
for such things there?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> done with it.
I guess the filling doesn't make a perfect seal, or maybe there's a
crack somewhere else in the tooth. IDK. All I know is that having an
infected tooth hurts quite a bit.
Obviously, I don't have (and never will have) that amount of money.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
They just did. ;-)
It's not cosmetic if you're fixing an infection. "Cosmetic" generally means
"voluntary" in this sort of thing. So if the dentist says "You need a
denture there to keep the teeth from shifting inappropriately" it's not
cosmetic, any more than a prosthetic limb is.
Quoth the raven:
Need S'Mores!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Losing one tooth is certainly not a severe impairment, and one could
argue that fixing it with an artificial tooth is more of a cosmetic fix
than a necessary one (in most countries with a public health care system
the system usually doesn't pay for unnecessary cosmetic surgery, unless
it can be demonstrated that the life of the patient gets severely degraded
without the surgery). Of course I'm not a medical professional, much less
a dentist, so I have no idea how they classify this. I assume it's up to
the doctor to decide if the operation is necessary or not.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Warp wrote:
> I assume it's up to the doctor to decide if the operation is necessary or not.
That's what I was trying to express. Sometimes losing a tooth on one side
will make the other teeth move to fill the gap over time, leading to poor
matching between upper and lower teeth. In that case, it wouldn't be cosmetic.
Quoth the raven:
Need S'Mores!
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Thu, 26 Aug 2010 13:07:26 -0700, Darren New wrote:
>> or not.
> side will make the other teeth move to fill the gap over time, leading
> to poor matching between upper and lower teeth. In that case, it
Yes, I've heard that can be a real problem - a coworker of mine has an
issue with a lost tooth (he plays hockey, imagine that - missing teeth
<g>), and it would cost him about C$3000 (he's in Canada) to have a post
put in to support an artificial tooth.
Ouch indeed.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I had four of my molers removed and I can still fit my tongue in all the
gaps :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> than a necessary one.
Apparently Cute QA Girl was missing a tooth. Though in her case, it's
probably due to some hockey incident... ;-)
AFAIK, it didn't bother her too much. And she was still cute, too.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
