POV-Ray : Newsgroups : povray.off-topic : What's in an IDE? Server Time
15 May 2026 06:18:00 EDT (-0400)
  What's in an IDE? (Message 41 to 50 of 66)
Subject: Re: What's in an IDE?
Date: 1 Mar 2010 19:59:05
Message: <4b8c62d8@news.povray.org>
Darren New <dne### [at] sanrrcom> wrote:
> Warp wrote:
> >   (Besides, what is *your* definition of "IDE", if CMake isn't one?)
> CMake is just a new version of make, or a makefile generator, I forget
> which. It's not integrated, and it's not an environment, any more than make
> itself is.
  You said what CMake is/isn't, not what an "IDE" is...
Date: 1 Mar 2010 20:47:02
Message: <4b8c6e16$1@news.povray.org>
>> itself is.
You weren't talking to me. :-)  I wasn't sure you knew what cmake was, so I
was clarifying that it wasn't an IDE. :-)
I don't consider cmake a development environment. It's one tool that's part
of some development environments.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 2 Mar 2010 00:00:01
Message: <web.4b8c9a47c7641e1cfbacf1b0@news.povray.org>
> > itself is.
bash is a pretty good IDE to me.  It integrates/glues all other dev tools
needed. :)
Date: 2 Mar 2010 04:35:42
Message: <4b8cdbee$1@news.povray.org>
>> Actually it saves the GUI description as an XML file, which your
>> program then loads and parses at runtime.
> Yes. As does Visual Studio. And what do you think the boilerplate does
> there beside "load and parse at runtime" that XML? :-)
Surely it's just 1 line of code? (Unless you want to do something
special to determine where to find the XML file...)
>> Now, see, to me these kinds of tasks all belong to the set of things
>> which are "impossible" in the first place, so I guess I don't tend to
>> think about it. You can't write web browser plugins unless you're a C
>> programmer, unfortunately.
> Of course you can.
Oh, yeah, I forgot. You could be a C++ programmer. ;-)
Date: 2 Mar 2010 04:54:04
Message: <4b8ce03c$1@news.povray.org>
>>> Edit->Advanced->Reformat entire document
>> Wouldn't that just apply the incorrect formatting to the whole document?
> It applies the formatting rules you asked it to apply.
Or rather, it applies the default formatting rules, whatever they happen
to be for the IDE in question.
> Which would be "the" incorrect formatting?
For example, both JBuilder and VS put the opening bracket of a function
on the same line as the function declaration, rather than on the next
line where it belongs. They also indent everything by 8 spaces rather
than the usual 2. And so on. (I'm not even sure *what* formatting rule
they apply to if-statements...)
> So you're going to maintain a batch file that first compiles the code
> needed to parse the video game animations, then the code that writes
> them out, then runs the animations through that, then put them in the
> right place?
> Why in the world would you do that when it has already been written for
> you?
Yeah, if your application was actually that complex, you'd probably use
make or similar.
> It is if you're doing something small enough. But then, you can live
> without batch files too if you never type the same command more than twice.
> The advantages of an IDE over a DE is that it's integrated.
OK, fair enough.
Large numbers of people apparently think that it's just infeasible to
write any code of any kind unless you have an IDE specifically targetted
at the programming language you're using. But to me, it looks like an
IDE is only really beneficial if you're actually doing something
complex. (And, further more, it looks to me that the tipping point is
when you start writing something more complex than any program I've ever
attempted in my entire life - so an IDE is probably of little to no use
to me...)
>>>>> 6) "Template" projects for a Windows app
>>>> What does that do?
>>> Try it! Or at least google it. :-)
>> A human being is far more likely to give a useful overview.
> You know what a template is in documents, right? Corporate report
> template? Vacation time reporting template? Request for purchase of
> networking equipment template?
> Same thing, for code.
Sure. But "Windows app" template? What could possibly be in it?
It's like, you have a template for a purchase request. Or a template for
a procedure document. But you know what you *don't* have a template for?
