![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
>> Not obese, no. Also not fit. My arms contain very little muscle, and
>> attempting to lift 100 Kg using only my arms operating in an unusual
>> direction is pretty much beyond my current capabilities.
> You make it sound harder than it is :-)
No, actually putting it in writing makes it sound significantly *easier*
than it is.
> First off you are probably not lifting 100kg when you do pushups,
> because a good part of your weight is supported by your feet. I think
> less than 70% of your weight is more accurate. Even less if you do them
> on your knees (which you should probably try).
Well, just for giggles, I did have a go at a pushup a little earlier
today. I can get my head a few milimeters off the floor, but that's
about it. My neck and shoulders can't take much more than that, never
mind the unability of my arms to supply sufficient power. (And ignoring
the increased blood pressure to my head...)
> And the arms are not in an unusual position when you do that exercise.
> They are very well made to operate in front of your torso :-)
Sure. And I can lift fairly heavy loads in an *upwards* direction. But
pushing forwards is a pretty unusual configuration.
> Read this book for more fun :-D
http://www.lulu.com/product/t%C3%A9l%C3%A9chargement/the-little-book-of-push-ups/6102671
"Fortunately, it is almost impossible to injure yourself while doing
basic pushups."
LMAO! WTF?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You're doing it wrong. You should start at the up position, then go down
as far as you can, then go back up. Trying to start from lying flat on
the ground is quite a bit harder and won't train you to succeed...
What about all this time you spent on all fours as a child? What about
all those doors you've pushed?
If you prefer pushing upward you can try vertical pushups, but they are
not the easiest kind ;-)
Vincent
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Oh. I see.
>>> exercise. They are very well made to operate in front of your torso :-)
Mass rises as the cube of size, but muscle power rises as the square of
size. (This is why ants can lift 1,000 times their own weight, but
elephants can only lumber along.)
Besides, you can move on all fours with your elbows locked. That doesn't
take much muscle power. ;-)
> What about all those doors you've pushed?
A door isn't nearly as heavy as a person.
I did, however, move a piano up a spiral staircase one time... Jesus,
THAT was fun! o_O
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> today.
If you can't do that, then lean against the edge of a table, so you're at a
45-degree slant or so, and do some. Then use a lower table, or the edge of
your matress, or some such. Do one more of that type every day.
When you can get to doing pushups on the floor, do one more every day. It
really only takes like 5 minutes a day to get a basic amount of fitness.
In three months, you'll be doing 100 pushups in a row.
You might not be able to do one more every day if the day has been
particularly tiring, but it doesn't sound like you have particularly tiring
days. Or if that'sa a problem, do them in the morning.
Forget "focus follows mouse." When do
I get "focus follows gaze"?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
scott wrote:
>> ...my God. You can make metal that thin?? o_O
> You've seen aluminium foil haven't you? That's probably 10x thinner.
And one of the benefits of gold is that you can squash it down to literally
one atom thick and it'll still stick together in sheets.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> today. I can get my head a few milimeters off the floor, but that's about
> it. My neck and shoulders can't take much more than that, never mind the
> unability of my arms to supply sufficient power. (And ignoring the
You can start off with your hands on a raised platform to make it easier.
For example, feet on ground, hands on table, should be very easy. Then try
hands on a chair, etc., eventually you will be able to do it with your hands
on the ground. Then start to lift your feet up, until finally you can do a
press-up with your body vertical :-)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Invisible wrote:
>>> Hmm, interesting. I wouldn't have expected that to work.
>> What, that a car has more weight on the front wheels than the back?
> Possibly, once you've got the back wheels up on a ramp. ;-)
> I meant more that I wouldn't have expected to be able to just completely
> disregard 3/4 the weight of the object just because I'm only looking at
> one wheel.
The suspension of the car does play a part here. They are designed to
keep all four wheels on the ground, and as flat as possible, when going
through a corner. If the weight of the car started shifting around every
time you moved the center of mass on the interior or went into a banked
corner just a bit too fast, the car would not be very stable at all.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Invisible" <voi### [at] dev null> wrote in message
news:4b717a62@news.povray.org...
Then don't lift your body; push the earth down.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Some of the ones we had offshore weighed half a ton.
Best Regards,
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
