POV-Ray : Newsgroups : povray.off-topic : New car Server Time
2 Apr 2026 17:54:06 EDT (-0400)
  New car (Message 85 to 94 of 184)
Subject: Re: New car
Date: 4 Feb 2010 13:22:45
Message: <4b6b1075$1@news.povray.org>
Eero Ahonen wrote:
> Orchid XP v8 wrote:
>> (I also don't understand why one of the manouvers they get you to
>> demonstrate is reversing around a corner. This has to be the MOST STUPID
>> THING EVER. You should NEVER, EVER do this in real life! So... WTF?)
> Why not? You can reverse to a parking slot (or out of it) or to a garage
> for example.
Sure. But we're talking about reversing around a corner, out of one road
and into a side road.
> Try doing it with a trailer :-). After that reversing only the car is
> pretty easy...
Heh. I still have trouble just parking in small spaces. Still, my new
car has a superior turning circle and sharper power steering. (Now if
only selecting reverse wasn't so hard and the clutch worked properly...)
http://blog.orphi.me.uk/
Date: 4 Feb 2010 13:24:50
Message: <4b6b10f2@news.povray.org>
Eero Ahonen wrote:
> Go ahead and give Saab 9-3 TTiD or BMW 123d a test-drive. They both have
> *two* turbos, still no whistle nor mentionable lag.
Oh yeah, like they're *really* going to let some college kid test-drive
a £400,000 car. :-P
Still, the only vehicle I've come across that had a turbo was a busted
old Land Rover that was, like, 30 years old or something and rusting
apart... Maybe they've improved since then?
Date: 4 Feb 2010 13:34:09
Message: <4b6b1321@news.povray.org>
>> In the category of "I realise nobody actually gives a damn but I'm going
>> to tell you all anyway": I have a new car.
> Me too!
> http://www.zbxt.net/~aero/saab/sc_front.jpg
> http://www.zbxt.net/~aero/saab/sc_back.jpg
...it's grey.
> I doubt it's not turbocharged.
Really?
The turbo version apparently generates an extra 30 BHP.
>> - The clutch doesn't enguage until you completely remove your foot from
>> the pedal. You can lift the pedal all the way from the floor to almost
>> fully released, and you're still not moving. Only in the last 5mm or so
>> of travel do you get any power to the wheels.
> Traditional French clutch. All the French cars I've drive have had a
> clutch like that. It's something I've never got used to.
My previous car (exact same brand and model, just the previous revision)
had a clutch which behaved normally. (Although it was starting to wear
out TBH. One more reason to get rid of it!)
>> I still haven't found a way to lock the car yet. Presumably if I walk
>> far enough away, it will lock. (But I'll be far away, so I have no way
>> of verifying this.)
> Try pushing all the buttons! :D
Turns out the button on the door handle will lock the door - if the key
is in range.
>> (Which, considering that the clutch doesn't work properly, isn't
>> much fun.)
> It does. It's just French.
[Insert joke here about the legendary tendancy of the French to not work.]
>> - It does not appear to be possible to turn the headlights on or off.
>> They just turn themselves on or off when they feel like it. (Presumably
>> too many French people decided to drive off in the middle of the night
>> with no lights on or something?)
> That's actually a good thing. Light automation rocks, when you get used
> to it you'll hate the German cars without it :-).
This morning I drove to work on a dark, cloudy day - but the computer
still decided I didn't need my lights on. *I* would have kept them on
anyway...
>> The wipers don't work very well (but then, they never do).
> Wait, what? They never do? In the history of me and cars I've had *one*
> car with *one* problem on wipers and that was a loose nut on a 14-year
> old car!
The wipers leave little streaks behind at exactly eye-height [but only
on the driver's side].
The rear wiper only sweeps 10% of the screen in the first place [because
it's conical], and do almost nothing to clear even the area being swept.
And, unlike any other car I've seen, driving at speed seems to somehow
*attract* water to the screen, rather than repel it.
>> I couldn't say whether the 20% bigger engine makes it go any faster,
> If it doesn't, it's crap :).