A document. Because, let's face it, what would a template for "a
document" actually contain?
Similarly, "a Windows application" could be absolutely anything. How do
you template that?
> I want to write a game. I want to write a windows service. I want to
> write a new type for a SQL database engine.  I want to build a web
> application.
Maybe it's because I've never written any of these things, but I can't
imagine what (for example) two games would have in common. (And hence,
what you'd put into a template.)
>> I'll just spend an hour not being able to figure out what it's
>> supposed to be for.
> That's because you never practice the skill, so you never improve at it.
This statement is not falsifiable.
Date: 2 Mar 2010 05:18:15
Message: <4b8ce5e7$1@news.povray.org>
Actually if you install XNA with VC# then you can go File -> New -> Windows
Game and then press F5 and you will have running a game skeleton program
which is very easy to add stuff too.  In fact you can also choose
"Platformer Starter Kit" as a new project and have a playable platform game
as a template!  Then go Build -> Publish... and it creates a standalone
installer to distribute, it doesn't get any easier than this to code games
on Windows/XBOX!
Date: 2 Mar 2010 05:36:47
Message: <4b8cea3f$1@news.povray.org>
> For example, both JBuilder and VS put the opening bracket of a function on
> the same line as the function declaration, rather than on the next line
> where it belongs.
In VS Express (the free one):
Options -> Text Editor -> (Language) -> Formatting -> New Lines -> "Place
open brace on new line for xxxx" where (xxx) is a number of different
options.  Feel free to tick all these (actually they seem to all be ticked
by default, it's the style I prefer too).
>  They also indent everything by 8 spaces rather than the usual 2. And so
> on. (I'm not even sure *what* formatting rule they apply to
> if-statements...)
Options -> Text Editor -> (Language) -> Tabs -> "Tab Size" or "Indent size"
Why don't you just spend 5 minutes setting the options to your preference?
Err, the headers and namespaces for graphics, audio and input libraries,
build processors set up for graphics files, meshes, sound files etc, a game
loop with empty functions for you to add your game logic and graphics code,
pre-existing code for initialising the graphics API and painting the updates
into the window each frame, a framework for adding "components" to your game
that can be easily enabled/disabled and automatically called/rendered, etc.
Just download VC# and XNA and ask it to make a new "Game" project - there's
a lot of useful common stuff in there that makes your job way easier.
Date: 2 Mar 2010 05:55:42
Message: <4b8ceeae@news.povray.org>
>> function on the same line as the function declaration, rather than on
>> the next line where it belongs.
> "Place open brace on new line for xxxx" where (xxx) is a number of
> different options.  Feel free to tick all these (actually they seem to
> all be ticked by default, it's the style I prefer too).
When I looked at this stuff, there were 3 different options you could
select. I tried all three, and none of them did what I want. (Curiosly,
there didn't seem to be an option for "disable all autoformatting and
just let me do it by hand".)
As I say, when I tried it there wasn't much you could adjust.
> game loop with empty functions for you to add your game logic and
> graphics code, pre-existing code for initialising the graphics API and
> painting the updates into the window each frame, a framework for adding
> "components" to your game that can be easily enabled/disabled and
Now, to me, that sounds like it's just going to build a bunch of
boilerplate code for how the designers invesage a game would be
structured, and if you want your game structured a different way you're
going to have to waste time deleting the template stuff and rewritting
it the way you want it.
Similarly, I obviously haven't written many games (currently at zero and
counting), but I would have hoped that "initialising the system" would
already be a fairly painless task. (Isn't this what we have libraries for?)
I'm not quite sure what "build processors set up for graphics files,
mashes, sound files etc" is supposed to mean.
> there's a lot of useful common stuff in there that makes your job way
> easier.
Well, yeah, there is always that. (Although not understanding C#,
presumably none of it will make sense anyway...)
Date: 2 Mar 2010 06:15:44
Message: <4b8cf360$1@news.povray.org>
> going to have to waste time deleting the template stuff and rewritting it
Sorry but I never heard of anyone making a game that didn't have a "game
loop" and methods for rendering and methods for the game logic.  Obviously
you are free to delete those and make your own, or just start from scratch.
