POV-Ray : Newsgroups : povray.off-topic : Context switching Server Time
5 Jul 2026 08:44:48 EDT (-0400)
  Context switching (Message 131 to 140 of 222)
Subject: Re: Context switching
Date: 22 Apr 2010 12:30:30
Message: <4bd079a6$1@news.povray.org>
Warp wrote:
>   No. Windows doesn't support them, so user have learned to live without
> them, and then they are claiming that they "don't need them" (one of the
> most common "windows'isms").
More like "Programmers learned to live without them." I'd classify that as a
good idea.
What do you *need* symlinks for?  I've never found a good use except getting
around paths that are hard-coded that shouldn't be, or distributing files
from one directory onto multiple file systems due to not all file systems
having the same capabilities.
>   If Windows had supported soft links from day one, they would probably be
> in pretty common use, and it would be unthinkable to drop them.
Possibly.  That wouldn't necessarily be a good thing.
>>  Software is written to not hard-code paths that don't need to be
>> hard-coded.
>   Yeah, because that's the *only* thing soft links are used for.
Well, tell me what else you *need* them for that a configuration variable
wouldn't work just as well.
>   You might yourself believe that, but I don't think it's true. I'm pretty
> certain that if Windows had supported soft links from the very beginning,
> you would today be defending them. (You would *especially* be defending
> them if Unix/Linux didn't support them, I'm pretty sure.)
Oh, give it a rest, Warp.
>>  I think soft links are an abomination, and I've
>> only ever seen them used to basically correct flaws in software
>> configurations.
>   Linux distros use them frequently to, for example, make "aliases" of
> libraries of different versions to an actual file which is fully compatible.
OK. Windows puts this information in the files themselves, and the code asks
to load the library with the compatible version. Or it looks up the
registration in the registry. (Hence the name, you see.)
The symlink solution works OK until the upgrade from libxyz.1.2.so to
libxyz.1.3.so breaks the program written to use libxyz.so. And dont tell me
it doesn't happen, as I have not infrequently binary-edited libraries to
change the strings there.
> In other words, if version 1.2.3 of a library is fully backwards compatible
> back to version 1.0.0 of the library, the "versionless" library (eg.
> "libsomething.so") file will usually be linked to the 1.2.3 version of the
> file (eg. "libsomething.so.1.2.3"), as well as the several versioned files
> (eg. "libsomething.so.1" would be a soft link to "libsomething.so.1.2.3" if
> the latter is fully backwards compatible with version 1).
Yes, I know how that works.
>   This is not a question of "bad configuration".
Inadequate configuration. The program itself should be telling you which
versions it's compatible with, and the loader should be enforcing that. The
fact that you *can* do it with the file system doesn't mean that's a *good*
way to do it. :-)
> It's a question of
> practicality (an executable may have been linked against version 1.0.0 of
> the library, but it will work ok with the version 1.2.3, so the soft link
> will make it load that) and saving disk space (especially if the library is
> several megabytes in size).
This works less well when you have a bunch of programs that you don't have
the source for which may or may not break when you change library versions.
Hence, "DLL Hell".  That's much less common when you can just test every
piece of software written for the platform when you change a library.
>   And before you start nitpicking about how that could be solved in other
> ways (which I'm 100% sure you will do), that was just ONE EXAMPLE of many.
Sure. Let's hear some others. Seriously.
>   (Another cool example is when a software package consists of several
> executables, each one doing slightly different things... But instead of
> having a 5-megabyte file for each executable, they are all in fact soft
> links to one single 6-megabyte executable which then acts different depending
> in which name was used to start it. Again, this saves disk space.)
Yep. This is what the whole busybox thing is about. Given that, the common
functionality ought be in a shared library. Otherwise, you're taking up more
memory than disk space.
Or in the Windows way, you have one tiny file that launches the library with
different arguments, so you don't have to depend on the file name not
changing in order to make it work. You know, like, a shortcut or something. :-)
How would a *user* use symlinks, is really what I want to hear. Not someone
managing software installations, but an end-user. Why would I want a symlink
in my home directory, for example?
