![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Does anybody know the actual name of that LCD technology that produces a
monochrone display of light blue and dark purple? (And, incidentally, is
usually scored with horizontal or vertical lines that shouldn't be there...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> there...)
You mean like this?
http://www.crystalfontz.com/phpthumb/phpThumb.php?id=806
It's a transmissive passive matrix TN display. Same as you get in
calculators or watches, except it controls the amount of light that can come
through from the backlight, rather than how much is reflected. The blue is
because when the pixel is "off" it's only tuned to block out green light
(the brightest wavelength), so some blue (and a bit of red) manage to get
through.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> a monochrone display of light blue and dark purple? (And,
>> incidentally, is usually scored with horizontal or vertical lines that
> You mean like this?
The ones I've seen are a lot more purple than that, but yeah...
OK.
> Same as you get in
> come through from the backlight, rather than how much is reflected.
Yeah, those usually just have a silvered back. And, depending on what it
is, they don't always turn completely transparent when "off". (E.g., the
phone on my desk has an 8x8 grid of pixels, and you can see where the
pixels are even when they're supposed to be off. They do turn very, very
black when they're on though.)
> The
> blue is because when the pixel is "off" it's only tuned to block out
> green light (the brightest wavelength), so some blue (and a bit of red)
> manage to get through.
Hmm, I see.
We have several items of equipment here that have screens like this. I
first saw them in laptops, about 20 years ago. But now you see them as
touch-screen controls for photocopiers and the like.
And then, at home I have a keyboard that has a backlit LCD. But it's
yellowy-green, with black pixels...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
TN = Twisted Nemetic?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Only if you look at them from exactly the right angle :-)
Yes, they are very cheap compared to higher performance displays. Not just
the actual LCD, but also the drive electronics required is much simpler.
The "colour" of a monochrome display is just the combination of the LED
colour used in the backlight, and what wavelength the LCD is tuned to block.
I guess there are common combinations, but pretty much anything should be
possible.
Yes
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> it is, they don't always turn completely transparent when "off".
>> (E.g., the phone on my desk has an 8x8 grid of pixels, and you can see
>> where the pixels are even when they're supposed to be off. They do
>> turn very, very black when they're on though.)
Hmm, yes... Apparently if I stand in front of my desk phone, all the off
pixels become completely transparent.
Why is LCD angle-dependent in the first place?
> just the actual LCD, but also the drive electronics required is much
> simpler.
I'm guessing making it touch-sensitive makes it more expensive though?
(How the hell do they do that anyway? And how come the display doesn't
"ripple" when you do this?)
> block. I guess there are common combinations, but pretty much anything
> should be possible.
So the keyboard probably has a green backlight and green liquid crystals?
I was under the impression that high-performance displays (e.g., my
computer monitor) use florescent lighting rather than LEDs. (Although,
obviously, I don't design LCDs for a living...)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Look at a picture of how TN molecules are orientated inside the LCD, eg
here:
http://img.tfd.com/cde/LCD.GIF
When light is not going perpendicularly through, the LC obviously has a
different effect on the light.
TN happens to be very bad for this, there are of course better ideas, one is
called multi-domain vertical alignment:
http://www.pctechguide.com/images/43mva.gif
Simply put, it splits the pixel into several sub-parts, each aligned a
different way, so when you see the pixel overall it looks the same from all
viewing angles.
Of course.
Stick a touch panel on the front.
> And how come the display doesn't "ripple" when you do this?)
Because there's an air gap between the TP and LCD, unless you press really
hard then the TP might hit the front of the LCD.
CCFLs are being replaced by LEDs, mainly because CCFLs contain mercury. It
started off with small size displays, but recently even TVs are using LEDs
now. LEDs have pros and cons compared to CCFL, but the only real cons are
that it's harder to spread out the light evenly from a point source, and
they get dimmer at high temperatures (watch out for positive feedback!).
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Am 31.03.2010 12:48, schrieb Invisible:
LCDs (at least the older ones) use an effect of various materials (which
can be controlled by an electrical current in the case of LCs) to
"twist" the polarization direction of light passing through. The LCs are
sandwiched between two polarizing filters, the first of which is used to
polarize the light source, and the second to filter out part of the
light depending how much "twist" it has experienced. (In passively-lit
LCDs, a single polarizing filter may serve both roles.)
Obviously the twisting effect does not only depend on voltage applied to
the LC, but also on the distance the light travels through it - which in
turn depends on the viewing angle.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