They are just providing the most common structure, as most people will want
that anyway.
> for?)
Sure, it's just the odd line here and there for creating a
GraphicsDeviceManager, a content loader object, a sprite/texture manager
object, method calls to clear and redraw the frame, that sort of thing.  No
more than a handful of lines of code, but it's easier to have it done for
you in a nice structure than to have to start from scratch each time.
So that you can go "Add to project..." and include a JPEG, PNG, WAV, MP3,
BMP, X (3D mesh) or whatever and at the build stage it will convert your
file into a format suitable/optimised for the game (eg mipmaps for the
textures).  It saves you have to export all your data files in some specific
format just to get them to work with your API, the build processor just does
it seemlessly (obviously it detects if there has been an update or not).
FYI here's the raw template code it gives you when you create a new game (it
looks better in the IDE than in plain text):  Now maybe it's just me, but I
quite like it doing that automatically for me rather than having to
remember/type that all each time I want to mess about quickly with a little
graphics demo or whatever.
using System;
using System.Collections.Generic;
using System.Linq;
using Microsoft.Xna.Framework;
using Microsoft.Xna.Framework.Audio;
using Microsoft.Xna.Framework.Content;
using Microsoft.Xna.Framework.GamerServices;
using Microsoft.Xna.Framework.Graphics;
using Microsoft.Xna.Framework.Input;
using Microsoft.Xna.Framework.Media;
using Microsoft.Xna.Framework.Net;
using Microsoft.Xna.Framework.Storage;
namespace WindowsGame3
    /// <summary>
    /// This is the main type for your game
    /// </summary>
    public class Game1 : Microsoft.Xna.Framework.Game
        GraphicsDeviceManager graphics;
        SpriteBatch spriteBatch;
        public Game1()
            graphics = new GraphicsDeviceManager(this);
            Content.RootDirectory = "Content";
        /// <summary>
        /// Allows the game to perform any initialization it needs to before
starting to run.
        /// This is where it can query for any required services and load
any non-graphic
        /// related content.  Calling base.Initialize will enumerate through
any components
        /// and initialize them as well.
        /// </summary>
        protected override void Initialize()
            // TODO: Add your initialization logic here
            base.Initialize();
        /// <summary>
        /// LoadContent will be called once per game and is the place to
load
        /// all of your content.
        /// </summary>
        protected override void LoadContent()
            // Create a new SpriteBatch, which can be used to draw textures.
            spriteBatch = new SpriteBatch(GraphicsDevice);
            // TODO: use this.Content to load your game content here
        /// <summary>
        /// UnloadContent will be called once per game and is the place to
unload
        /// all content.
        /// </summary>
        protected override void UnloadContent()
            // TODO: Unload any non ContentManager content here
        /// <summary>
        /// Allows the game to run logic such as updating the world,
        /// checking for collisions, gathering input, and playing audio.
        /// </summary>
        /// <param name="gameTime">Provides a snapshot of timing
values.</param>
        protected override void Update(GameTime gameTime)
            // Allows the game to exit
            if (GamePad.GetState(PlayerIndex.One).Buttons.Back ==
ButtonState.Pressed)
                this.Exit();
            // TODO: Add your update logic here
            base.Update(gameTime);
        /// <summary>
        /// This is called when the game should draw itself.
        /// </summary>
values.</param>
        protected override void Draw(GameTime gameTime)
            GraphicsDevice.Clear(Color.CornflowerBlue);
            // TODO: Add your drawing code here
            base.Draw(gameTime);
Date: 2 Mar 2010 06:28:45
Message: <4b8cf66d@news.povray.org>
> MP3, BMP, X (3D mesh) or whatever and at the build stage it will convert
> your file into a format suitable/optimised for the game (eg mipmaps for
> the textures).
Oh, OK. I didn't realise there was a conversion step there.
> (it looks better in the IDE than in plain text):
That's actually not too bad...