Well, yes. ;-)
So far I haven't been able to climb above 35 MPG - so that's 10 MPG
lower than my old car. :-(
>> since I'm constantly in the wrong gear. (I've yet to figure out how to
>> access 6th gear. Every time I try I get 4th instead.) Selecting reverse
>> is a tad tricky too. I guess I'll get used to it.
> You will, you just need to find the 6th first to know how to get there.
Selecting reverse requires you to pull the little ring. But, unlike my
old car, it's at the opposite end of the stick, which keeps confusing me...
Subject: Re: Manual mayhem
Date: 4 Feb 2010 13:35:14
Message: <4b6b1362$1@news.povray.org>
Invisible wrote:
> First of all, all the diagrams are for a left-hand drive car. You think
> that doesn't matter? Well, the buttons on the central console are the
> other way around on a right-hand drive car. (E.g., the lock and start
> buttons are the other way around.)
Still the gearbox is the same etc, so not everything is mirrored?
> Thirdly, the manual contains endless instances of "if you have this
> option, press button A. Alternatively, if you have this other option,
> press button B." But which freakin option do *I* have?!
If you don't know, you test it.
> My favourit is the manual for the stereo system, which tells you how to
> load and unload CDs from the CD changer, but omits to mention WHERE THIS
> IS! (I have since discovered that I don't actually *have* one - contrary
> to the information given to me when I purchased the car.)
Ask them to lower the price for that or to change a CD-changer to the car.
> I spent 20 minutes trying to find the airbag disable switch on the
> passenger door before I figured out that when they switched the car to
> right-hand drive, they forgot to move the switch. So it's still on the
> right-hand side, it's just that that isn't the passenger side anymore!
Aaahahahaaa :-D
> And another thing. Does anybody remember when if you wanted to fit
> seatbelts, you just went to B&Q, bought some seatbelts, and bolted them
> to the car?
OTOH you now have officially room for 5 passengers (really for 4) and
also seatbelts for 5 passengers. Why would you fit more of them?
> Well of course *this* car has seatbelt pre-tensioners,
> force-limiters, front and side air bags, and who knows what else. So if
> you want to do *anything* to the seats or seatbelts, you have to get a
> qualified Renault engineer to do it.
Isn't it actually a *good* thing that it's a lot safer than your old car?
> Now manufacturers *always* want you to use their own parts. They make
> way more money that way. And I'm pretty sure that no matter what the
> manual says, putting non-approved engine oil into my engine isn't going
> to destroy it (provided that it's of the correct type).
Yep. It just can void the warranty.
> But it seems
> there are so many things on this car that require specialist equipment
> to work on.
Yes, there are.
> You're supposed to get the crash sensors and air bag pyrotechnics
> checked annually - which can only be done by specially-trained Renault
> technitions with specialist equipment.
That's probably in the service program, right?
> Good thing I don't have the Xeon lights though - those have to be
> referred to a qualified service technition due to the high-voltage
> components inside. (Seeing a pattern here yet?)
OTOH you don't need to change xenon bulbs so often. I drove 90Mm's with
the original xenon bulbs on Audi. Just try to do that with halogen.
> And then there's the controls. I think I'm going to have to build a
> flowchart or something. Take one example:
> The control for the wipers has 4 positions, A, B, C and D. In position
> A, the wipers are off. B is intermittent. C is normal speed, and D is
> fast speed. Unless your car is fitted with the automatic wipe option, in
> which case B is intermittent wipe depending on the amount of water
> detected.
Well yes, this is pretty normal.
> [Don't you just love the way *you* have to know what the spec of the car
> is to figure out which instructions apply?]
Yes. The other possibility would be that the manual says that you
*don't* have that one option and then it's added afterwards.
> Mine evidently has the automatic option, since it wipes every 20
> seconds, but now and then it suddenly starts frantically trying to file
> through the glass! o_O
If you have a properly working automatic wiper option, you simply don't
need to touch the lever yourself except for some rare wipe-once
-situations - just keep it in the automatic position.