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 22 Apr 2010 12:33:21
Message: <4bd07a51$1@news.povray.org>
Warp wrote:
> Darren New <dne### [at] sanrrcom> wrote:
>> I.e., "I find Windows difficult because it's not made for nerds by nerds, so
>> to make it as nerdy as Linux, I have to download some free programs and
>> install them." :-)
>   Most of which are very specific, support only a limited amount of
> functionalities, cannot be chained to perform more complex operations,
> are often inconvenient to use, large and heavy, and litter your system
> with tons of setup files and registry entries which it will leave there
> even after you uninstall the app.
http://gnuwin32.sourceforge.net/
Jeez, you're really harsh on those GNU guys.  Most of those programs are
simple stand-along .exe files.
But that's OK. I understand that you're more into bitching about Windows
than you are in improving your experience, so carry on.
 > Also if they do very low-level stuff,
> they usually don't integrate very well with Windows and its own apps
> (such as Windows Explorer).
Well, duh. How well does grep integrate with GNOME?
Date: 22 Apr 2010 12:33:49
Message: <4bd07a6d$1@news.povray.org>
Invisible wrote:
> Darren New wrote:
>> I put the task bar on the side. I can probably put 40 tabs on there
>> before it gets close to full.
> Logically that makes sense - especially if you have a widescreen
> monitor. But that would just be too weird - for no better reason than
> "it's not what I'm used to".
It wasn't what I was used to etiher, but I got used to it really quickly. I
resisted for years myself.
Date: 22 Apr 2010 12:46:32
Message: <4bd07d68$1@news.povray.org>
Invisible wrote:
>>> I mean, I realise that hypothetically a regex can find things that a
>>> normal search can't. But in reality, when are you *ever* going to use
>>> that? What would it be useful for?
>> For example, finding where in the file a symbol is defined instead of
>> used.
>> I do that all the time. "Where is the definition of this macro?"
> As I say, I've never needed to do that. (Then again, I don't work with
> other people's code, only my own.)
Lucky you!
Date: 22 Apr 2010 12:53:27
Message: <4bd07f07$1@news.povray.org>
> me it doesn't happen, as I have not infrequently binary-edited libraries
> to change the strings there.
BTW, that said, I think it's more like this was a problem,a nd rather than
write code to fix the linker, people started making quicky patches using
symlinks.
Its a quick and simple solution to something that plagues MS for years and
years.  I just don't think it's the *right* solution.  I'm more of a code
and API kind of programmer than a file system and file format kind of
programmer.
> The fact that you *can* do it with the file system doesn't mean that's a
> *good* way to do it. :-)
Oh, and you'll notice that Linux goes thru all the libraries when it starts
anyway to gather up version information, and you'll notice that GNU has
defined a library format that has a textual description of which libraries
you *really* want to load. Both of these are a better (IMO) solution than
using symlinks. And not because Windows doesn't have symlinks, but because
it's less fragile.
Date: 22 Apr 2010 13:33:07
Message: <4bd08852@news.povray.org>
> >   So in order to get Windows Explorer to show exact byte counts, I would have
> > to download and install Visual Studio, get it to work, write an extension
> > manually, install it, and keep it with me in an USB stick so that I can
> > install it in a friend's computer if I ever want to see the byte sizes there
> > as well?
> Pretty much, yah. Same as any other program you write. What did you expect?
  I expect Windows to support such a *basic* feature as showing the sizes of
files in bytes. It's not like it's too much to ask. I'm sure someone at MS
could add the feature in 5 minutes. In fact, I wouldn't even be surprised
that they *already* have the feature but it has been disabled with an #ifdef,
so all it would take to support it is one additional #define.
  But they don't. Why not? I have no idea.
> You mean if I want to indent files the way I like, I have to download emacs,
> write some elisp code, then stick it on a USB stick and carry it around to
> every other emacs-enabled computer?
  Yeah, because indenting code is in the exact same league as showing file
sizes in bytes rather than rounded.
> >   I think you made some kind of claim containing the word "trivial" in some
> > post of yours.
> More trivial than rewriting the shell. A 50-line program is pretty trivial, yes?
  No. Trivial is "click here and here, and you are done".
  You have a rather odd definition of "trivial". It still sounds like "not
impossible".
> >>>> And which byte count do you want?
> >>>   The size of the file. How many bytes it contains. If I opened it with a
> >>> program and started reading bytes, how many I would get before EOF.
> >> Open it raw, or processed, or for backup?
> >   You are nitpicking, and you know it.
