POV-Ray : Newsgroups : povray.off-topic : Context switching Server Time
5 Jul 2026 12:08:27 EDT (-0400)
  Context switching (Message 151 to 160 of 222)
Subject: Re: Context switching
Date: 22 Apr 2010 15:47:54
Message: <4bd0a7ea$1@news.povray.org>
On 04/22/10 03:38, Warp wrote:
>> More specifically,
>> http://www.codeproject.com/kb/shell/ShellExtGuide8.aspx
>   So in order to get Windows Explorer to show exact byte counts, I would have
> to download and install Visual Studio, get it to work, write an extension
> manually, install it, and keep it with me in an USB stick so that I can
> install it in a friend's computer if I ever want to see the byte sizes there
> as well?
	Or, you know, just use a different file explorer program.
	Somehow I've lost the point of this whole discussion. Who said you have
to use just Windows Explorer?
>   Konqueror uses thousands-separators in file sizes.
	And I'm sure there exists software that runs on Windows that shows
exact file sizes.
	I sense an apples to oranges comparison going on here. Why are you
comparing Konqueror with Windows Explorer, anyway?
Sign on ZIP file : CAUTION! Contents under pressure!
Date: 22 Apr 2010 15:50:54
Message: <4bd0a89e$1@news.povray.org>
On Thu, 22 Apr 2010 09:10:03 +0100, Invisible wrote:
> (I'm still having trouble thinking up a use-case for that. About the
> only thing I can think of is trying to find out which header file
> defines a particular symbol or something.)
Header file definitions, sure.
Some of the things I grep for regularly:
Which file contains contract information for a particular partner?
Which of the chat log files I have contains a reference to a particular
website, user ID, password, or discussion?
Which of the configuration files for apache contain information about a
particular virtual host?
Jim
Date: 22 Apr 2010 15:54:17
Message: <4bd0a969$1@news.povray.org>
andrel wrote:
> Ah ok. And how do I do that? I'll find out next week after some deadlines.
http://articles.techrepublic.com.com/5100-10878_11-6163793.html
GIYF, once you have a basic idea of what the answer looks like. :-)
In particular, peek at Figure G.
If that doesn't help (and you might have to tell it to reindex stuff), then
there's something out there somewhere that provides a "this is really a text
file" interface for an arbitrary list of extensions.
http://www.bench3.com/2009/06/customize-search-feature-in-windows.html
explains that a bit more, showing you where you'll see it.  See if that
helps. And again, remember that unless you wait for the rebuild of the
index, it won't necessarily show up right away.
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 22 Apr 2010 16:00:00
Message: <4bd0aac0$1@news.povray.org>
On Thu, 22 Apr 2010 09:12:03 +0100, Invisible wrote:
>>> I throught that grep is an overly-complicated way of searching for the
>>> location of a string within one particular file? (I usually just use
>>> my text editor's "search" function.)
>> Does your editor support regular expressions?   Most only support a
>> simple substring search.
> Is there some advantage to supporting regular expressions?
Yes, because if you don't know the exact string you're looking for, you
can specify a more general string that is likely to be found.
> I mean, I realise that hypothetically a regex can find things that a
> normal search can't. But in reality, when are you *ever* going to use
> that? What would it be useful for?
I use it several times a week myself, reasons include chat log files in
my IM client where I might need to find a conversation I've had in the
past about something.  I recently was trying to remember the name of an
internal website, but I couldn't remember who I had talked to about it or
the website name.  I was able to use grep to find what I needed in a
matter of seconds without searching (checks - "find -type f | wc -l" -
8694 chat log files across all the different IM protocols I use).
Doing that by hand would be very tedious and would take days, and even
then, I might not find what I was looking for.
>> As Warp said, you also can traverse a directory structure with grep to
>> find the file(s) that have the string in them.
> I didn't know that. I thought grep was just for searching within one
> file.
