> It's a load of codswallop. If I titrate caffeine to the point there's
> none left in solution in the water, the water is *no different* than
> taking water that's never been near caffeine. It is chemically the
> *same*.
I think these people believe there is something "beyond" basic chemistry, ie
even when no active substance can be detected, it has somehow made its mark
on the carrier substance (water, sugar etc). And as is completely normal
with human nature, they subconsciously interpret the results of a few very
unscientific tests (eg my friends mum was cured by it) and conclude it
works.
On 3/25/2010 3:52 PM, Darren New wrote:
> TC wrote:
>> Apart from this all: the strangest thing is the (scientifically
>> proven) effect of a placebo - it is strange that it actually works.
> Even stranger: The placebo effect is getting stronger. There are
> medicines on the market in the USA that if you re-tested them, you'd
> find they're ineffective. The placbo effect has gotten stronger to the
> point where it's
> now stronger than the actual medicine that passed scrutiny a couple
> decades ago.
Sometimes this is called "over use". People are exposed, directly or
indirectly, to things so much that their bodies "get used to" having it
in the blood stream, so when you do need it, its less effective. This is
well known, with almost *everything*, especially if it effects nerves,
brain function, etc.
void main () {
If Schrödingers_cat is alive or version > 98 {
if version = "Vista" {
call slow_by_half();
call DRM_everything();
call functional_code();
else
call crash_windows();
<A HREF='http://www.daz3d.com/index.php?refid=16130551'>Get 3D Models,
3D Content, and 3D Software at DAZ3D!</A>
> works.
I have hard time understanding the psychological phenomenon that many
people are eager to believe in some things based solely on what other
people *claim*, without any actual convincing evidence, or with just some
flimsy circumstancial evidence of eyewitness testimony, and *keep believing*
in it even after an enormously more comprehensive and accurate testing shows
that the thing is bogus.
Someone might believe that something works because someone claims that it
worked on 10 people. Even if a scientifically accurate study is then performed
repeatedly on 1000 people, and this test shows that it doesn't actually work,
these people will *still* believe it works.
I really can't understand why. It's like accurate scientifical testing which
is more extensive and more thorough is less convincing than a much smaller
sample of inaccurate circumstancial evidence.
Why do so many people think like this? What is the psychological phenomenon
behind this kind of thinking?
> Suppose you have 30 containers with 0.9 liters of water in each (totaling
> 27 liters). Put 0.1 liters into the first container, then take 0.1 liters
> from this solution, put it in the second container, then take 0.1 liters
> of
> this solution, put it in the third container, and so on.
Where do you get 27 liters of water from that doesn't have a single molecule
in it of the thing you are trying to dilute?
Better hope nobody has already tried it and thrown away the 10% solution
into the sea :-)
> phenomenon
In most cases I suspect it is because the person just can't been bothered to
research it, they have more important things in their life to worry about
than whether some cool-sounding fad medicine is scientifically proven to
work or not. Hey they might not even realise there is such a thing as a
scientific test.
I suspect if you confronted most people who bought this stuff and explained
the science and the study results, they would believe you.
I doubt it. If you could reason with people believing in such things, they
wouldn't believe in them in the first place.
>> explained
The thing is they just don't care about the science, they buy it because it
seems cool, and don't even give a second thought to how it has been tested
or what "30C" actually means. Most people are reasonable once you explain
things to them (of course there are exceptions, the "die hard" believers).
> > phenomenon
> scientific test.
I specifically talked about people who keep believing in it even *after*
they have been told about the better tests. In other words, they refuse to
believe in the accuracy of the scientifical tests.
> > of
> into the sea :-)
I'm sure homeopaths will argue something like the solution specifically
needing to be performed by "succussion" or else there will be no effect.
(Don't bother asking for the physical or chemical explanation for this.)
[snip]
Best Regards,