> You're nitpicking. You want exact byte counts in one window but not the
> other.
  What? What window? What other window? I have no idea what you are talking
about.
  The only thing I want is an option somewhere that, when checked, will make
Windows Explorer to show file sizes in bytes instead of rounded to kilobytes
or megabytes. That's it. Nothing less, nothing more.
> It's trivial to get that information
  I don't want to "get that information". I want Explorer to use bytes when
listing files and their sizes. "Getting" is too laborious. I don't want to
"get" anything, I want it to show it without me doing anything to "get" it
explicitly.
> yet you complain it's difficult.
  It's extremely inconvenient and slow. I want a full list of a directory
with file sizes in bytes. That's all. I don't want to have to open some
separate info dialog on every single file just to see the size in bytes.
That's just crazy.
  It's not like it would be away from anybody. If someone doesn't want to
see the sizes in bytes, he just doesn't use that specific option. It's that
simple.
> Plus, you can't even clearly define what it is you want to see.
  You know *perfectly* what I mean, so stop acting stupid. You are just
arguing for the sake of argument.
> > Is agreeing with something really so hard?
> I already agreed. You kept bashing at it.
  "you can't even clearly define what it is you want to see" doesn't sound to
me like agreeing.
> >   So if I want to see the individual byte sizes of 20 files, exactly how do
> > I do that "with one extra step"?
> "dir"
  You have an odd definition of "one extra step".
  Pressing the keys 'd', 'i', 'r' and return is certainly not enough. There
are quite many additional steps involved, including going somewhere else than
Windows Explorer.
> >   Each file in a list having its size shown with a different unit is
> > confusing. You can't visually see which of the files are larger and
> > which ones are smaller.
> Click the size column header and it sorts by size.
  That doesn't give me visual feedback on the sizes of the files. It only
tells me which files are larger than the others. It doesn't tell me how
much, unless I start deciphering the units one by one.
> >>>   Except that it doesn't tell that. If you try to copy it to another file
> >>> system or an archive file, it will most probably end up taking a completely
> >>> different amount of space.
> >> Hence the "which size do you want" question. :-)
> >   The amount of bytes in the file. What's so damn hard to understand about
> > that?
> OK, now I ask you "how big is the directory? What's its size? How many bytes
> in that Linux directory? What's so damn hard to understand? I just want to
> know how many bytes are in it."
  I'm not interested in the size of a directory. I interested in seeing the
sizes of the files in bytes, that's all.
  (Seeing the total size of the files in bytes without having to do anything
extra to get it is useful as well, but a somewhat different issue.)
> "How big is that process? How many bytes does it take in memory? What's so
> hard to understand about that?"
  I'm not interested in that in this context.
> Copy the file to another system or an archive file. That's three different
> sizes. Copy the file to another file system may or may not lose the
> compression. Copying it to an archive file is going to need it to carry the
> encryption and ACL overhead as well as alternate streams. That's exactly my
> point.
  So what? I'm not interested in how much disk space the file is taking.
I'm interested in its size in bytes. If disk usage is what one wants, *that*
can be put in some info dialog or whatever you want.
> > that?
> Because first you ask for the amount of bytes in the file, then you ask for
> the amount of bytes you'd read if you opened and read the file. And that's
> two different numbers.
  Why do you keep nitpicking? You understand perfectly what I'm talking about.
> >>>   Yeah, start doing that to a dozen files, rather than seeing it in one
> >>> glance in the file listing. It *is* extremely inconvenient.
> >> If I want the total, I pick a dozen files and say "properties" and it tells
> >> me the total.
> >   Do you have reading comprehension problems? I was not talking about totals.
> The "that" wasn't really clear there. "Start doing that to a dozen files"
> doesn't really say whether you mean "one at a time" or "all at once."
  If Windows Explorer showed sizes in bytes for each individual file *and*
for the total (in the status bar), then it would solve both problems at
once, without the need to open any info dialogs. See? Easy.
> I'm not defending Microsoft per se. I'm just saying you seem to think
> there's some big important reason for this feature not to be here.
  Well, I have yet to see a good reason for it to not to be there.
  (Except Microsoft's incompetence. This is certainly not the only
annoying feature which worked ok eg. on Windows 3 but MS decided to
screw it up for newer versions just for the sake of making it different,
even at the cost of making it usable.)
