POV-Ray : Newsgroups : povray.off-topic : Spectrum Server Time
2 Jul 2026 09:12:02 EDT (-0400)
  Spectrum (Message 44 to 53 of 53)
Subject: Re: Spectrum
Date: 30 Apr 2010 09:23:35
Message: <4bdad9d7@news.povray.org>
> You can reduce this by using another window function - but then,
> strictly speaking, you're multiplying your signal by a window, which
> convolves its spectrum with the spectrum of the window. In other words,
> by windowing the signal you're blurring its spectrum.
Usually a slightly blurred spectrum is the preferred outcome.
> So far, everything I've ever learned about DSP seems to hinge on one
> single equation:
>   sin X + sin Y = 2 cos (X-Y)/2 sin (X+Y)/2
> This says many things. But most obviously, it says that the sum of any
> two waves is also the product of two *other* words, and vice versa. So
> the question is, at what frequency does a wave become "sound" rather
> than "variation in sound"?
20 Hz?
> The *other* question, of course, is "how many frequency bands do I need?"
Experiment!
Date: 30 Apr 2010 09:26:47
Message: <4bdada97$1@news.povray.org>
> (I have no idea how you measure signal energy...)
You mean how to assign a number to "loudness" given the waveform?  I'd guess
that taking the RMS over a few cycles followed by some log scaling would be
a good start, but the ear is complex...
Date: 30 Apr 2010 09:37:02
Message: <4bdadcfe@news.povray.org>
>> words, by windowing the signal you're blurring its spectrum.
Preferable to phantom frequencies, sure...
> 20 Hz?
That's approximately the lowest frequency that the human ear can
mechanically detect. There's no particular reason to expect this to be
in any way related to the rate of change in frequency spectrum that the
human mind can percieve. (One is related to the physics of the ear, the
other is related to the internal operation of the brain...)
> Experiment!
Science: It works, bitches! :-D
Date: 30 Apr 2010 10:33:49
Message: <4bdaea4d$1@news.povray.org>
>> 20 Hz?
> mechanically detect. There's no particular reason to expect this to be in
> any way related to the rate of change in frequency spectrum that the human
> mind can percieve.
Modulate a 1 kHz tone with a N Hz square wave.  At what value of N do you
cease to be able to recognise the 1 kHz tone turning on and off?  I suspect
it's somewhere around 20 Hz, you could easily figure it out with a sound
editor program like Audacity.
Date: 30 Apr 2010 10:39:44
Message: <4bdaebb0$1@news.povray.org>
> you cease to be able to recognise the 1 kHz tone turning on and off?
Yes, this is the experiment to perform.
> I suspect it's somewhere around 20 Hz, you could easily figure it out with
> a sound editor program like Audacity.
I'd probably use my synthesizer actually, but anyway... ;-)
Date: 30 Apr 2010 11:50:23
Message: <4bdafc3f$1@news.povray.org>
Around 10Hz to 12Hz.
   Linux: Now bringing the quality and usability of
   open source desktop apps to your personal electronics.
Date: 30 Apr 2010 11:52:25
Message: <4bdafcb9@news.povray.org>
Closer to 10Hz.  Between 10Hz and 20Hz, you detect sufficiently loud sound
with different organs, such as your eyeballs vibrating or your sinuses
resonating. If you play a tone in that range, you get the "spooky" feeling,
or unaccountably sad, or mystical feelings, or things like that, depending
on the frequency.
Date: 3 May 2010 08:29:34
Message: <4bdec1ae$1@news.povray.org>
> sound with different organs, such as your eyeballs vibrating or your
> sinuses resonating. If you play a tone in that range, you get the
> "spooky" feeling, or unaccountably sad, or mystical feelings, or things
> like that, depending on the frequency.
I know with my headphones (Hybrid canalphones, actually) I can detect
down to around 10hz, anything lower is inaudible. I designed my
headphone amp with a ~15hz corner frequency high pass in it's input
stage (AC coupling, to get rid of any DC bias before feeding the signal
to the op-amp)
It sounds beautiful, very rich tones.
There is something about a big pipe organ with extremely low registers.
Occasionally at church they'll pull what I think is the 16' stop, and it
sounds incredible, there's something about that deep rumble the big
pipes put out...
~Mike
Date: 3 May 2010 11:54:31
Message: <4bdef1b7$1@news.povray.org>
That "something about" is exactly what I'm talking about. :-) That's the
subsonics kicking in.
Date: 3 May 2010 14:14:04
Message: <4bdf126c$1@news.povray.org>
> pipes put out...
On a normal church organ, 16' is the lowest available stop. This is due
mainly to size considerations. (Not to mention that building large pipes
requires a lot of metal, and therefore costs money.)
A cathedral organ, however, would usually have at least one 32' stop.
Exactly two pipe organs on the face of the Earth have a 64' stop. But
then, really, that's not a note, it's a small earthquake! o_O
(I should maybe point out that a 16' stop doesn't necessarily contain
any pipes that are 16' long. There are ways to make the pipes shorter
[while muffling the tone they generate]. Or the stop might simply not
contain all the notes of the scale; only the *lowest* pipe would need to
be 16' long; the next just one octave up only needs to be _half_ that size!)
I leave it as an exercise for the over-interested reader to figure out
what the fundamental frequency of a 32' pipe is. (Remember that the
fundamental wavelength is 2x the pipe length - or 4x if it's a closed pipe!)
http://blog.orphi.me.uk/