If I tell you the 'net is wonderful resource for information, what will
you say in response?  ;-)
Jim
Date: 22 Apr 2010 16:01:27
Message: <4bd0ab17$1@news.povray.org>
Darren New wrote:
> Orchid XP v8 wrote:
>> With an extension? Or natively? I don't recall seeing anything about
>> it in the docs. (I did find DDE, however. And registry access.)
> That said, it's in ActiveState's teapot, so in a sense it's "native" and
> "comes with Tcl".
OK, fair enough. I just didn't see anything about it while reading the
FreeWrap documentation.
http://blog.orphi.me.uk/
Date: 22 Apr 2010 16:02:56
Message: <4bd0ab70$1@news.povray.org>
On Thu, 22 Apr 2010 09:06:38 +0100, Invisible wrote:
>>> Now, in fairness,
>>> as far as I can tell Windoze can't do this *at all*. But it was pretty
>>> hard to do from Linux either.
>> Windows = Internet Connection Sharing Linux = at least with openSUSE
>> 11.2, YaST -> Firewall -> Masquerading. Two NICs need to be configured
>> and running.  You can even set port forwarding there.
> Interesting. I thought ICS only works for dialup modems?
Apparently not.  Dunno the current state, as I don't use Windows...
Jim
Date: 22 Apr 2010 16:08:44
Message: <4bd0accc$1@news.povray.org>
>>> Nonsense. Every programming language and every scripting language
>>> supports COM that I've seen.
>> I've yet to find a language that can do it.
> I've named half a dozen. What languages do you use?
I just named a bunch of 'em. ;-)
>>> Didn't you tell me Haskell has a COM interface?
>> Yes, but it doesn't compile on Windows.
> Are you sure it's "it doesn't compile" and not "I don't know how to
> compile it"?
Well, I asked about it and got stoney silence. From past experience, the
solution probably begins with "install a Unix emulator..."
>>> I know Tcl does.
> http://www.vex.net/~cthuang/tcom/
> Extensions *are* native. Tcl is a language for writing extensions in.
I have a vague recollection of seeing some Tcl extension that did
something I wanted, and being unable to actually make it work. I won't
beat on about that too much though since I no longer remember enough
details.
>>> What language have you used on Windows that does *not* do COM?
>> Java, Smalltalk, Eiffel, JavaScript, Tcl, Haskell, POV-Ray (well,
>> duh!) As far as I know, none of them support it.
> In other words, you didn't take the time to google
> java "com interface"
> smalltalk "com interface"
> eiffel "com interface"
> tcl "com interface"
> before you said you have no languages that support it.
Ah, so they added it to Java? (I'm not sure I even want to know how they
made that platform-neutral...) I haven't used Java for a while, but when
last I did it was legendary that the APIs undergo radical changes with
every minor point release.
For Smalltalk, I'm going to put my foot down and assert that the
implementation that *I* have doesn't support COM.
And Eiffel... yeah, well, I don't use Eiffel any more. And Tcl we've
talked about elsewhere.
> Javascript per se doesn't, but jscript does, which is pretty much the
> same thing with a different name.
I'm clearly going to have to investigate this one... It might actually
be useful.
Date: 22 Apr 2010 16:23:18
Message: <4bd0b036@news.povray.org>
discussion : 4BD### [at] gmailcom...
> Matlab files with extension .m in XP
> no luck but your google skills are way beyond mine anyway.
> Do you have an idea why it would not find those or look into them anyway?
> Because if I had a theory about that I could try to find a cure.
Darren gave you the answer, but here's the magic google search:
http://www.google.com/search?q=xp+search+matlab+files
The right answer is the first one.
I've largely stopped wondering about oddities in Windows (or Office or any
software with a big following). I just google for answers: it's faster and
usually very smart people have found workarounds.
G.
Date: 22 Apr 2010 16:28:53
Message: <4bd0b185$1@news.povray.org>
> Jim
Your lighting bill must be huge ;-)
Best Regards,
Date: 22 Apr 2010 16:31:13
Message: <4bd0b211$1@news.povray.org>
The god of capitalism? Hmm! :-)
Best Regards,
