![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Subject: Re: Fan without blades: should we ROTFL or weep?
Date: 6 Jun 2010 13:29:46
Message: <4c0bdb0a$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Paul Fuller wrote:
> On 6/06/2010 12:58 PM, Sabrina Kilian wrote:
>> Jump to new topic: Dyson's patents may have run out, but I haven't seen
>> any bagged or bag-less vac that beats the old Rainbows. Similar concept,
>> impel the air into a cyclone; only the rainbows used a cyclone of water.
> I have seen but not used water based vacs. More tagged as 'carpet
> cleaning'. You could hire them from shops at one point. Maybe they
> were the 'Rainbow' mode that you mentioned?
The ones I have seen at shops, or more specifically adverts for cleaning
shops, are ones that push water onto the carpet and then pull it back
off again. Used with water, they are called carpet shampooers around
here. The vac I used worked like a normal vacuum, but instead of a bag
or bin it just funneled the air into a container of water. Absolutely
disgusting to watch water turn from clear to filled with the stuff one
house could hold on the floor in a week. Worked better than HEPA
filters, though.
>> Back to topic: I saw one of the Dyson fans at a big store, I was
>> impressed by the design. It does hit "Oh, shiny" quite well. But I will
>> still wait for the cheap knock-offs, I can't afford $300 for
>> mass-produced art.
> Same here. Doesn't seem like a big enough problem to warrant the
> expense (assuming that they are indeed better). I've never bought
> things for cool factor alone.
Oh, I would and have. Just not pop-art.
> Plus I would almost never buy V1 of something radically new. Even the
> original Dyson vac looks relatively primitive and lacks a lot of the
> refinements of the newer generations.
Also a good reason. However, I can not see many directions to take the
fan concept. Higher speeds, maybe, or floor stands.
Now, if they made a humidifier version, and added blue LEDs inside the
turbine to make the mist glow, then I might get one.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 6 Jun 2010 19:34:10
Message: <4c0c3072@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Examples please.
Sounds like a DIY project.
I was thinking about trying it with a polystyrene ball. Point the fan
upwards. Throw the ball up into the ring. The air flow carries it
through. Then would it be trapped in the stream above the ring by the
Bernoulli effect ?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Bernoulli effect ?
Yes. Dyson made a video where they routed balloons thru many dozen of these
things in a big loop.
Eiffel - The language that lets you specify exactly
that the code does what you think it does, even if
it doesn't do what you wanted.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Jun 2010 00:32:10
Message: <4c0c764a$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Bernoulli effect ?
I imagine it would, much like a toy I had when I was a kid.
Jim
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On 7/06/2010 12:39 PM, Darren New wrote:
> Paul Fuller wrote:
>> Then would it be trapped in the stream above the ring by the Bernoulli
>> effect ?
> these things in a big loop.
Here it is - http://www.youtube.com/watch?v=4WNcjkZ6d0w
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Jun 2010 14:05:24
Message: <4c0d34e4$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Examples please.
I suppose the definition of 'cool' would be the trick. To me, hand made
jewelery is cool, even if it is just driveway gravel wrapped in plastic
electrical wire. Cheap old cameras are cool, more so if I can make them
work again. Bow-ties are cool. Non-functional? The doll that happened to
match my desk so well that she has sat on it for years without being
noticed often. Some old networking hubs that will look nice in the 19U
racks that serve as storage cabinets. An old brick car phone.
All cheap, but all purchased because of that 'oh, cool, I don't need
that but I want it' factor.
If you were scoping to see what was worth stealing, not a whole lot. ;-)
Right, for the cheap knock offs. That way, when the liquid fries one of
the motors, I am only out a few dollars.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> > Examples please.
> work again. Bow-ties are cool...
Good job I did not reply in High Dudgeon. ;-)
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Jun 2010 20:25:20
Message: <4c0d8df0@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Drat. Not worth the airfare.
A tank of propane may have some possibilities with one of these although
they probably are not powerful enough.
Once upon a time I worked as a sysprog for a bank. There was an
incident when water condensation built up in the air conditioning units
on Level 3. The outlet pipe had become blocked and water spilled over
the collection pan, found a crack in the slab, trickled into a light
fitting and collected until it broke the fitting and dumped out.
Estimated to be about 10 litres of water.
Then the real drama began. Level 2 was the main computer room. The
light fitting was the one sitting above the disk system housing amongst
other things the volumes for the mainframe running the production online
system. Water + Electronics = Failure.
Much mayhem ensued.
The link is that one of the IBM engineers had the idea to get some
industrial gas heaters in to help dry things out. These were large
blowers with gas burning in the air stream. Crank up the speed and
amount of gas and they were quite impressive. Somewhere less than a
rocket motor but still a *lot* better than a hand electric hair dryer.
Quite an interesting day. I had a spare system image on another disk
unit on the other side of the computer room. We got the system back up
in the evening and got through batch in time for the next day. The
affected unit was rebuilt. It needed some new controller boards but the
physical drives were fine. No data lost.
Good blokes those IBM engineers.
Not so good is the idea of putting the air con plant directly above the
computer room.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 7 Jun 2010 21:18:49
Message: <4c0d9a79$1@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>>> > Examples please.
In the land of checkered planes and mirrored spheres, how could I not
like op-art?
Should have said pop-art and minimalism. I still wonder how a black
square on a white canvas was influential so long after the invention of
both black ink and white canvas. But that is an off-topic art rant.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Date: 8 Jun 2010 16:04:55
Message: <4c0ea267@news.povray.org>
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> like op-art?
your heart out.
Some minimalism is OK (IMO) but I think it can be over done. (Is that an
oxymoron?)
Best Regards,
Download '4spheresandaplane.jpg' (104 KB)
Preview of image '4spheresandaplane.jpg'
![4spheresandaplane.jpg](/povray.off-topic/attachment/%3C4c0ea267%40news.povray.org%3E/4spheresandaplane.jpg?preview=1)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
