POV-Ray : Newsgroups : povray.off-topic : I need a book... Server Time
27 Mar 2026 18:36:29 EDT (-0400)
  I need a book... (Message 1 to 10 of 14)
Subject: I need a book...
Date: 20 Feb 2010 15:15:00
Message: <web.4b8041ea99e22b1ce79f0df40@news.povray.org>
....on real world applications of calculus, specifically one that covers Fourier
and Laplace transforms.
I've managed to squeak by in my class, but our text is theory-only, and our
instructor is... not very helpful.
What I'd really like is something that explains the theory briefly (more as a
recap), then shows real world situations where the theory can be applied.
Hopefully something at least mildly entertaining to read, but that might be
asking for a bit much :/
Does anyone have some suggestions?
....Chambers
Subject: Re: I need a book...
Date: 20 Feb 2010 16:01:33
Message: <4b804dad$1@news.povray.org>
The DSP Guide covers the Fourier and Laplace transforms, and how you use
them for digital filter design or signal analysis. It'll be of
absolutely no help with differential or integral calculus though.
http://blog.orphi.me.uk/
Date: 22 Feb 2010 08:47:45
Message: <4b828b01$1@news.povray.org>
> ....Chambers
Just like what I had in school - professor was a brain on feet, but no
practicable applications really shown or taught.
As you probably already know, DSP systems use the transforms a lot and
can actually be quite fun.
We did type a few transforms into MATLAB and get to hear what it did to
a sound file, but little more.
What I really wanted was to be able to do it on a chip and then have it
process sound real-time.  That would have helped me see the application
much more clearly.
Date: 22 Feb 2010 09:16:56
Message: <4b8291d8@news.povray.org>
Our brain on feet was called Zimin Wu. His English was... minimal. Which
is kind of an impediment to teaching, actually. (Fortunately, this was a
lecture in HCI, not mathematics.)
> much more clearly.
Go here:
http://www.falstad.com/mathphysics.html
Scroll down to "signal processing".
They have two applets. One lets you draw an arbitrary waveform and see
its Fourier series, draw an arbitrary Fourier series and let you see its
waveform, and listen to the result in either case.
They also have a little DSP applet which will let you play [literally!]
with any kind of FIR or IIR filter known to mankind - not just the usual
type-I Chebyshev filter, but also type-II, for example. See and hear in
realtime, tweak the parameters, and so forth.
That single page also has links to a ridiculous number of other
addictive applets, like wavetank simulators, circuit simulators, and God
only knows what else. You might not leave for several hours.
Date: 22 Feb 2010 10:28:33
Message: <4b82a2a1$1@news.povray.org>
On 2/22/2010 8:16 AM, Invisible wrote:
> Go here:
Something that should be on any geek's bookmarks list!
Yep! These applets are quite fun indeed! I've burned many hours playing
with them.
I've actually begun poking around in the source code of the circuit
sim.... Generally well-written stuff, very organized and easy to
understand. Not a whole lot of comments though.
I've had a couple of e-mail exchanges with the author. All around nice guy!
~Mike
Date: 22 Feb 2010 10:40:04
Message: <4b82a554@news.povray.org>
> much more clearly.
If you have a fast enough computer and use a fast enough language you should
be able to do some pretty funky stuff on your home PC with the line/mic
input and the speaker output of your sound card.  I would recommend using
C++ and the ASIO driver/protocol - it's really fast (very low latency) and
easy to code for.
As an aside, I looked into this recently because my transmitter for a radio
controlled helicopter outputs a PWM signal that can be connected to the PC's
audio input.  I tried to process this data using the standard Windows API
calls for recording audio and then DirectSound, but they were *way* too slow
(when trying to control a helicopter, even a 200 ms delay on the controls
makes it very hard to control, I was seeing more like 500 ms).  I found the
ASIO drivers and it worked perfectly with seemingly instant response time,
now I can use the RC simulator with my own controller!
Date: 22 Feb 2010 10:49:36
Message: <4b82a790$1@news.povray.org>
>> it process sound real-time.  That would have helped me see the
>> application much more clearly.
> should be able to do some pretty funky stuff on your home PC with the
> line/mic input and the speaker output of your sound card.  I would
> recommend using C++ and the ASIO driver/protocol - it's really fast
> (very low latency) and easy to code for.
Yeah, ASIO is especially designed for low latency. The reason I spent
produced sane latency. (Try playing keyboard when there's a 500ms delay
between pressing a key and hearing something!)
Of course, I use Reaktor for my DSP programming, but that's just a *tad*
expensive...
Date: 22 Feb 2010 13:18:55
Message: <4b82ca8f@news.povray.org>
Perhaps I didn't make this very clear...
A modern PC is already easily fast enough to do realtime DSP even in
quite low-powered languages. Falstad is doing it in mere Java, for
example. You don't need to do anything special if you're just doing a
simple digital filter implementation, for example.
Now, if you want something that you could use for serious studio work,
or you want to do really complex processing, you're going to need
specialist tools. But if you just want to play around with basic DSP
algorithms, you really don't need chips. Just a programming language
with access to sound hardware. It's really not computationally
challenging any more.
Date: 23 Feb 2010 05:07:55
Message: <4b83a8fb$1@news.povray.org>
> on a new sound card was because it provided ASIO drivers and produced sane
> latency.
I just have on-board sound but downloaded this:
http://www.asio4all.com/
Works a treat.
Date: 23 Feb 2010 05:19:38
Message: <4b83abba$1@news.povray.org>
> Works a treat.
Mmm, nice. (Not quite sure how adding more processing can make it do
*faster*, but anyway...)
Presumably this doesn't improve the sound quality in quite the same way
for music-making either. ;-)
