POV-Ray : Newsgroups : povray.off-topic : Coding in ___ is like ___ Server Time
16 Jul 2026 14:10:11 EDT (-0400)
  Coding in ___ is like ___ (Message 7 to 16 of 66)
<<< Previous 6 Messages Goto Latest 10 Messages Next 10 Messages >>>
Subject: Re: Coding in ___ is like ___
Date: 25 Feb 2010 17:58:58
Message: <4b8700b2$1@news.povray.org>
Kevin Wampler wrote:
> evidence for the need for better error messages
I was actually pretty impressed by the C# IDE from MS. I wrote
void do_it(int a, int b, int c = 0) { ... }
and the error message wasn't ") or , expected" or "syntax error", but rather
a pointer to the = and the message "C# does not support default arguments."
I was also impressed when I started up my program under test in full screen
and the IDE bumped its debugger windows over to the second screen and put
them back when the program exited. Cool attention to detail.  Not that this
has anything to do with the current thread.
   The question in today's corporate environment is not
   so much "what color is your parachute?" as it is
   "what color is your nose?"
Date: 25 Feb 2010 18:03:33
Message: <4b8701c5$1@news.povray.org>
How have you liked C# so far?  I last tried it when it was a pretty new
language and it came across as a slightly altered version of Java, but I
imagine it's changed a fair bit since then.
Date: 25 Feb 2010 18:21:16
Message: <4b8705ec@news.povray.org>
  But is that kind of message the rule or the exception?
  And it's not like gcc didn't have similar-sounding error messages:
error: ISO C++ forbids declaration of 'x' with no type
Date: 25 Feb 2010 20:20:47
Message: <4b8721ef$1@news.povray.org>
On Thu, 25 Feb 2010 13:39:25 -0800, Darren New wrote:
> One of the better ones I've seen.
> http://web.mit.edu/~axch/www/writing_rant.html
He missed "Pseudocode", which I'd write as:
Coding in pseudocode is like a metaphor.
Jim
Date: 25 Feb 2010 22:15:40
Message: <4b873cdc$1@news.povray.org>
I like it! (although given your sentence construction shouldn't that be
"simile", or alternatively "Coding in pseudocode is a metaphor"?)
Date: 25 Feb 2010 23:03:26
Message: <4b87480e$1@news.povray.org>
I do. I've been using it on and off from early on.
Well, at first glance it looks like that, but deeper in it has a whole lot
of good stuff Java doesn't. Until you start going into complex stuff, it's
just "Java, fixed."  Once you start trying to do something difficult (like
access to native languages, deployment, web scripts, generating code at
run-time, etc) it's way better.
Indeed it has. C# 1.0 was sort of "Java, improved."  C# 3.x by now has all
kinds of goodies in it that Java lacks.
Date: 25 Feb 2010 23:06:45
Message: <4b8748d5$1@news.povray.org>
The error messages are all good, but I usually don't get an error at compile
time because the IDE puts a red squiggly under compile-time errors and a
green or blue squiggly for warnings, as you type. The IDE is really an order
of magnitude better than anything else I've ever used.
That was just surprising, because MS anticipated that someone would do that
and special-cased the parser just to handle a common error message.
I've gotten a few of those and not understood them, actually. I don't
remember what I had, but having something more along the lines of "you
forgot an #include" would be a better error message, I think. :-)
Date: 25 Feb 2010 23:34:45
Message: <4b874f65$1@news.povray.org>
Technically, I guess "simile" would be correct there - I always get the
two mixed up.  :-)
Jim
Date: 26 Feb 2010 02:11:43
Message: <4b87742f$1@news.povray.org>
> two mixed up.  :-)
At least I have something to show for all the effort my teachers spent
hammering the difference into my head!
Date: 26 Feb 2010 02:13:49
Message: <4b8774ad$1@news.povray.org>
>> I last tried it when it was a pretty new language and it came across
> lot of good stuff Java doesn't. Until you start going into complex
> stuff, it's just "Java, fixed."  Once you start trying to do something
> difficult (like access to native languages, deployment, web scripts,
> generating code at run-time, etc) it's way better.
Makes sense.  I think the runtime code generation was what I was
particularly interested in, and I'm pretty sure it didn't have much in
the way of that when I last looked at it.  Now that I have Visual Studio
maybe I'll take a look at it again sometime.