> I just
> think it's that it didn't sell more copies of Windows. There would be no
> downside to providing it except the need to spend resources providing it.
  There are tons of way more useless features in Windows than this. Features
which almost nobody uses. They didn't have resource problems for those.
Date: 22 Apr 2010 13:54:03
Message: <4bd08d3b@news.povray.org>
  What do you *need* directories for? Useless. Just use a naming convention.
  What do you *need* long file names for? 8 characters are plenty for any
amount of files you might need. Useless to have anything larger.
  What do you *need* Windows shortcuts for? It's not like the system
couldn't work without them.
  If we start dropping everything that is not absolutely necessary, we could
get a pretty bare-bones system.
  On the other hand, other people find convencience features useful.
  You are not giving me much reason to.
> >> configurations.
  And once again we have a hard-coded, specific feature which will work
*only* for dll files but nothing else which might be similar.
  Generic solutions are much more useful than hard-coded, specific ones.
  Yeah, I see how programs are constantly breaking when libraries are
updated.
  Seemingly you missed the "if the library is backwards-compatible" part.
If it isn't, then it will not be sym-linked so that programs will believe
it's the same library, of course.
> And dont tell me it doesn't happen
  I don't remember personally ever seeing it happen in my computer.
OpenSUSE repositories are pretty competent at handling dependencies
properly.
  Then why are you asking for examples if you know that?
  Most programs do. You can use the 'ldd' utility to check which .so files
they depend on, and usually they do have the version number. (Then if you
check the actual .so file itself, you'll usually see that it's a soft link
to a compatible version of the library.)
  As said, if program A depends on libSomething.so.3 and program B depends
on libSomething.so.4, and the latter happens to be fully compatible with
the former, it would be a waste of disk space to have both. Instead, the
former is simply made a symbolic link which points to the latter.
> way to do it. :-)
  Instead, you want to hard-code such specific features as .so file versions
into a loader routine.
  What happens if you are dealing with something similar, but which is not
a bunch of .so files which are loaded by a loader routine?
  Why? For any possible example I could mention you will come up with a
contrived reason why it's "better" to do it in some other way. Just for
  Have you ever heard of "shortcuts" in Windows? They are like a poor-man's
symbolic link.
  Why would a user need those?
  (Yes, go on an rant about how these "shortcuts" are so much infinitely
better than symbolic links. After you have done, please explain to me why
shortcuts *are* useful to regular users while symbolic links *aren't*.
You are insinuating that symbolic links would be completely useless for
regular users. "Shortcuts" are functionally the same, and are being
constantly used in Windows. Are you arguing they are also completely
useless?)
Date: 22 Apr 2010 13:55:39
Message: <4bd08d9b@news.povray.org>
>>  From what I've seen, you can't touch COM unless you're programming in
>> C or C++.
> Nonsense. Every programming language and every scripting language
> supports COM that I've seen.
I've yet to find a language that can do it.
> Didn't you tell me Haskell has a COM interface?
Yes, but it doesn't compile on Windows. (That's The Real WTF, right
there!) Then again, a few people have hinted that it's possible to do
things like COM, ODBC, etc on Unix too...
> I know Tcl does.
With an extension? Or natively? I don't recall seeing anything about it
in the docs. (I did find DDE, however. And registry access.)
> OK, I'll grant that maybe postscript doesn't do COM. Whoops, nope, I
> take that back. Ghostscript supports COM.
PostScript does a lot more than many people realise...
> What language have you used on Windows that does *not* do COM? That
> would be like having a language on Linux that doesn't support
> environment variables.
Java, Smalltalk, Eiffel, JavaScript, Tcl, Haskell, POV-Ray (well, duh!)
As far as I know, none of them support it. (As I say, there's a Haskell
library, but it doesn't work. And even if it did, some documentation
would be nice...)
>> Last time I checked, neither WSH nor Power Shell comes with Windows.
>> You said "all of this is trivial using only the scripting tools that
>> come with Windows". So how exactly do you do this then?
> They both come with Windows.
> Obviously "last I checked" didn't include googling before you posted.
As I posted in another thread, it appears that WSH now comes with
Windows. Obviously this is kind of game-changing; it changes it from a
novel curiosity to something that might have a real-world use...
http://blog.orphi.me.uk/
Date: 22 Apr 2010 14:22:26
Message: <4bd093e2$1@news.povray.org>
> files in bytes.
