POV-Ray : Newsgroups : povray.off-topic : HDMI cable confusion/paranoia Server Time
13 Sep 2025 23:23:44 EDT (-0400)
  HDMI cable confusion/paranoia (Message 9 to 18 of 128)
<<< Previous 8 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: HDMI cable confusion/paranoia
Date: 5 Mar 2010 17:15:47
Message: <4b918293@news.povray.org>
Jeremy "UncleHoot" Praay wrote:
> Yes, but if the bits start out as 101 and end-up as 101 on both the high
> quality cable and the low quality cable (every time),
Right. I'm just saying that the equipment at each end determines how good
quality cable you need. You can't test a cable on lab equipment and say "we
got no errors, so you won't either."   It's like saying "we put X brand
gasoline in our car and got 40MPG, so you will to."
I think we understand each other. :-)
> It doesn't just paint the same frame?
That's what they *say*.  Whether they're just full of it, I couldn't say.
The demos make it look better, but then they would.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 5 Mar 2010 17:29:32
Message: <4b9185cc@news.povray.org>
> quality cable and the low quality cable (every time), then even though the
> high quality cable is transmitting the analog signal better, it really makes
> no difference, as they both interpret the digital portion the same way.  I
> think we're both on the same page here.
  Maybe if there's nearby interference (not completely unthinkable given
how much electronics there are in today's homes) the likelihood for the
bits to get garbled during transport is lessened with the higher-quality
cable.
Date: 5 Mar 2010 17:34:00
Message: <4b9186d8$1@news.povray.org>
> There it is.  Let me know if I'm wrong.  I can't believe that I could be
> right about all of this stuff, as there seem to be so many people out there
> who seem to think I'm wrong.
You seem to have encountered the High-Def equivalent of extreme
audiophiles. You can find the same people buying CD/DVD/Blue-ray
de-magnetizers, because it makes the sound/image quality better. Or
wooden knobs for their amps, for the tonal quality. Or acoustic rocks,
after-market power cords infused with nitrogen, R-Type stickers that
make their cars go faster . . . wait, slipped off topic for a bit there.
All said, there can be a difference in cable quality. I would not try
pushing 10Gbps ethernet over cat5 cable for any distance. HDMI, if it
were supporting 1080p, 60 Hz frame rate, 12 bit per color with no
compression, would have to support a data rate close to 4.5 Gbps. (G is
SI, not 1024M here). I don't think I would try sending that over
unfolded cloths hangers wrapped together with gaffers tape. But, for the
normally short distances between a TV and other components, just about
any braided copper wire will do, if properly shielded from cross-talk
and such which, I would think, the HDMI standard should cover. If you
get problems between two components then you can look at just those
cables involved, and figure out if they are really bad cables or if the
components need a better cable to communicate over.
For 120Hz, and now 240Hz, some (most?) of those TVs blend frames
together, to blur the change between each frame. Watching the
side-by-side demos in stores hasn't impressed me too much, maybe because
the compression artifacts are so pronounced when you stand that close to
these big TVs. Maybe when 3D becomes more used, I will check them out again.
Date: 5 Mar 2010 18:31:21
Message: <4b919449$1@news.povray.org>
> these big TVs.
You know, I used to think that.  I used to work on compression algorithms,
so I got really good at seeing the kind of artifacts that jpeg and mpeg
produce. Every time I went in the store and looked at the HDTV, I saw all
the compression artifacts in the background and thought 'wow, that sucks.'
Then my TV died, so we bought a big-screen LCD TV. The difference between
the SD channels on cable and the HD channels on cable is stunning. Stadium
crowds that used to look like a Monet painting now all have faces and stuff
even in the background. You can see grass blades. Etc.
Yes, the compression artifacts are still there, but they're *still* smaller
than the analog blurring and color drift artifacts on a TV set that size. :-)
Date: 5 Mar 2010 22:14:24
Message: <4b91c890@news.povray.org>
>> these big TVs.
