POV-Ray : Newsgroups : povray.off-topic : Unit tests Server Time
2 Jul 2026 13:46:25 EDT (-0400)
  Unit tests (Message 11 to 20 of 21)
<<< Previous 10 Messages Goto Latest 10 Messages Next 1 Messages >>>
Subject: Re: Unit tests
Date: 3 Jun 2010 16:21:00
Message: <4c080eac$1@news.povray.org>
Orchid XP v8 wrote:
> Whilst Haskell does have an assert() function, it seems to be more
> popular to use QuickCheck.
Of course, the *other* thing that's popular is constructing software in
such a way that it cannot malfunction in the first place. (E.g., if
negative numbers aren't allowed, use unsigned integers. Now you don't
have to check whether the input is negative, because it can never *be*
negative.) Obviously, there are limits to how well this approach works...
http://blog.orphi.me.uk/
Date: 3 Jun 2010 18:03:54
Message: <4c0826ca$1@news.povray.org>
Darren New wrote:
> Warp wrote:
>> Orchid XP v8 <voi### [at] devnull> wrote:
>>> Eiffel has preconditions *and* postconditions, which most people don't
>>> seem to bother checking with assert() calls.
>>   A little thought experiment: How would you write a comprehensive
>> postcondition to a function that sorts a list/array of elements?
> Trivial.
> Forall(i < length-1) assert(j[i]<=j[i+1]);
> Basically, the definition of sorting. Of course, you need to be able to
> put qualifiers in your assertions.}
A sorting function that, given any input, returns [1,2,3,4,5], will pass
that test.
Try again.
Date: 3 Jun 2010 20:01:25
Message: <4c084255$1@news.povray.org>
>> Trivial.
> that test.
Heck, for that matter anything returning a zero-length array would pass. OK,
to be *comprehensive*, you would have to add that the result is a
permutation of the original. You could do this by counting how many times
each original value occurs in the list and making sure it occurs in the
result the same number of times.
    Eiffel - The language that lets you specify exactly
    that the code does what you think it does, even if
    it doesn't do what you wanted.
Date: 4 Jun 2010 02:07:24
Message: <4c08981c$1@news.povray.org>
On 06/03/10 11:47, Darren New wrote:
>> On top of that, any kind of testing is going to be easier if a
>> function's output depends only on its current inputs...
> Yep. The problem with "unit testing" per se is that it only tests a
> unit. It doesn't test anything except the invariants of the unit you're
> testing.
	I wouldn't call it a "problem".
Guitar for sale. Very cheap. No strings attached.
Date: 4 Jun 2010 04:07:48
Message: <4c08b454@news.povray.org>
> OK, to be *comprehensive*, you would have to add that the result is a
> times each original value occurs in the list and making sure it occurs
> in the result the same number of times.
Let's hope Warp doesn't ask us to test for a *stable* sort...
Date: 4 Jun 2010 11:32:37
Message: <4c091c95@news.povray.org>
>> testing.
Well, a limitation.  I do very little programming where the invariants of
the class are particularly difficult to ensure.  That would be
"datastructures" and "file systems", which I use system/language libraries for.
Date: 4 Jun 2010 11:33:43
Message: <4c091cd7$1@news.povray.org>
>>> testing.
> of the class are particularly difficult to ensure.  That would be
> libraries for.
Or, to rephrase, sure, a SQL server can have gazillions of unit tests that
make sense. But I don't write SQL servers. That's been done. :-)
Date: 4 Jun 2010 12:13:10
Message: <4c092616@news.povray.org>
> >> Trivial.
> > that test.
  That was one warning example at school aboit how easy it is to write
pre- and postconditions which actually are not comprehensive enough.
The sorting example is superb to demonstrate that, because many people,
like you, think that it's enough to go through the array after the sorting
is done and check that every value is larger or equal to the previous value.
The counter-example to this is, of course, to make the "sorting" fill the
array with the same value (eg. the first one), and it would pass the test.
  At the same time it poses an interesting thought problem: *How* would you
write a post-condition that truly checks that the resulting array has the
same values as the original, but sorted? And a bit more difficult: What
would be the asymptotically fastest possible way of doing the check?
Date: 4 Jun 2010 12:41:12
Message: <4c092ca8$1@news.povray.org>
Yes, it's a good point. :-)
Obviously had it not been an offhand post to p.o-t I would have put more
thought into it. I thought you were asking more about the technology of how
it was done, and I was saying "obviously you need universal qualifiers like
this..." rather than trying to actually be comprehensive.
Sure. As I said, you can loop thru the original array, counting the number
of times old[i] appears in old, then for each of those loop thru new[j]
counting the number of times old[i]==new[j].  So it's at worst O(N^2).
It's not hard to specify, which is what I thought you were getting at. Hard
to do efficiently, but that's what people do in debug builds.
For example, MS has a rule that you're not allowed to publish performance
reviews of their beta software. At one point, they gave a beta of Excel to a
journalist, and they tried it out, and published that it was terribly slow.
Well, it was a debug build, and every time you did an update, it would
calculate everything with the optimized path, then it would iteratively
calculate every single cell over and over until it stabilized (or they
looped more than the number of cells), and then compared the two. Of course
it was slow.
Once you're confident your sort works, you don't have to test you haven't
introduced new values in production. :-)
Date: 4 Jun 2010 15:16:34
Message: <4c095112$1@news.povray.org>
>>> testing.
> libraries for.
	I think you took me too seriously. I meant that it does precisely what
it claims to. It's not meant for all kinds of tests. Just one kind.
	I suppose limited is more appropriate, but it still sounds too
negative.<G> It's like saying mutt is limited because it doesn't send
mails and needs the sendmail command. It just was never meant for
sending mail.