It does. It just doesn't show it *where you want it*.  It has shown file
sizes in bytes since before there were windows involved.
> I'm sure someone at MS could add the feature in 5 minutes.
Uh, no. Nothing happens in five minutes in MS.  How long do you think it
takes to even translate the help files and header text into 105 different
languages?
Did you ask them?
And you can do that too. Click "open command window here" then click "d" and
then click "i" and then click "r" and then click "enter."
> impossible".
No, I mean adding your own extensions is well supported and well documented.
A small extension is short.
But no, it's not in there by default, and they could add it as easily as
they add any other trivial feature, but they haven't.
>> other.
> about.
The properties window or the cmd.exe window.
I understand that.
09/24/2009  18:39           231,936 XpsRasterService.dll
09/24/2009  19:00         3,068,416 xpsservices.dll
01/20/2008  19:48           942,592 XPSSHHDR.dll
01/20/2008  19:49         2,935,808 xpssvcs.dll
12/31/2006  21:00           625,152 xvidcore.dll
12/31/2006  21:00           120,320 xvidvfw.dll
09/18/2006  14:39             2,650 xwizard.dtd
01/20/2008  19:50           353,280 xwizards.dll
11/02/2006  04:19            94,208 xwreg.dll
01/20/2008  19:49           111,104 xwtpw32.dll
11/08/2008  17:38    <DIR>          zh-CHS
11/08/2008  17:30    <DIR>          zh-CHT
02/24/2010  16:09    <DIR>          zh-CN
12/10/2009  20:05    <DIR>          zh-HK
02/24/2010  16:09    <DIR>          zh-TW
08/29/2007  17:06            61,952 ZIMF.DLL
04/11/2009  00:11           387,072 zipfldr.dll
08/29/2007  17:06           127,488 ZSPOOL.DLL
08/29/2007  17:06            52,224 ZTAG.DLL
             2344 File(s)  1,122,038,817 bytes
               98 Dir(s)  57,167,736,832 bytes free
I know what *you* mean.  I'm just saying that it's not as simple as you
think if you want it usable by more than just you.  Perhaps you're just used
to open source, where you can scratch your own personal itch *and* get it
into the official distribution?
> me like agreeing.
I agreed it would be trivial to put something like this in Windows. I didn't
agree that you can clearly define what you want. ;-)
If you want sizes for multiple files, then yes, it's maybe five seconds of
work instead of two extra clicks.  Maybe four or five mouse clicks, and then
four button presses.
And I'm explaining why, under Windows, that question is ambiguous, by
providing an analogy that shows "how big is it" doesn't always have a
trivial answer.
It was an analogy to explain why what *you* want isn't what everyone else
wants. You want "how big would this file be if the only access was
UNIX-style access".
But most other people are. Hence the default UI.
Indeed, it is.
>>> that?
I'm nitpicking to show that what *you* ask for is different than what many
other people might ask for, even tho they'll all describe it the same way.
I *do* understand what you ask for. Then you ask me "why can't Microsoft do
that?"  And I'm explaining that what you ask for isn't general enough to
sell to hundreds of millions of people, and then you get mad for trying to
explain that.
Indeed it would!
The same reason there's no future value calculations in the calculator. It's
a lot of work for Microsoft to put features in.
And you have good statistics for what features get used most on Windows?
Really? Where can *I* see those?  Or did you work for that department in
Microsoft or something else proprietary?
Date: 22 Apr 2010 14:28:50
Message: <4bd09562$1@news.povray.org>
>>> in C or C++.
I've named half a dozen. What languages do you use?
Are you sure it's "it doesn't compile" and not "I don't know how to compile it"?
>> I know Tcl does.
http://www.vex.net/~cthuang/tcom/
Extensions *are* native. Tcl is a language for writing extensions in.
In other words, you didn't take the time to google
java "com interface"
smalltalk "com interface"
eiffel "com interface"
tcl "com interface"
before you said you have no languages that support it.
Javascript per se doesn't, but jscript does, which is pretty much the same
thing with a different name.
OK, POV-Ray doesn't. It uses a different mechanism for some unknown reason
to supply the "GUI Extension" function.