> algorithms, so I got really good at seeing the kind of artifacts that
> jpeg and mpeg produce. Every time I went in the store and looked at the
> HDTV, I saw all the compression artifacts in the background and thought
> 'wow, that sucks.'
I could ignore them on my old small TV, when cable started
rebroadcasting very compressed signals. Now I have a large 1080p tv, but
I get programing over the air, so the local news and such comes in very
clear while other programing varies.
> between the SD channels on cable and the HD channels on cable is
> stunning. Stadium crowds that used to look like a Monet painting now all
> have faces and stuff even in the background. You can see grass blades. Etc.
> smaller than the analog blurring and color drift artifacts on a TV set
> that size. :-)
Oh, yeah. It's the angle the they have you viewing the TVs at in stores
that make the difference. I am not likely to watch the tele from 1 foot
away, nor from 6 feet under the box staring up a wall at it. It benefits
the high end TVs that do some filtering, which I suspect all have a
higher margin for the stores.
Date: 5 Mar 2010 22:56:38
Message: <4b91d276@news.povray.org>
"Darren New" <dne### [at] sanrrcom> wrote in message
news:4b919449$1@news.povray.org...
>> these big TVs.
I'm not sure if it's just the Walmart in my neighborhood, or if all of them
are like this, but they have lots and lots of TV's all running the same
signal, and their TV's look like crap.  For one thing, most (if not all) are
using shared analog connections of some kind.  Plus, the demo they have
running has TONS of compression artifacts in it.  Any time the on-screen
text should look clear and crisp, it looks like an awful, lossy JPEG.  It
certainly doesn't impress.
Ironically, that's where I bought my TV.  :-)
Date: 5 Mar 2010 22:59:31
Message: <4b91d323$1@news.povray.org>
"Sabrina Kilian" <ski### [at] vtedu> wrote in message
news:4b91c890@news.povray.org...
>>> these big TVs.
>> 'wow, that sucks.'
Digital compression on my old 27" TV bothered me, but I guess I could handle
it.   Once we got the 46" screen, it was painful to watch.  Generally
speaking, I only watch the HD channels now, and by and large, they look
pretty good.  (DISH Network)
Date: 6 Mar 2010 05:19:09
Message: <4b922c1d$1@news.povray.org>
> It's the same reason you can only get ADSL service at certain distances
> from the telco CO. It's an analog signal. It's only digital once it gets
> inside your computer.
ADSL is a digital signal modulated into an analogue one. (And carried
over cables supplied by the lowest bidder, specified to carry voice data
only, at the minimum quality level necessary for it to be vaguely
comprehendable.) HDMI is a raw, unmodulated digital signal.
http://blog.orphi.me.uk/
Date: 6 Mar 2010 05:24:51
Message: <4b922d73@news.povray.org>
>> these big TVs.
> 'wow, that sucks.'
> that size. :-)
Well, let me see now.
On my mum's old CRT TV, there was really no noticable difference between
analogue and digital. Both looked equally fuzzy.
(I once plugged my laptop into the TV, and even if I set the resolution
absurdly low and made all the fonts huge, they were unreadable.)
Now my mum has this shiny new LCD TV. And suddenly digital looks
*awful*! As soon as anything moves faster than 2 MPH, it's blocky and
unrecognisible. Although... it seems to vary by channel somewhat.
(And that of course is the other undesirable thing about digital TV.
There used to be, like, 5 channels, 4 of them containing high quality
programming. Now there's 500 channels and they're *all* showing utter
crap that nobody would ever want to watch...)
I've only seen HD stuff in shops, but from what I can tell, there's no
visible difference between HD and SD. If I ever get time to set up my
mum's new BluRay player, maybe I can test for myself. But seriously,
everybody's going on like it fundamentally transforms your viewing
experience. But it's only 4x the resolution. Not 40x or 400x, just 4x.
And, from what I've seen, this equals to a slight increase in constrast,
and not much else.
Date: 6 Mar 2010 11:57:14
Message: <4b92896a@news.povray.org>
There is no such thing. Digital is your imagination.