> This is probably THE single most annoying feature. It's raining, you
> stop at some traffic lights, and suddenly you can't see ANYTHING. Or
> even worse, you stop at a busy junction, trying to find a gap to pull
> out into. This is THE MOST CRITICAL TIME to need to see what's around
> you, but no, your wipers have turned themselves off without your
> permission.
Yes, that sounds stupid.
> Now of course, the lights turn themselves off, not when you stop the
> engine, but when you open the door. So somebody has programmed in a
> feature [I forget how you select it] where the lights stay on for 30
> seconds after you lock the car. (They call it "guide me home" -
> presumably so you can see your front door or something...)
Yes. You can see the lock in your door to fit the key, it's very
practical :-).
> And the middle part of the back seat folds out into a table with cup
> holders. WTF?
If you'll take some nice girl to a car-picnic and it starts to rain, you
can benefit from that table ;-).
-Aero
Subject: Re: Beautiful safety warnings
Date: 4 Feb 2010 13:52:20
Message: <4b6b1764$1@news.povray.org>
Invisible wrote:
> What I liked most was the warning to never put the seatbelt under your
> arm or behind your back. It seems so *ludicrously* obvious that this
> will result in horrifying bodily injury that I cannot believe anybody
> would do something so stupid...
> ...and yet, they bothered to print the warning, so...
That's a warning I'd remove, to let natural selection do its job.
> I also liked the warning to never leave children unattended inside the
> car. Yeah, LIKE ANYBODY IS TAKING ANY NOTICE OF THAT ONE! Still, I guess
> the idea isn't really to keep children safe, but to protect Renault from
> lawsuits. ;-)
I read about a man who had to do something at work on a weekend. It was
supposed to be pretty quick (a 5 minute thing). He was in the car with his
child (presumably to go somewhere else afterwards). He actually spent *three
hours* inside the office. When he came back, the kid was dead.
Temperature inside the car, which was receiving direct and strong sunlight
and had no open windows: 50°C.
Date: 4 Feb 2010 14:01:37
Message: <4b6b1991$1@news.povray.org>
Orchid XP v8 wrote:
> Still, my new
You haven't driven Volvo 940/960 or even 740/760, have you? ;)
-Aero
Date: 4 Feb 2010 14:04:48
Message: <4b6b1a50@news.povray.org>
> a £400,000 car. :-P
Neither one of those is a £400000 car. Or if was, Saab wouldn't be in
financial problems :-).
Mind you, I recall we're about the same age (I was born in late 1981)
and I just bought a 9-3 TiDS. TTiD costs only 3000€ more in Finland.
I don't think Land Rover had turbos 30 years ago (not sure though).
-Aero
Date: 4 Feb 2010 14:12:17
Message: <4b6b1c11@news.povray.org>
> lawsuits. ;-)
  Maybe they are philanthropes honestly worried about the safety of children.
Date: 4 Feb 2010 14:12:32
Message: <4b6b1c20$1@news.povray.org>
Orchid XP v8 wrote:
> ...it's grey.
Yes, yes it is.
> Really?
Yep.
And an enormous amount of torque.
It must have been broken :-P. My mother's 1.gen Megane did have the
French clutch.
> is in range.
...even if the key is inside the car?
It's not a question of working or not, it's a question of different
styles. It does it's job quite nicely after all, doesn't it? Therefore
it works.
> anyway...
Then you should tune the automagic up to light them up easier.
Clean the driver-side wiper. If that doesn't help, change it.
Well yes, that is a common problem (the rear wiper being mostly cosmetical).
Change the wiper, it's worn out.
The rear glass? Yes it does, because it's vertical. It's aerodynamics.
That's because you're not familiar with the engine and transmission.
According to SID (the on-board computer) I'm driving 5,7l/100km (around
41MPG - dunno if that's American or Imperial).
Ah, you'll get used to it :-).
-Aero
Date: 4 Feb 2010 14:20:00
Message: <4b6b1de0@news.povray.org>
That, and scrub the road grease off the window.  And clean the other wiper
while you're at it, if it pushes into the space used by the driver's side wiper.
   Forget "focus follows mouse." When do
   I get "focus follows gaze"?
