POV-Ray : Newsgroups : povray.off-topic : Stupid question time Server Time
27 Feb 2026 03:22:16 EST (-0500)
  Stupid question time (Message 23 to 32 of 32)
Subject: Re: Stupid question time
Date: 22 Jun 2010 13:19:23
Message: <4c20f09b$1@news.povray.org>
>> So each time you analyse a set of samples, there is a linear
>> conversion, but it's different each time.
> Only if the cross sectional area or length of the sample is different.
> You really need to read up on the physical properties of materials.
Well, sure. I mean, it's not like the resistence of a diode varies with
voltage.
Oh, wait, actually that's exactly what it does. :-P
So what makes you so certain that passing a current through a sample
can't cause some kind of chemical reaction that affects its electrical
characteristics, given that we don't even know what the hell this
machine is or what it does?
http://blog.orphi.me.uk/
Date: 22 Jun 2010 13:20:00
Message: <4c20f0c0$1@news.povray.org>
On Tue, 22 Jun 2010 18:15:30 +0100, Orchid XP v8 wrote:
> Excel can *import* text files with all sorts of strange delimiters.
> However, it seems to be unable to *create* anything except CSV or
> tab-delimited; there's no option for pipe-delimited.
Fortunately, that's pretty easy to work around with a scripting
language.  Export tab delimited and then use something like awk to
replcae the tabs with pipes = job done.
Jim
Date: 22 Jun 2010 13:22:13
Message: <4c20f145$1@news.povray.org>
Oh, sure, I'm not disputing that. I'm just wondering where the hell some
random user who can barely operate Notepad has heard of pipe-delimited
files from...
Date: 22 Jun 2010 13:54:23
Message: <4c20f8cf$1@news.povray.org>
> files from...
Probably a vendor that they interact with who said "we need/will provide
files in this format".
I interact with a company that delivers exams and a company that tracks
exam results and certifications; the typical user of the systems they
provide is non-technical, and they provide data in that type of format -
it's actually fairly widely used because "|" isn't often part of actual
data.
The perhaps surprising thing is that Excel and oocalc both don't have an
option built in for exporting files in that format, given that they are
so widely used.
Jim
Date: 22 Jun 2010 14:07:23
Message: <4c20fbdb$1@news.povray.org>
Am 22.06.2010 16:46, schrieb Darren New:
> If you think a question is stupid, it's because you already know
> the answer. So give it to them. :-)
Nice point ;-)
Date: 22 Jun 2010 14:33:04
Message: <4c2101e0$1@news.povray.org>
>> files from...
I got the impression that she created one of these files by mistake, and
then whoever else she was interacting with rewrote the spec to match.
Which still leaves the question "how the hell did you manage to do this
in the first place?" Oh well.
> so widely used.
Yeah, I had assumed it would be there...
Date: 22 Jun 2010 15:32:38
Message: <4c210fd6$1@news.povray.org>
> voltage.
For a start you know what units it measures and you can research how to
measure “admittance”.
Of course passing a current through a material affects its properties.
Even a resistor will change its resistance as you pass a current through
it and it heats up. The trick is to use as small a current or voltage as
will work and let the material reach its working temperature.
Electronics is not all zeroes and ones, you have to think physical
properties as well.
As for a material having a chemical reaction:  If it were to have a
reaction that changed its properties adversely then that is the wrong
way to test it. Someone who understands the problem will come up with a
solution.
Best Regards,
Date: 22 Jun 2010 16:33:35
Message: <4c211e1f$1@news.povray.org>
> Nice point ;-)
There are no stupid questions only stupid answers.
Or as I often say, ask a stupid person, get a stupid answer.
Best Regards,
Date: 22 Jun 2010 17:08:53
Message: <4c212665$1@news.povray.org>
There are no stupid questions. Only stupid people asking questions.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 23 Jun 2010 02:32:28
Message: <4c21aa7c$1@news.povray.org>
I might argue the *"Only"* if I were that sort of person. ;-)
Best Regards,
