POV-Ray : Newsgroups : povray.off-topic : BPM Server Time
14 May 2026 20:03:38 EDT (-0400)
  BPM (Message 11 to 20 of 77)
Subject: Re: BPM
Date: 8 Jun 2010 02:52:00
Message: <4c0de890@news.povray.org>
>> Hey, at least he didn't say it's obviously impossible. :-)
> No - just ludicrously difficult. ;-)
Funny how it took me about 30 mins of research and coding to come up with a
working program, when previously I didn't know a single thing about it.  It
didn't require any skills beyond being able to set up a struct and calling
windows API functions.  In my book ludicrously difficult is when I think and
work on something for *weeks* or *months* and cannot get anywhere close to a
working program.
> Still, I would also guess that, say, CDex is going to write identical WAV
> files for every track ripped. So I can probably just go measure how many
> bytes the header is, and skip that...
IIRC that's exactly what I did at some point previously.  I guessed/knew the
samples were in 16bit stereo format, so just took 4 bytes at a time from the
file and experimented with the order until the result wasn't white noise!
Subject: Re: BPM
Date: 8 Jun 2010 02:54:12
Message: <4c0de914@news.povray.org>
> See attached. Press any key rhythmically to send "taps". The reset
> button... uh... resets the stats.
If I press buttons too fast I get a negative maximum BPM :-)
Subject: Re: BPM
Date: 8 Jun 2010 04:03:16
Message: <4c0df944$1@news.povray.org>
> with a working program, when previously I didn't know a single thing
> about it.  It didn't require any skills beyond being able to set up a
> struct and calling windows API functions.
So I'm guessing you know an awful lot more about C than I do.
>> WAV files for every track ripped. So I can probably just go measure
>> how many bytes the header is, and skip that...
> the samples were in 16bit stereo format, so just took 4 bytes at a time
> from the file and experimented with the order until the result wasn't
> white noise!
I suppose you could just open the file in a hex editor and look for the
chunk names.
Oh, wait - you'd need a hex editor to do that...
Subject: Re: BPM
Date: 8 Jun 2010 04:05:02
Message: <4c0df9ae$1@news.povray.org>
Really? That's impressive. You're a special guy! :-D
No, the minimum and maximum values are derived by taking the mean and
adding/subtracting the SD. If the SD is sufficiently large, it should be
possible to make the minimum value negative. (I.e., if the error ratio
is greater than 100%.) Not sure how you'd make the maximum go negative,
but it's probably possible somehow...
Subject: Re: BPM
Date: 8 Jun 2010 04:28:15
Message: <4c0dff1f@news.povray.org>
>> a working program, when previously I didn't know a single thing about it.
>> It didn't require any skills beyond being able to set up a struct and
What's C got to do with it?  You can call DLL functions from lots of
different languages.  So long as your language allows you to set up a block
of data with the common data types it shouldn't be at all tricky.
Subject: Re: BPM
Date: 8 Jun 2010 04:31:56
Message: <4c0dfffc$1@news.povray.org>
Sure. So long as you have the necessary magic numbers for the specific
functions you want to access, and you know how to do the pointer
manipulation to make it happen. It's not exactly trivial though.
(Unless, of course, you're working with a language which actually has
built-in support for calling DLLs. Then presumably it *is* trivial.)
> block of data with the common data types it shouldn't be at all tricky.
Heh, right.
I still think recording a few keypresses and doing some statistics on
them is way, way simpler.
Subject: Re: BPM
Date: 8 Jun 2010 04:32:41
Message: <4c0e0029$1@news.povray.org>
> possible to make the minimum value negative. (I.e., if the error ratio is
> greater than 100%.) Not sure how you'd make the maximum go negative, but
How are you calculating the maximum BPM?  I guess you are calculating some
minimum beat time using the mean and SD and then inverting it?  Maybe the
minimum beat time is negative if the SD is too big compared to the mean?
Subject: Re: BPM
Date: 8 Jun 2010 04:34:33
Message: <4c0e0099$1@news.povray.org>
>> be possible to make the minimum value negative. (I.e., if the error
>> ratio is greater than 100%.) Not sure how you'd make the maximum go
>> negative, but it's probably possible somehow...
> some minimum beat time using the mean and SD and then inverting it?
> Maybe the minimum beat time is negative if the SD is too big compared to
> the mean?
Minimum = mean - SD
Maximum = mean + SD
(But remember that it takes the mean and SD over the beat period, and
then takes the reciprocol of that to compute the BPM value.)
So, yes, as I asserted, if SD > mean than one of the figures comes out
negative.
Subject: Re: BPM
Date: 8 Jun 2010 04:42:12
Message: <4c0e0264$1@news.povray.org>
Since when do you take the simpler solution? :-)
Subject: Re: BPM
Date: 8 Jun 2010 04:50:52
Message: <4c0e046c@news.povray.org>
What you trying to say? :-P
